    BL-Touch don´t trigger by Home Z
    608
    • CupaCabraundefined
      CupaCabra @DIY-O-Sphere
      @DIY-O-Sphere are not in the G30 deploy and the retract command inside.
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @Veti
        This post is deleted!
          CupaCabra @Veti
          @Veti can you help me ar it´s possible 4 you.
          So i can change the right Data in the Config.
          Sry 4 the stupid Help Requests
          • Vetiundefined
            Veti @DIY-O-Sphere
            @DIY-O-Sphere said in BL-Touch don´t trigger by Home Z:
            As far as I could see the deploy and retract of bltouch is missing on homeall.g.
            Probe P9 does not require that
              DIY-O-Sphere @CupaCabra
              @CupaCabra
              And where do you call the G30?
              It's not incuded in the homeall.g
              Normaly it would look like this:
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool on Sat Jul 14 2018 17:15:09 GMT+0200 (Mitteleuropäische Sommerzeit)
              G91 ; relative positioning
              G1 H1 X-310 Y-325 F3500 ; move quickly to X or Y endstop and stop there (first pass)
              G1 H1 X-310 ; home X axis
              G1 H1 Y-325 ; home Y axis
              G1 H1 X-310 F360 ; move slowly to X axis endstop once more (second pass)
              G1 H1 Y-325 ; then move slowly to Y axis endstop
              G90 ; absolute positioning
              G1 X128 Y160 F6000 ; go to first bed probe point and home Z
              M98 "Pdeployprobe.g" ; deploy mechanical Z probe
              ;G1 H2 Z5 F100 ; uncomment this line to lift the nozzle after homing
              M98 "Pretractprobe.g" ; retract mechanical Z probe
              CupaCabraundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti
                PT 100 would be configured like this (change the spi to match the correct terminal)
                M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs1
                M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs2
                M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                M308 S2 P"spi.cs3" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs3
                M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                M143 H2 S280 ; set temperature limit for heater 2 to 280C
                M307 H2 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                but if you get output without this, this strongly indicated that you do not have pt100 sensors.
                  @DIY-O-Sphere
                  ; homeall.g
                  ; generated by RepRapFirmware Configuration Tool v2.1.4 on Fri Dec 20 2019 11:16:59 GMT+0100 (Mitteleuropäische Normalzeit)
                  G1 H1 X385 Y355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                  G1 H1 X385 ; home X axis
                  G1 H1 Y355 ; home Y axis
                  G1 X-5 Y-5 F6000 ; go back a few mm
                  G1 H1 X385 F360 ; move slowly to X axis endstop once more (second pass)
                  G1 H1 Y355 ; then move slowly to Y axis endstop
                  G1 H2 X0 Y0 F6000 ; go to first bed probe point and home Z
                  ;M280 P0 S10 ; deploy
                  M98 "deployprobe.g" ; deploy mechanical Z
                  ;M280 P0 S90 ; retract
                  M98 "retractprobe.g" ; deploy mechanical Z probe
                  ;G91 ; relative positioning
                  ;G1 S2 Z5 F100 ; lift Z relative to current position
                  ;G90 ; absolute positioning
                    DIY-O-Sphere
                    @Veti said in BL-Touch don´t trigger by Home Z:
                    As you have much more experience you should take over now...😊
                      CupaCabra @Veti
                      @Veti YES 🙂 you are right there are
                      100K 1% NTC
                        @CupaCabra
                        That is not the same code as posted first ....
                          @CupaCabra
                          yes, there are the revisedet version with your command´s.
                          i take your script as idol.
                            @CupaCabra
                            as @Veti mentioned you can remove the M98
                            I have removed them too, as they furthermore where not correctly coded.
                              CupaCabra
                              Hello, i have clean all my Home Script´s.
                              I have test with the Orginal Script´s
                              like below
                              ; homez.g
                              ; called to home the Z axis
                              ; generated by RepRapFirmware Configuration Tool v2.1.5 on Fri Jan 10 2020 12:51:00 GMT+0100 (Mitteleuropäische Normalzeit)
                              G1 H1 Z505 F1800 ; move Z up until the endstop is triggered
                              G92 Z500 ; set Z position to axis maximum (you may want to adjust this)
                              and
                              ; homeall.g
                              ; generated by RepRapFirmware Configuration Tool v2.1.5 on Fri Jan 10 2020 12:36:58 GMT+0100 (Mitteleuropäische Normalzeit)
                              G1 H1 X405 Y405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                              G1 H1 X405 ; home X axis
                              G1 H1 Y405 ; home Y axis
                              G1 H1 X405 F360 ; move slowly to X axis endstop once more (second pass)
                              G1 H1 Y405 ; then move slowly to Y axis endstop
                              G1 H1 Z-505 F360 ; move Z down stopping at the endstop
                              G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                              ;G90
                              the Pin don´t come Out i have try homeall und homez
                              If i write on the DuePanel or in the WebBrowser
                              M401 oder M402 der Pin get Out and In
                              the same with M280 P0 S10 or S90
                              But if i try G30 Code the Z Move UP but the Pin don´t come Out.
                              If ist someone possible to Help me to fix the Prob. please
                              Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • Vetiundefined
                                Veti @CupaCabra
                                your home scripts are for switches and not for probes.
                                there is no reason why the bltouch should deploy.
                                please go to the configurator and select bltouch and generate new home scripts.
                                  Phaedrux Moderator @CupaCabra
                                  @CupaCabra said in BL-Touch don´t trigger by Home Z:
                                  Please post your deployprobe and retractprobe files.
                                  Does the pin respond when you send M401 and M402?
