    Pressure Advance seems to not be working.
    83
    6.7k
    • Samuel235undefined
      Samuel235
      Cube just completed:
      Single Walled Cube Pressure Advance Test 01
      As you can see throughout the range of 0.5 to 7 PA value there is no difference. This was with a jerk value of 8000mm/min. I’m dropping that jerk down to 4000mm/min now for another test. Should i expect to see any improvements with lowering the extruder acceleration value too?
        Phaedrux Moderator @Samuel235
        @Samuel235 something isn't right. There should definitely be some noticeable difference over such a wide range of 0.5 to 7.
        What command are you using?
        Can you post your config?
          Samuel235
          Nothing has changed from the settings i posted originally, other than change to the extruder current limit. Do you want me to post them again (Asking as i’m not at my system at the moment but will get to it if needed) so you can confirm any typos were not made or something? I don’t believe there is anything i would have typoed as It was just a change of number not a command or anything.
            How are you changing the PA value? Via the console during the print, or is it scripted into the gcode file?
            I'm thinking it may not actually be getting applied because there should definitely be some visible result. At a value of 7 you'd likely see the extruder reversing dramatically.
            Samuel235undefined 1 Reply Last reply Reply Quote 0
              Samuel235 @Phaedrux
              @Phaedrux - its hardcoded into the code, but i confirm it changes every 25 layers using the command line console. The extruder behaviour changes each time PA changes, i can confirm that. But nothing changes in the print.
              Im thinking PA is working but something is masking its effects, hence why i was thinking of changing jerk and possibly acceleration on the extruder.
                Are you still getting hiccups?
                  Samuel235 @Phaedrux
                  @Phaedrux - This is a M122 just ran (around an hour after the print finished, this would still be reporting from the print, right?):
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-956GU-DJMSN-6J1F4-3SJ6N-1BNBF
                  Used output buffers: 6 of 24 (20 max)
                  Static ram: 25680
                  Dynamic ram: 94256 of which 308 recycled
                  Exception stack ram used: 492
                  Never used ram: 10336
                  Tasks: NETWORK(ready,524) HEAT(blocked,1236) DUEX(suspended,156) MAIN(running,1668) IDLE(ready,160)
                  Owned mutexes:
                  Last reset 75:55:33 ago, cause: software
                  Last software reset at 2019-12-31 18:44, reason: User, spinning module GCodes, available RAM 10232 bytes (slot 2)
                  Error status: 16
                  Free file entries: 10
                  SD card longest block write time: 378.3ms, max retries 0
                  MCU temperature: min 40.0, current 54.9, max 59.0
                  Supply voltage: min 23.9, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: standstill, SG min/max 0/1023
                  Driver 1: standstill, SG min/max 0/1023
                  Driver 3: standstill, SG min/max 0/1023
                  Driver 5: standstill, SG min/max 0/270
                  Driver 6: standstill, SG min/max 0/281
                  Driver 7: standstill, SG min/max 0/284
                  Driver 8: standstill, SG min/max 0/291
                  Date/time: 2020-01-03 22:40:42
                  Slowest loop: 149.85ms; fastest: 0.08ms
                  Hiccups: 0, FreeDm: 169, MinFreeDm: 145, MaxWait: 156472642ms
                  === DDARing ===
                  Heater 0 is on, I-accum = 0.0
                  Heater 1 is on, I-accum = 0.5
                  Segments left: 0
                  Stack records: 4 allocated, 0 in use
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is idle in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 379.69ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  - WiFi -
                  Network state is running
                  Failed messages: pending 0, notready 0, noresp 8
                  WiFi firmware version 1.23
                  WiFi MAC address 5c:cf:7f:76:71:05
                  WiFi Vcc 3.32, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 24672
                  WiFi IP address 192.168.0.26
                  WiFi signal strength -52dBm, reconnections 0, sleep mode modem
                    @Samuel235 said in Pressure Advance seems to not be working.:
                    As long as you haven't run a M122 or power cycled the count should still be from the print.
                    well I'm all out of ideas. Do experiment with different jerk and acceleration values, but usually the higher values would just mean giving pressure advance room to manage the extruder position rather than limiting it.
                    • DIY-O-Sphereundefined
                      DIY-O-Sphere @DIY-O-Sphere
                      @DIY-O-Sphere said in Pressure Advance seems to not be working.:
                      Maybe the jerk value for the extruder is too high.
                      While setting up PA today, I had the same issue. After decreasing jerk to 1000 mm/min I was able to print the test cube.
                      That's a common case with a geared extruder.....You will find that also documented in other threads
                      (UTC+1)
                        Samuel235
                        Should i try changing the acceleration of XY, just thinking back, on that cube the seam would only cause PA to activate pretty much only on the seam itself, nothing before or after it was instantly on the seam and then stopped as it increased Z to the next layer.
