    Y axis moving when trying to move Z axis with multiple Z motors
    Beta Firmware
    1.5k
      deckingman @HWW
      @HWW said in Y axis moving when trying to move Z axis with multiple Z motors:
      I suspect that it really is something going on with the firmware but I do not know how to confirm or fix it.
      I'm leaning towards the opinion that you may be right and that it might be a firmware issue, but I'm just an end user like you. I am using 13 stepper drivers spread across the main board and 3 expansion boards but only a single Z motor, so I'm unable to replicate your set up. Hopefully David, @DC42 will step in soon with some suggestions or comments.
        droftarts administrators
        What firmware is installed on the expansion board? Send M115 B1
        HWWundefined 1 Reply Last reply Reply Quote 0
          deckingman @HWW
          @HWW Just another suggestion but does it make any difference if you omit the H2 parameter? You'll need to use M564 H0 to allow moves prior to homing.
          • HWWundefined
            HWW @droftarts
            @droftarts Both the main board with M115 and the expansion with M115 B1 report back with Firmware 3.0RC1
            @deckingman Using M564 H0 and omiting the H2 parameter from the G1 commands results in the same movements, so no difference there.
            • HWWundefined
              HWW
              Dont know why I didnt think of this before using the M584 command on its own spits out the drive mapping in the console. I never got around to actually testing the extruders but looks like those are mapped wrong as well. You can see in this photo I tried entering the M584 with the mapping command as well and the report after is also screwed up.
              The first info from the M584 shows 0.0 and 0.1 mapped into the first two spots on the z axis followed by 0.5 and 0.4 this is using the last config line I was using which was "M584 X1.0 Y0.0:0.1 Z0.5:0.4:0.3:0.2 E1.1:1.2"
              Then in the console I tried entering my original config of "M584 X1.0 Y0.0:0.1 Z0.2:0.3:0.4:0.5 E1.1:1.2" and it again results in 0.0 and 0.1 in the first two spots with 0.2 and 0.3 filling the last two.
              And in both cases the extruders are mapped to 0.0 and 0.1 which I never noticed before as well
                Try defining those connected to main board without 0. on front.
                • HWWundefined
                  HWW @droftarts
                  @droftarts No change in the result from removing the explicit board number, I also went ahead and threw in my other test of assigning all the Z motors to the Y axis to confirm that entering the mapping into the console was changing things and you can see the strange result from that as well. The Y axis is mapped correctly but both Z and E are incorrect.
                    Can you try mapping all drives individually in order, eg
                    M584 X0.0 Y0.1 Z0.2 U0.3 V0.4 W0.5 A1.0 B1.1 C1.2 P9
                    And see what it reports?
                    The only other thing I notice is that in the RRF 3 overview notes, a comma is used to delimit the second board. Might be a typo, though? https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M584
                    • HWWundefined
                      HWW @droftarts
                      @droftarts Assigning them all individually like that they mapped correctly, the drive map report matched the mapping command.
                      I played around with it a bit more and I think whats happening has something to do with having multiple motors on two axis
                      I tried M584 X0.0 Y0.1:0.2 Z0.3 U0.4 V0.5 W1.0 A1.1 B1.2 P8 and that mapped correctly
                      However when I tried M584 X0.0 Y0.1:0.2 Z0.3:0.4 U0.5 V1.0 W1.1 A1.2 P7
                      the resulting map was X0.0 Y0.1:0.2 Z0.1:0.2 U0.5 V1.0 W1.1 A1.2
                      Also in all cases the extruders were mapped to 0:0 and 0:1 which I think is a default value since no E parameter was in the mapping
                      • HWWundefined
                        HWW
                        Yeah look at this one
                        M584 X0.0:0.1 Y0.2:0.3 Z0.4:0.5 E1.0:1.1
                        results in a reported drive map of
                        X0.0:0.1 Y0.0:0.1 Z0.0:0.1 E0.0:0.1
                        • Danalundefined
                          Danal
                          Yep. I just tried two axis with two motors each. Reproduced the issue.
                          12/21/2019, 7:02:51 PM	M584 X0.0 Y0.1:0.3 Z0.4:0.5 U0.2 E0.3:0.4
                          12/21/2019, 7:02:58 PM	M584
                          Driver assignments: X0.0 Y0.1:0.3 Z0.1:0.3 U0.2 E0.1:0.3, 4 axes visible
                          Z should be 4 5, instead it is repeat of Y's 1 3. E is wrong as well, again, a repeat of 1 3
                          Interestingly enough, it is OK to have multiple motors on Z and E. This is my day-to-day configuration on a tool changer:
                          12/21/2019, 7:06:11 PM	M584
                          Driver assignments: X0.0 Y0.1 Z0.3:0.4:0.5 U0.2 E1.0:1.1, 4 axes visible
                            So, bug? One for @dc42? Thanks for getting to the bottom of it!
