    RepRapFirmware 3.0RC2 now available
    Beta Firmware
    11
    39
    3.1k
      dc42 administrators @nraynaud
      @nraynaud said in RepRapFirmware 3.0RC2 now available:
      I may have been chasing a red herring:
      M552 S0 ; awaken wifi module and set to idle
      M587 S"NUMERICABLE-B290" P"PASS" ; send this line to be saved in wifi module
      M552 S1 ; connect the wifi module to the network
      of course, those lines looks like a reboot.
      Not a reboot, just turning the network off and on again. The only one of those lines you need is M552 S1.
      • nraynaudundefined
        nraynaud
        yes.
        I don't have a reboot in my configuration, but I still have a weird hang during homing.
        is there a way to dump the state of the machine? I feel like it's waiting for something.
        here is a log during homing:
        21:59:09M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0RC2 running on Duet WiFi 1.02 or later + DueX5
        Board ID: 08DDM-9FAM2-LW4SD-6JKD4-3S46L-92X3W
        Used output buffers: 10 of 24 (16 max)
        Static ram: 30516
        Dynamic ram: 93164 of which 12 recycled
        Exception stack ram used: 488
        Never used ram: 6892
        Tasks: NETWORK(ready,640) HEAT(blocked,1184) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156)
        Owned mutexes:
        Last reset 00:27:43 ago, cause: software
        Last software reset at 2019-12-29 21:31, reason: User, spinning module GCodes, available RAM 6788 bytes (slot 0)
        Error status: 0
        Free file entries: 9
        MCU temperature: min 33.9, current 35.2, max 35.7
        Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: standstill, SG min/max 359/1023
        Driver 1: standstill, SG min/max 344/1023
        Driver 3: standstill, SG min/max 56/1023
        Driver 4: standstill, SG min/max 0/196
        Driver 5: standstill, SG min/max not available
        Driver 6: standstill, SG min/max not available
        Driver 7: standstill, SG min/max not available
        Date/time: 2019-12-29 21:59:08
        Slowest loop: 8.01ms; fastest: 0.09ms
        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 165, MaxWait: 1652015ms
        === MainDDARing ===
        Scheduled moves: 8, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
        === AuxDDARing ===
        Segments left: 1
        Stack records: 2 allocated, 1 in use
        Movement lock held by http
        http is doing "G53 G1 Y-415 F360 H1" in state(s) 0 8, running macro
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 15.86ms; fastest: 0.00ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 1 of 8
        - WiFi -
        Network state is running
        WiFi firmware version 1.23
        WiFi MAC address 60:01:94:34:3b:19
        WiFi Vcc 3.37, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 19376
        WiFi IP address 192.168.0.28
        WiFi signal strength -57dBm, reconnections 0, sleep mode modem
        21:58:58G28 Y
          Looks like it thinks it is executing the Y homing move and waiting for the endstop to trigger. Maybe the Y motor current or motor current percentage is set to zero? Or the Y motor mapped to the wrong driver?
          • nraynaudundefined
            nraynaud
            ; homey.g
            ; called to home the Y axis
            ; generated by RepRapFirmware Configuration Tool on Wed Nov 15 2017 23:36:04 GMT-0700 (MST)
            ; Lift Z relative to current position
            G91
            G1 Z2 F6000
            G90
            ; M98 P"outdanger.g"
            ; Move quickly to Y axis endstop and stop there (first pass)
            G53 G1 Y-415 F10000 H1
            ; Go back a few mm
            G53 G1 Y3 F40000
            ; Move slowly to Y axis endstop once more (second pass)
            G53 G1 Y2 F10000
            ; Lower Z again
            G91
            G1 Z-2 F6000
            G90
            it has moved and done the coarse homing right before that.
            executing it line by line seems to work ok:
            22:48:41G90
            22:48:35G1 Z-2 F6000
            22:48:28G91
            22:48:22G53 G1 Y2 F10000
            22:48:16G53 G1 Y-415 F360 H1
            22:48:05G53 G1 Y3 F40000
            22:47:56G53 G1 Y-415 F10000 H1
            22:47:47G90
            22:47:40G1 Z2 F6000
            22:47:32G91
            22:47:31Connection established!
