    Is there likely a way to repair a blown PWM output?
    2.0k
      The tricky part is removing the blown MOSFET. It's easy with a hot air rework station, difficult otherwise. Soldering the replacement MOSFET can be done using an ordinary soldering iron with a fine tipped bit.
      • briangilbertundefined
        briangilbert
        I do have soldering station with hot air luckily, whether or not I can get the SMD MOSFET locally or have to order online is the question.
        Online it seems..
        @dc42 can you please confirm this is a suitable replacement?
        http://au.element14.com/nxp/pmv40un2/mosfet-n-ch-30v-4-4a-sot-23-3/dp/2469654
        And how I can confirm if thats the part that would have blown?
        Co-creator of the Zesty Nimble direct drive extruder
          T3P3Tony administrators
          The part is a PMV40UN2 so that's spot on.
          • InSanityundefined
            InSanity
            Good you have the hot air rework station, personally I don't even attempt to do SMD work without. I prefer about a 1mm wide chisel tip. Too pointy and they do nothing good. Flux flux flux. Clean up with some 91% + iso and all is well.
            Also learning the art of drag soldering is always a good skill, not useful in this case but sure comes in handy.
            Jeff
            Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
            • InSanityundefined
              InSanity
              Ohh, a bit of kapton tape covering areas you don't want melting is a useful trick. If you have plastic connectors too close for example, cover them loosely with kapton. More or less make a heat shield.
              • Zesty_Lykleundefined
                Zesty_Lykle
                Good thing it happened to Brian and not to me. My thick fingers would have a great deal of trouble over this. Besides, all I have is a small soldering iron. He is the electronics I am mechanical. Good split.
                Lykle
                Design, make and enjoy life
                Co Creator of the Zesty Nimble
                • gen2engundefined
                  gen2eng
                  So, what is the correct orientation for the flyback diode? I'm getting ready to connect a Berd-Air also and the orientation discrepancies have me nervous. I would rather not get lucky…
                  It would be great if the Wiki page could be updated. https://duet3d.com/wiki/Connecting_and_configuring_fans
                  Thanks!
                    The wiki page already mentioned the need for a flyback diode, but I've just updated the text with information about the polarity.
                    • ShadowXundefined
                      ShadowX
                      If you have a microscope, it would make the job a lot easier! 🙂
                        I find a pair of strong reading glasses sufficient during soldering, supplemented by an eyeglass for inspecting the joints after soldering.
                        • InSanityundefined
                          InSanity
                          @ShadowX:
                          I find that to be too much mag in most cases. Great for final inspection however.