                            • Danalundefined
                              Danal
                              Certainly looks like a bug.
                              And I'm running what I believe to be the very latest:
                              Board: Duet 3 MB6HC (MB6HC)
                              DSF Version: 1.1.0.5
                              Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12+1 (2019-12-02b2)
                              • Danalundefined
                                Danal
                                Same thing happens if X has more than one motor, it "overlays" all later multimotor axis mappings.
                                12/21/2019, 7:12:02 PM	M584 X0.0:0.3 Y0.1 Z0.4:0.5 U0.2 E1.0:1.1
                                12/21/2019, 7:12:08 PM	M584
                                Driver assignments: X0.0:0.3 Y0.1 Z0.0:0.3 U0.2 E0.0:0.3, 4 axes visible
                                TRIPLE motor Z seems to work fine:
                                12/21/2019, 7:13:29 PM	M584 X0.0 Y0.1 Z0.3:0.4:0.5 U0.2 E1.0:1.1
                                12/21/2019, 7:13:42 PM	M584
                                Driver assignments: X0.0 Y0.1 Z0.3:0.4:0.5 U0.2 E0.3:0.4, 4 axes visible
                                However, DUAL motor Z overlays E:
                                12/21/2019, 7:14:39 PM	M584 X0.0 Y0.1 Z0.4:0.5 U0.2 E1.0:1.1
                                12/21/2019, 7:14:45 PM	M584
                                Driver assignments: X0.0 Y0.1 Z0.4:0.5 U0.2 E0.4:0.5, 4 axes visible
                                • HWWundefined
                                  HWW @Danal
                                  @Danal Triple motor Z also overwrote the E mapping
                                  My best guess is that whatever values are getting used for multi motor mapping are not reset or filled or something between cycles of the code loop running
                                  • Danalundefined
                                    Danal
                                    Yep, and it looks like it is the "single line parser" loop. Specifying each axis on a separate line yields proper results. For example, with this sequence, E never gets overlaid:
                                    12/21/2019, 7:17:40 PM	M584
                                    12/21/2019, 7:17:45 PM	M584 X0.0
                                    12/21/2019, 7:17:58 PM	M584 Y0.1:0.3
                                    12/21/2019, 7:18:16 PM	M584
                                    Driver assignments: X0.0 Y0.1:0.3 Z0.3:0.4:0.5 U0.2 E1.0:1.1, 4 axes visible
                                    12/21/2019, 7:18:34 PM	M584 Z0.4:0.5
                                    12/21/2019, 7:18:41 PM	M584
                                    Driver assignments: X0.0 Y0.1:0.3 Z0.4:0.5 U0.2 E1.0:1.1, 4 axes visible
                                    12/21/2019, 7:18:54 PM	M584 E1.0:1.1
                                    12/21/2019, 7:18:59 PM	M584
                                    This also provides a bypass until this is fixed.
                                    • HWWundefined
                                      HWW @Danal
                                      @Danal A workaround solution until things get a proper fix!! Fantastic. I was just about to ask what your day to day config looks like since in the example from before it E got overwritten but you had a working readout from your day to day.
                                      • Danalundefined
                                        Danal @HWW
                                        You are correct!!!
                                        And I just looked in my actual config.g, and I'd separated the extruders because this is a toolchanger and I'm adding tools one at a time:
                                        ; Axis to driver mapping
                                        M584 X0 Y1 U2 Z3:4:5        ; X and Y for CoreXY.  U for toolchanger lock. Z has three drivers for kinematic bed suspension.
                                        M584 E1.0:1.1               ; Extruders for four tools.
                                        Man, a bullet dodged a few weeks back. That would have been VERY frustrating when I was trying to figure out a bunch of other stuff as well...!
                                        • HWWundefined
                                          HWW
                                          I have added this as an issue to the github tracker
                                          https://github.com/dc42/RepRapFirmware/issues/345
                                          HWW-GS created this issue in dc42/RepRapFirmware
                                          closed M584 Multi Axis/Motor Mapping Error #345
                                            dc42 administrators @HWW
                                            It's probably a DSF issue not a RRF issue, because it doesn't happen when the Duet 3 is run in standalone mode.