            I really don't know. running `M98 P"homey.g"' triggers the issue too.
            edit: I get the bug both with and without the pullup, but I don't see any influence of this setting the web interface anyways (the switch works perfectly in my tests in the web interface)
              You really ought to be using relative movement commands with G1 H1. Also, i still donm;'t understand why you think you need the G53 prefixes. What happens if you use relative movement and no G53 prefixes?
              • nraynaudundefined
                nraynaud
                In my limited testing (the software side of this project feels like being a ball at a rugby game, everything is just hard, I don't know what conclusion actually hold), homing without G53 was placing the tool center at the switch trigger point instead of placing the machine zero there.
                I will look into the relative movements, I need to find the original example files, thanks.
                • nraynaudundefined
                  nraynaud
                  I found it! Thanks for your help.
                  I need more time or more distance to back out of the switches after the coarse homing (what's weird is that I had the same issue in X and Y). That's why I couldn't find the issue line by line.
                  have you de-bounced the switches or changed the execution order?
                    There has been a change in behaviour when you execute a homing move and the switch is already triggered. Previously, the move would be started and when the first microstep was due, at that point it would recognise that the switch was triggered. Now it checks the switches before starting the move. If they are triggered, it should cancel the move, unless there are other motors being homed using different switches. It sounds to me that it is behaving as if there is another switch waiting to be triggered.
                    • stewwyundefined
                      stewwy
                      Is manual bed probing working in 3.0RC2, (my IRprobe is not working,a different problem). I've changed the probe type to P0. This worked in 2.05 giving me the manual menu in DWC/Paneldue but not in 3.0RC2. Is there something else I need to do? I have noticed that the Z endstop is showing as constantly triggered.
                      EDIT: It gave me this error--
                      G28
                      Error: SetPositions called when DDA ring not empty
                      • blt3dpundefined
                        blt3dp
                        Is it up on the unstable package server?
                        My 3D Printing YouTube Channel
                        Better Living Through 3D Printing
                        Follow me on Instagram and Twitter
                        Instagram
                        Twitter
                        • chrishammundefined
                          chrishamm administrators
                          The latest version on the unstable package feed is now RC2+1 because I found another DSF-related issue involving macro files. If anyone wants to compile it, those changes are on my v3-chrishamm branch of RRF.
                          Duet software engineer
                          blt3dpundefined 1 Reply Last reply Reply Quote 0
                          • chas2706undefined
                            chas2706
                            @chrishamm
                            Hi are you aware of M291 error "command not known" in DSF
                              Yes, see https://github.com/chrishamm/DuetSoftwareFramework/tree/dev#known-issues
                              • chas2706undefined
                                chas2706
                                Ok cheers!
                                • blt3dpundefined
                                  blt3dp @chrishamm
                                  @chrishamm
                                  Doing sudo apt-get update and then apt-get upgrade gives this error on reprap firmware package.
                                  Setting up reprapfirmware (1.2.2.0-1) ...
                                  [error] Failed to connect to Duet
                                     System.IO.IOException: Error 16. Cannot put line into event mode.
                                     at LinuxDevices.InputGpioPin..ctor(String devNode, Int32 pin, String consumerLabel) in /home/christian/duet/DuetSoftwareFramework/src/LinuxDevices/InputGpioPin.cs:line 60
                                     at DuetControlServer.SPI.DataTransfer.Init() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 65
                                     at DuetControlServer.SPI.Interface.Init() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 65
                                     at DuetControlServer.Program.Main(String[] args) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 92
                                  Everything else updated except for the firmware, still on 3.0RC1
                                  I noticed the Duet3Firmware_MB6HC.bin on the virtual SD card had today's timestamp so I ran M997 and it updated, now it shows 3.0RC2+1
                                  Instagram
                                  Twitter
                                    jay_s_uk @blt3dp
                                    @blt3dp
                                    I had that happened as well.
                                    If you run M997 S0, the firmware is still updated
                                    • blt3dpundefined
                                      blt3dp @jay_s_uk
                                      @jay_s_uk said in RepRapFirmware 3.0RC2 now available:
                                      @blt3dp
                                      Yep, I was just doing an edit. That's exactly what I did.
                                      Instagram
                                      Twitter
                                        Error code 16 means Device or resource busy. From what version did you upgrade?
                                          jay_s_uk @chrishamm
                                          @chrishamm RC2
                                            I mean from what DSF version
                                            blt3dpundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
