BLtouch with Reprap Firmware 3.0
27
3.6k
    Adamfilip
    Cant seem to get my BLtouch to work after updating to Reprap firmware 3.0
    hoping for some advice
    This is my current config
    ; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time)
    M550 P"TitanXY" ; set printer name
    M667 S1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwards
    M569 P1 S0 ; physical drive 1 goes backwarsa
    M569 P2 S0 ; physical drive 2 goes backwards
    M350 X32 Y32 Z32 I0 ; configure microstepping without interpolation
    M350 E16 I1 ; configure microstepping with interpolation
    M92 X400 Y400 Z1593 E409 ; set steps per mm
    M566 X600 Y600 Z20 E800 ; Set maximum instantaneous speed changes (mm/min)
    M203 X9000 Y9000 Z1500 E10000 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z250 E5000 ; Set accelerations (mm/s^2)
    M906 X1200 Y1200 Z1500 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M572 D0 S0.15 ; Pressure Advance ; Set idle timeout
    M208 X270 Y270 Z300 S0 ; set axis maxima
    M574 X1 S3 ; configure sensorless endstop for low end on X
    M574 Y1 S3 ; configure sensorless endstop for low end on Y
    ; BLTouch
    ; BLTouch - Heaters
    M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
    M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
    ;M558 P5 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
    G31 P25 X22 Y0 Z2.2 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
    M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
    M308 S1 P"e0temp" Y"thermistor" T110.23 B-356.98 ; configure sensor 1 as thermistor on pin e0temp
    M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
    M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
    M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
      jrsphoto
      Funny, I just ( about 20 min ago) got this working for myself.
      I'm sure there are still things wrong with my config.g but you can look at it here. I would also have you look at the Duet/BLTouch guide posted here. You didn't mention which Duet board your using but lets just say its the Duet 2 Wifi. Look at the wifi section of that page. Pay special note to where to connect the BLTouch to the board. Heater3 in the case of the Duet 2 Wifi. If you connect your BLTouch to those pins, and use the probe section from my config, you should be good:
      M950 H3 C"nil" ; Disable heaters h3-h7 to free up pins
      M950 H4 C"nil"
      M950 H5 C"nil"
      M950 H6 C"nil"
      M950 H7 C"nil"
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H10 F800 T2000 ; set Z probe type to bltouch and the dive height + speeds
      The M950's with the C"nil" are there to free up those pins. You only really need to free up H3 for the BLTouch in this case, but I figured I wasn't using those so I'd free them all up.
      Let me know if you have any questions
        Adamfilip
        Ok I am using Heater3
        Duet Wifi 2
        here is my updated config
        ; BLTouch - Heaters
        ;M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
        M950 H7 C"nil" ; Disable heaters h7 to free up pins
        G31 X20 Y0 Z3.3 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
        Here is my homeall setup
        ; homeall.g
        ; called to home all axes
        M913 X75 Y75 Z100 ; reduce motor power
        M400 ; make sure everything has stopped before we make changes
        M915 H400 X Y S0 R0 F0 ; set X and Y to sensitivity 0, do nothing when stall, unfiltered
        M574 X1 Y1 S3 ; set endstops to use motor stall
        G91 ; use relative positioning
        G4 P500 ; wait 500msec
        G1 H1 X-285 F2000 ; move quickly to X axis endstop and stop there (first pass)
        G1 X5 ; move away from home
        G1 H1 Y-285 F2000 ; move quickly to Y axis endstop and stop there (first pass)
        G1 Y5 ; move away from home
        G1 H2 Z10 F6000 ; lift Z relative to current position
        G1 X150 Y150 F1200 ; Centre Print head
        G1 H1 Z-305 F1800 ; move Z down until the endstop is triggered
        G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
        M913 X100 Y100 ; XY motors to 100% current
        G90 ; back to absolute positioning
        Currently im getting this error
        G28 SetPosition called when DDA ring not empty
        for wiring I have the BLTOUCH
        White Wire (Z signal) = Z Probe IN
        Orange (Servo Sig) = Heater3
        Red (5v) = +5V
        Brown (GND) = GND
          jrsphoto
          That looks good.. These V3 /config.g files are complicated. More so than with versio 2.x I think. Have you tried it
            jrsphoto
            @Adamfilip said in BLtouch with Reprap Firmware 3.0:
            One change.. Change:
            to
            M950 H3 C"nil" ; Disable heaters h3 to free up pins
              Adamfilip
              I managed to get it to deploy in tests but when I run homeall
              it gets to the point where it centers the head
              then it gives me the error
                CupaCabra
                Hallo, can you over a Macro or a G-Code push the BLTouche Pin in or out.
