BL-Touch don´t trigger by Home Z
608
    CupaCabra
    I have a other Problem with my Printer and BLTouch.
    I home X and Y, in the second step are Home Z.
    The Bed go´s UP but wehn i Trigger the BL-Touch mith my Finger the Pin are stif and the Bed want chrash into the BLTouch.
    my HomeZ config
    ; homez.g
    ; called to home the Z axis
    ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 13:42:31 GMT+0100 (Mitteleuropäische Normalzeit)
    G91 ; relative positioning
    G90 ; absolute positioning
    G1 X50 Y50 F6000 ; go to first probe point
    ;G91 ; relative positioning
    ;G90 ; absolute positioning
    are those OK
    undefined 1 Reply Last reply 9 Jan 2020, 14:07 Reply Quote 0
      DIY-O-Sphere @CupaCabra
      @CupaCabra
      Have you edited also the homeall.g?
      You have to change the M98 for calling the macros for deploy and retract...
        Veti
        post your config.g
          CupaCabra
          The homeall.g
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 09:19:35 GMT+0100 (Mitteleuropäische Normalzeit)
          G1 H1 X-405 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X-405 ; home X axis
          G1 H1 Y-405 ; home Y axis
          G1 H1 X-405 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H1 Y-405 ; then move slowly to Y axis endstop
          G1 H1 Z505 F360 ; move Z up stopping at the endstop
          G92 Z500 ; set Z position to axis maximum (you may want to adjust this)
          undefined 1 Reply Last reply 9 Jan 2020, 14:22 Reply Quote 0
            CupaCabra
            and the config.g
            M550 P"My Printer" ; set printer name
            M667 S1 ; select CoreXY mode
            M551 P"123456" ; set password
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P4 S1 ; physical drive 4 goes forwards
            M584 X0 Y1 Z2 E3:4 ; set drive mapping
            M92 X80.00 Y80.00 Z4000.00 E415.00:415.00 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1400 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X400 Y400 Z500 S0 ; set axis maxima
            M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin xstop
            M574 Y1 S1 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
            ; BLTouch - Heaters
            ;M307 H3 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
            M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
            G31 X20 Y0 Z3.3 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
            M557 X50:350 Y50:350 S50 ; define mesh grid
            M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
            M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
            M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
            M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
            M143 H2 S280 ; set temperature limit for heater 2 to 280C
            M307 H2 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
            M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
            M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
            M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on
            M563 P1 H2 F0 ; define tool 1
              Veti
              @CupaCabra said in BL-Touch don´t trigger by Home Z:
              there is no config for the probe
              add
              undefined 1 Reply Last reply 9 Jan 2020, 14:28 Reply Quote 0
                Veti
                B4138
                your thermistors are configured wrong. that is the default and incorrect for your thermistors.
                  @CupaCabra
                  As far as I could see the deploy and retract of bltouch is missing on homeall.g.
                  undefined undefined 2 Replies Last reply 9 Jan 2020, 14:26 Reply Quote 0
                    CupaCabra
                    Ok, i change the Config.g
                    but the thermistors shows the Temp. right.
                    i use the PT100 Thermistors
                      Veti
                      that is in no way reflected in your config.
                      undefined 1 Reply Last reply 9 Jan 2020, 14:29 Reply Quote 0
                        CupaCabra @DIY-O-Sphere
                        @DIY-O-Sphere are not in the G30 deploy and the retract command inside.
                        undefined 1 Reply Last reply 9 Jan 2020, 14:31 Reply Quote 0
                          DIY-O-Sphere @Veti
                          This post is deleted!
                            CupaCabra @Veti
                            @Veti can you help me ar it´s possible 4 you.
                            So i can change the right Data in the Config.
                            Sry 4 the stupid Help Requests
                              Veti @DIY-O-Sphere
                              @DIY-O-Sphere said in BL-Touch don´t trigger by Home Z:
                              Probe P9 does not require that
                                @CupaCabra
                                And where do you call the G30?
                                It's not incuded in the homeall.g
                                Normaly it would look like this:
                                ; homeall.g
                                ; generated by RepRapFirmware Configuration Tool on Sat Jul 14 2018 17:15:09 GMT+0200 (Mitteleuropäische Sommerzeit)
                                G1 H1 X-310 Y-325 F3500 ; move quickly to X or Y endstop and stop there (first pass)
                                G1 H1 X-310 ; home X axis
                                G1 H1 Y-325 ; home Y axis
                                G1 H1 X-310 F360 ; move slowly to X axis endstop once more (second pass)
                                G1 H1 Y-325 ; then move slowly to Y axis endstop
                                G1 X128 Y160 F6000 ; go to first bed probe point and home Z
                                M98 "Pdeployprobe.g" ; deploy mechanical Z probe
                                ;G1 H2 Z5 F100 ; uncomment this line to lift the nozzle after homing
                                M98 "Pretractprobe.g" ; retract mechanical Z probe
                                undefined 1 Reply Last reply 9 Jan 2020, 14:42 Reply Quote 0
                                  Veti
                                  PT 100 would be configured like this (change the spi to match the correct terminal)
                                  M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs1
                                  M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs2
                                  M308 S2 P"spi.cs3" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs3
                                  but if you get output without this, this strongly indicated that you do not have pt100 sensors.
                                  undefined 1 Reply Last reply 9 Jan 2020, 14:46 Reply Quote 0
                                    @DIY-O-Sphere
                                    ; homeall.g
                                    ; generated by RepRapFirmware Configuration Tool v2.1.4 on Fri Dec 20 2019 11:16:59 GMT+0100 (Mitteleuropäische Normalzeit)
                                    G1 H1 X385 Y355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                    G1 H1 X385 ; home X axis
                                    G1 H1 Y355 ; home Y axis
                                    G1 X-5 Y-5 F6000 ; go back a few mm
                                    G1 H1 X385 F360 ; move slowly to X axis endstop once more (second pass)
                                    G1 H1 Y355 ; then move slowly to Y axis endstop
                                    G1 H2 X0 Y0 F6000 ; go to first bed probe point and home Z
                                    ;M280 P0 S10 ; deploy
                                    M98 "deployprobe.g" ; deploy mechanical Z
                                    ;M280 P0 S90 ; retract
                                    M98 "retractprobe.g" ; deploy mechanical Z probe
                                    ;G1 S2 Z5 F100 ; lift Z relative to current position
                                    undefined 1 Reply Last reply 9 Jan 2020, 14:54 Reply Quote 0
                                      DIY-O-Sphere
                                      @Veti said in BL-Touch don´t trigger by Home Z:
                                      As you have much more experience you should take over now...😊
                                        CupaCabra @Veti
                                        @Veti YES 🙂 you are right there are
                                        100K 1% NTC
                                          @CupaCabra
                                          That is not the same code as posted first ....
                                          undefined 1 Reply Last reply 9 Jan 2020, 15:09 Reply Quote 0
                                          8 out of 25