                        Just putting it out there that maybe my CY acceleration os causing PA to have no time to perform its work?
                          DIY-O-Sphere
                          That are the values that I have set for PA
                          M566 X900.00 Y900.00 Z12.00 E1000.00
                          M203 X15000.00 Y15000.00 Z300.00 E12000.00
                          M201 X1600.00 Y1600.00 Z150.00 E3000.00
                          In my opinion all your values are fin exept the jerk.
                          By increasing the gear ratio you have to decrease jerk.
                          For a Nimble extruder other users advise to go below 100
                          I use a BMG which is geared 3:1
                          (UTC+1)
                            Samuel235
                            After the last cube I have got the following result (I still can't really see much of a difference, is the seam getting smaller high we go do you feel, if so maybe I just need to take PA up higher, it was 0.7:
                            Jerk settings were:
                            M566 X900 Y900 Z60 E1000
                            M122 after this print was:
                            M122
                            Used output buffers: 5 of 24 (9 max)
                            Static ram: 25680
                            Exception stack ram used: 540
                            Never used ram: 10288
                            Tasks: NETWORK(ready,692) HEAT(blocked,1236) DUEX(suspended,156) MAIN(running,1668) IDLE(ready,160)
                            Owned mutexes:
                            Last reset 02:58:13 ago, cause: software
                            Last software reset at 2020-01-04 09:39, reason: User, spinning module GCodes, available RAM 10336 bytes (slot 3)
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                            Error status: 0
                            SD card longest block write time: 7.2ms, max retries 0
                            MCU temperature: min 44.1, current 44.4, max 56.6
                            Driver 5: standstill, SG min/max 0/271
                            Driver 6: standstill, SG min/max 0/278
                            Driver 7: standstill, SG min/max 0/282
                            Driver 8: standstill, SG min/max 0/288
                            Slowest loop: 116.70ms; fastest: 0.07ms
                            Hiccups: 0, FreeDm: 169, MinFreeDm: 149, MaxWait: 165675ms
                            === DDARing ===
                            Heater 1 is on, I-accum = 0.6
                            Segments left: 0
                            === Network ===
                            Slowest loop: 39.70ms; fastest: 0.00ms
                            - WiFi -
                            WiFi MAC address XXXXXXXXXXX
                            WiFi flash size 4194304, free heap 23208
                            WiFi IP address XXXXXXXXXXXXXX
                            WiFi signal strength -55dBm, reconnections 0, sleep mode modem
                              DIY-O-Sphere
                              You can sent the command directly in DWC
                              M572 D0 S#.# (#, set the number for the value)
                              I would recommend to switch every 4-5 mm between PA 0 and current PA value +adding an amount.
                              Then it's easier to see the difference in direct comparison....
                              I have done that with a custom code in Prusaslicer.
                              That are values between 0,6 and 1,4
                              (UTC+1)
                              Samuel235undefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                Samuel235 @DIY-O-Sphere
                                @DIY-O-Sphere - So something like the following:
                                0-5mm: PA 0
                                5-10mm: PA 0.2
                                10-15mm: PA 0.4
                                15-20mm: PA 0
                                20-25mm: PA 0.6
                                25-30mm: PA 0
                                30-35mm: PA 0.8
                                35-40mm: PA 0
                                40-45mm: PA 1
                                I have been doing it just one after another without a 0 between, I see what you mean now, it will enable me to check all the way through the range easily back to original. Thank you, will get that done now.
                                  DIY-O-Sphere
                                  I have compared your last result with my first print, where Jerk was too high.
                                  Looks pretty similar. So maybe the jerk is still too high?
                                  In the lower area (PA 0.2-1.0) there is absolutely no visible difference. Then above 1.2 the extrusion begins to fail....
                                  What is the gear ratio of the extruder?
                                  (UTC+1)
                                  Phaedruxundefined Samuel235undefined 2 Replies Last reply Reply Quote 0
                                    Phaedrux Moderator @DIY-O-Sphere
                                    The pressure advance retreat combined with the retraction may have pulled the filament up high enough to get stuck.
                                    • zaptaundefined
                                      zapta @DIY-O-Sphere
                                      As a side note, the upcoming PrusaSlicer will make it even easier to set per height configurations.
                                      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
                                        @DIY-O-Sphere - This is a 4:1 ratio extruder
                                        @zapta - That is such an awesome addition to the slicer!
                                          DIY-O-Sphere @zapta
                                          @zapta said in Pressure Advance seems to not be working.:
                                          That is exactly the way I have done it ....
                                          (UTC+1)
                                          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                            And what is also awesome: If you save the project file as 3mf you will be able to take that as template, without setting up all layer changes....
                                            (UTC+1)
