    BL-Touch don´t trigger by Home Z
    608
    • CupaCabraundefined
      CupaCabra
      The homeall.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 09:19:35 GMT+0100 (Mitteleuropäische Normalzeit)
      G91 ; relative positioning
      G1 H1 X-405 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-405 ; home X axis
      G1 H1 Y-405 ; home Y axis
      G1 H1 X-405 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-405 ; then move slowly to Y axis endstop
      G1 H1 Z505 F360 ; move Z up stopping at the endstop
      G90 ; absolute positioning
      G92 Z500 ; set Z position to axis maximum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G90 ; absolute positioning
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
        CupaCabra
        and the config.g
        M550 P"My Printer" ; set printer name
        M667 S1 ; select CoreXY mode
        M551 P"123456" ; set password
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P4 S1 ; physical drive 4 goes forwards
        M584 X0 Y1 Z2 E3:4 ; set drive mapping
        M92 X80.00 Y80.00 Z4000.00 E415.00:415.00 ; set steps per mm
        M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1400 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X400 Y400 Z500 S0 ; set axis maxima
        M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin xstop
        M574 Y1 S1 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
        ; BLTouch - Heaters
        ;M307 H3 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
        M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
        G31 X20 Y0 Z3.3 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
        M557 X50:350 Y50:350 S50 ; define mesh grid
        M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
        M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
        M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
        M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
        M143 H2 S280 ; set temperature limit for heater 2 to 280C
        M307 H2 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
        M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
        M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
        M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on
        M563 P1 H2 F0 ; define tool 1
        • Vetiundefined
          Veti
          @CupaCabra said in BL-Touch don´t trigger by Home Z:
          there is no config for the probe
          add
          • Vetiundefined
            Veti
            B4138
            your thermistors are configured wrong. that is the default and incorrect for your thermistors.
            • DIY-O-Sphereundefined
              DIY-O-Sphere @CupaCabra
              @CupaCabra
              As far as I could see the deploy and retract of bltouch is missing on homeall.g.
              CupaCabraundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                CupaCabra
                Ok, i change the Config.g
                but the thermistors shows the Temp. right.
                i use the PT100 Thermistors
                • Vetiundefined
                  Veti
                  that is in no way reflected in your config.
                  CupaCabraundefined 1 Reply Last reply Reply Quote 0
                    CupaCabra @DIY-O-Sphere
                    @DIY-O-Sphere are not in the G30 deploy and the retract command inside.
                      DIY-O-Sphere @Veti
                      This post is deleted!
                        CupaCabra @Veti
                        @Veti can you help me ar it´s possible 4 you.
                        So i can change the right Data in the Config.
                        Sry 4 the stupid Help Requests
                        • Vetiundefined
                          Veti @DIY-O-Sphere
                          @DIY-O-Sphere said in BL-Touch don´t trigger by Home Z:
                          Probe P9 does not require that
                            @CupaCabra
                            And where do you call the G30?
                            It's not incuded in the homeall.g
                            Normaly it would look like this:
                            ; homeall.g
                            ; generated by RepRapFirmware Configuration Tool on Sat Jul 14 2018 17:15:09 GMT+0200 (Mitteleuropäische Sommerzeit)
                            G1 H1 X-310 Y-325 F3500 ; move quickly to X or Y endstop and stop there (first pass)
                            G1 H1 X-310 ; home X axis
                            G1 H1 Y-325 ; home Y axis
                            G1 H1 X-310 F360 ; move slowly to X axis endstop once more (second pass)
                            G1 H1 Y-325 ; then move slowly to Y axis endstop
                            G1 X128 Y160 F6000 ; go to first bed probe point and home Z
                            M98 "Pdeployprobe.g" ; deploy mechanical Z probe
                            ;G1 H2 Z5 F100 ; uncomment this line to lift the nozzle after homing
                            M98 "Pretractprobe.g" ; retract mechanical Z probe
                            • Vetiundefined
                              Veti
                              PT 100 would be configured like this (change the spi to match the correct terminal)
                              M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs1
                              M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs2
                              M308 S2 P"spi.cs3" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs3
                              but if you get output without this, this strongly indicated that you do not have pt100 sensors.
                                @DIY-O-Sphere
                                ; homeall.g
                                ; generated by RepRapFirmware Configuration Tool v2.1.4 on Fri Dec 20 2019 11:16:59 GMT+0100 (Mitteleuropäische Normalzeit)
                                G1 H1 X385 Y355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                G1 H1 X385 ; home X axis
                                G1 H1 Y355 ; home Y axis
                                G1 X-5 Y-5 F6000 ; go back a few mm
                                G1 H1 X385 F360 ; move slowly to X axis endstop once more (second pass)
                                G1 H1 Y355 ; then move slowly to Y axis endstop
                                G1 H2 X0 Y0 F6000 ; go to first bed probe point and home Z
                                ;M280 P0 S10 ; deploy
                                M98 "deployprobe.g" ; deploy mechanical Z
                                ;M280 P0 S90 ; retract
                                M98 "retractprobe.g" ; deploy mechanical Z probe
                                ;G1 S2 Z5 F100 ; lift Z relative to current position
                                  DIY-O-Sphere
                                  @Veti said in BL-Touch don´t trigger by Home Z:
                                  As you have much more experience you should take over now...😊
                                    CupaCabra @Veti
                                    @Veti YES 🙂 you are right there are
                                    100K 1% NTC
                                      @CupaCabra
                                      That is not the same code as posted first ....
                                        @CupaCabra
                                        yes, there are the revisedet version with your command´s.
                                        i take your script as idol.
                                          @CupaCabra
                                          as @Veti mentioned you can remove the M98
                                          I have removed them too, as they furthermore where not correctly coded.
                                            CupaCabra
                                            Hello, i have clean all my Home Script´s.
                                            I have test with the Orginal Script´s
                                            like below
                                            ; homez.g
                                            ; called to home the Z axis
                                            ; generated by RepRapFirmware Configuration Tool v2.1.5 on Fri Jan 10 2020 12:51:00 GMT+0100 (Mitteleuropäische Normalzeit)
                                            G1 H1 Z505 F1800 ; move Z up until the endstop is triggered
                                            and
                                            ; homeall.g
                                            ; generated by RepRapFirmware Configuration Tool v2.1.5 on Fri Jan 10 2020 12:36:58 GMT+0100 (Mitteleuropäische Normalzeit)
                                            G1 H1 X405 Y405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                            G1 H1 X405 ; home X axis
                                            G1 H1 Y405 ; home Y axis
                                            G1 H1 X405 F360 ; move slowly to X axis endstop once more (second pass)
                                            G1 H1 Y405 ; then move slowly to Y axis endstop
                                            G1 H1 Z-505 F360 ; move Z down stopping at the endstop
                                            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                            ;G90
                                            the Pin don´t come Out i have try homeall und homez
                                            If i write on the DuePanel or in the WebBrowser
                                            M401 oder M402 der Pin get Out and In
                                            the same with M280 P0 S10 or S90
                                            But if i try G30 Code the Z Move UP but the Pin don´t come Out.
                                            If ist someone possible to Help me to fix the Prob. please
                                            Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