                I have the BLTouch config like you and the BlTouch don´t move the Pin.
                  CupaCabra
                  ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 09:19:35 GMT+0100 (Mitteleuropäische Normalzeit)
                  M550 P"My Printer" ; set printer name
                  M551 P"123456" ; set password
                  M569 P4 S1 ; physical drive 4 goes forwards
                  M584 X0 Y1 Z2 E3:4 ; set drive mapping
                  M92 X80.00 Y80.00 Z4000.00 E415.00:415.00 ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                  M906 X1000 Y1000 Z1400 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M208 X400 Y400 Z500 S0 ; set axis maxima
                  ;M574 Z1 S2
                  ; BLTouch - Heaters
                  ;M307 H3 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
                  M950 H3 C"nil"
                  ;M950 H4 C"nil"
                  ;M950 H5 C"nil"
                  ;M950 H6 C"nil"
                  ;M950 H7 C"nil" ; Disable heaters h7 to free up pins
                  M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
                  M557 X50:350 Y50:350 S50 ; define mesh grid
                  M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
                  M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                  M143 H2 S280 ; set temperature limit for heater 2 to 280C
                  M307 H2 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                  M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
                  M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                  M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on
                  M563 P1 H2 F0 ; define tool 1
                  I have the BLTouch wired on Heater3 (PIN8) on the Duet Wifi Board.
                  i take the G-Code to test M401 / M402
                  or
                  M280 P3 S10 I1
                  M280 P3 S160 I1
                  M280 P3 S120 I1
                  nothing move it.
                  With the old Firmeware 2.05 the Pin Move in and out.
                  undefined 1 Reply Last reply 9 Jan 2020, 11:23 Reply Quote 0
                    DIY-O-Sphere
                    @CupaCabra said in BLtouch with Reprap Firmware 3.0:
                    Have you also adapted deployprobe.g and retractprobe.g?
                    (UTC+1)
                      DIY-O-Sphere @CupaCabra
                      M280 P3 S10 I1
                      M280 P3 S160 I1
                      M280 P3 S120 I1
                      Now you have to use
                      M280 P0 S10
                      M280 P0 S160
                      M280 P0 S120
                      (UTC+1)
                      undefined 1 Reply Last reply 9 Jan 2020, 11:27 Reply Quote 0
                        CupaCabra
                        yes i have but i don´t now is it right.
                        deployprobe.g
                        M280 P3 S10 I1
                        and in retractprobe.g
                        M280 P3 S90 I1
                        i hope there are right
                          DIY-O-Sphere
                          change P3 to P0 and remove I1
                          (UTC+1)
                            CupaCabra @DIY-O-Sphere
                            @DIY-O-Sphere
                            i change the Code in the Config now an test it.
                              CupaCabra
                              It´works with
                              M280 P3 S10 ......
                              thx so lot 🙂
                              droftartsundefined 1 Reply Last reply 9 Jan 2020, 11:50 Reply Quote 0
                                droftarts administrators @CupaCabra
                                @CupaCabra Great! Please post the 'Z-Probe' section of your config.g to show how you resolved this!
                                Also, you don't need to unassign the heater channels in RRF3 with M950 H3 C"nil", as they are not assigned by default. Only a few pins are assigned by default, and only need to be unassigned if you use them for something else; see https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Duet_2_WiFi_Ethernet_and_Duet_2_Maestro
                                  DIY-O-Sphere
                                  M280 P3 S10 ......
                                  Now I am confused.
                                  You will find exact your configuration in
                                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M280_Set_servo_position
                                  And we have done it succesfully on a buddys wifi exact that way with heater7.
                                  Are you shure you have update to the stable and not to a older beta.
                                  I think there you had to trigger the heater instead of the servo channel.
                                  (UTC+1)
                                    DIY-O-Sphere
                                    @droftarts said in BLtouch with Reprap Firmware 3.0:
                                    The beta would explain that too.
                                    (UTC+1)
                                      CupaCabra
                                      so i have change the
                                      deployprobe.g
                                      M280 P3 S10
                                      retractprobe.g
                                      M280 P3 S90
                                      if i test with a Marco file
                                      The pin go´s out with S10 und retract with S90
                                      I think it´s right.
                                        CupaCabra
                                        ;M574 Z1 S2
                                        ; BLTouch - Heaters
                                          CupaCabra
                                          the
                                          Firmware : 3.0 (2020-01-03b3)
                                          WiFi Server Version: 1.23
                                          Web Interface: 1.22.6
                                          5 out of 27
