    RepRapFirmware 3.0RC2 now available
    Beta Firmware
    11
    39
    3.1k
    • nraynaudundefined
      nraynaud
      ; homey.g
      ; called to home the Y axis
      ; generated by RepRapFirmware Configuration Tool on Wed Nov 15 2017 23:36:04 GMT-0700 (MST)
      ; Lift Z relative to current position
      G91
      G1 Z2 F6000
      G90
      ; M98 P"outdanger.g"
      ; Move quickly to Y axis endstop and stop there (first pass)
      G53 G1 Y-415 F10000 H1
      ; Go back a few mm
      G53 G1 Y3 F40000
      ; Move slowly to Y axis endstop once more (second pass)
      G53 G1 Y-415 F360 H1
      G53 G1 Y2 F10000
      ; Lower Z again
      G91
      G1 Z-2 F6000
      G90
      it has moved and done the coarse homing right before that.
      executing it line by line seems to work ok:
      22:48:41G90
      22:48:35G1 Z-2 F6000
      22:48:28G91
      22:48:22G53 G1 Y2 F10000
      22:48:16G53 G1 Y-415 F360 H1
      22:48:05G53 G1 Y3 F40000
      22:47:56G53 G1 Y-415 F10000 H1
      22:47:47G90
      22:47:40G1 Z2 F6000
      22:47:32G91
      22:47:31Connection established!
      I really don't know. running `M98 P"homey.g"' triggers the issue too.
      edit: I get the bug both with and without the pullup, but I don't see any influence of this setting the web interface anyways (the switch works perfectly in my tests in the web interface)
        You really ought to be using relative movement commands with G1 H1. Also, i still donm;'t understand why you think you need the G53 prefixes. What happens if you use relative movement and no G53 prefixes?
        • nraynaudundefined
          nraynaud
          In my limited testing (the software side of this project feels like being a ball at a rugby game, everything is just hard, I don't know what conclusion actually hold), homing without G53 was placing the tool center at the switch trigger point instead of placing the machine zero there.
          I will look into the relative movements, I need to find the original example files, thanks.
          • nraynaudundefined
            nraynaud
            I found it! Thanks for your help.
            I need more time or more distance to back out of the switches after the coarse homing (what's weird is that I had the same issue in X and Y). That's why I couldn't find the issue line by line.
            have you de-bounced the switches or changed the execution order?
              dc42 administrators @nraynaud
              @nraynaud said in RepRapFirmware 3.0RC2 now available:
              There has been a change in behaviour when you execute a homing move and the switch is already triggered. Previously, the move would be started and when the first microstep was due, at that point it would recognise that the switch was triggered. Now it checks the switches before starting the move. If they are triggered, it should cancel the move, unless there are other motors being homed using different switches. It sounds to me that it is behaving as if there is another switch waiting to be triggered.
              • stewwyundefined
                stewwy
                Is manual bed probing working in 3.0RC2, (my IRprobe is not working,a different problem). I've changed the probe type to P0. This worked in 2.05 giving me the manual menu in DWC/Paneldue but not in 3.0RC2. Is there something else I need to do? I have noticed that the Z endstop is showing as constantly triggered.
                EDIT: It gave me this error--
                G28
                Error: SetPositions called when DDA ring not empty
                • blt3dpundefined
                  blt3dp
                  Is it up on the unstable package server?
                  My 3D Printing YouTube Channel
                  Better Living Through 3D Printing
                  Follow me on Instagram and Twitter
                  Instagram
                  Twitter
                  • chrishammundefined
                    chrishamm administrators
                    The latest version on the unstable package feed is now RC2+1 because I found another DSF-related issue involving macro files. If anyone wants to compile it, those changes are on my v3-chrishamm branch of RRF.
                    Duet software engineer
                    blt3dpundefined 1 Reply Last reply Reply Quote 0
                    • chas2706undefined
                      chas2706
                      @chrishamm
                      Hi are you aware of M291 error "command not known" in DSF
                        Yes, see https://github.com/chrishamm/DuetSoftwareFramework/tree/dev#known-issues
                        • chas2706undefined
                          chas2706
                          Ok cheers!
                          • blt3dpundefined
                            blt3dp @chrishamm
                            @chrishamm
                            Doing sudo apt-get update and then apt-get upgrade gives this error on reprap firmware package.
                            Setting up reprapfirmware (1.2.2.0-1) ...
                            [error] Failed to connect to Duet
                               System.IO.IOException: Error 16. Cannot put line into event mode.
                               at LinuxDevices.InputGpioPin..ctor(String devNode, Int32 pin, String consumerLabel) in /home/christian/duet/DuetSoftwareFramework/src/LinuxDevices/InputGpioPin.cs:line 60
                               at DuetControlServer.SPI.DataTransfer.Init() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 65
                               at DuetControlServer.SPI.Interface.Init() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 65
                               at DuetControlServer.Program.Main(String[] args) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 92
                            Everything else updated except for the firmware, still on 3.0RC1
                            I noticed the Duet3Firmware_MB6HC.bin on the virtual SD card had today's timestamp so I ran M997 and it updated, now it shows 3.0RC2+1
                            Instagram
                            Twitter
                              jay_s_uk @blt3dp
                              @blt3dp
                              I had that happened as well.
                              If you run M997 S0, the firmware is still updated
                              • blt3dpundefined
                                blt3dp @jay_s_uk
                                @jay_s_uk said in RepRapFirmware 3.0RC2 now available:
                                @blt3dp
                                Yep, I was just doing an edit. That's exactly what I did.
                                Instagram
                                Twitter
                                  Error code 16 means Device or resource busy. From what version did you upgrade?
                                    jay_s_uk @chrishamm
                                    @chrishamm RC2
                                      I mean from what DSF version
                                      blt3dpundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                      • blt3dpundefined
                                        blt3dp @chrishamm
                                        @chrishamm said in RepRapFirmware 3.0RC2 now available:
                                        I was coming from DSF version 1.2.1.0 with with 3.0RC1
                                        Unpacking duetsoftwareframework (1.2.2.0) over (1.2.1.0)
                                        Unpacking reprapfirmware (1.2.2.0-1) over (1.2.1.0-1)
                                        Unpacking duettools (1.2.2.0) over (1.2.1.0)
                                        Unpacking duetcontrolserver (1.2.2.0) over (1.2.1.0)
                                        Unpacking duetruntime (1.2.2.0) over (1.2.1.0)
                                        Instagram
                                        Twitter
                                          jay_s_uk @chrishamm
                                          @chrishamm 1.2.1.0 for me too
                                            I see, thanks. I'll try to reproduce that.
                                            daaveryundefined 1 Reply Last reply Reply Quote 0
