    New RepRapFirmware config tool
    79
    10.3k
    • Danalundefined
      Danal
      You should get a "popup" or "overlay" like this:
      Does safari have any way to turn off popup blocking?
      renehundefined 1 Reply Last reply Reply Quote 0
      • PaulHewundefined
        PaulHew
        Please could you look at the issue in regards to selecting BLTouch as a probe type for the Ender3 template with RRF3 in the config tool.
        It is currently greyed out and is unselect-able.
        I mentioned it in a previous post and DC42 informed me he would look into it.
        Veti gave me the lines I need for it to work, mapping the pins.
        Thanks
        Paul
        • chrishammundefined
          chrishamm administrators @PaulHew
          @PaulHew said in New RepRapFirmware config tool:
          Thanks
          Paul
          I can select the BLTouch with RRF2 and RRF3 but in order to select it with RRF3, you need to assign the PWM Control Channel on the I/O Mapping page first. Then you can activate BLTouch on the Endstops page.
          Duet software engineer
          • PaulHewundefined
            PaulHew
            @chrishamm Thanks for the fast reply!
            I have a Duet Maestro board.
            On the I/O mapping page I cannot select any of the 'PWM Control Channels (BLTouch only).
            I can see them in the drop down but they are not selectable.
            My thinking was if I was able select BLT on the Endstops page it would automatically create the I/O mapping.
            Edit: Also on the Endstops page I cannot select 'Z Probe' for the Z axis
            Regards,
            Paul.
              @PaulHew You must set "Z Probe Mod Pin" to (not assigned) before you can use it in the input below. I'll consider that suggestion.
                chrishamm administrators @reneh
                @reneh There was a problem in the configtool that prevented the popup from being shown on OS X. It has been fixed in the latest version (2.1.8).
                  jay_s_uk
                  @chrishamm Is there a github repo for the config tool where issues can be raised to make them easier to track like there is for DWC?
                    chrishamm administrators @jay_s_uk
                    @jay_s_uk said in New RepRapFirmware config tool:
                    Yes, it's on GitHub.
                    • PaulHewundefined
                      PaulHew
                      @chrishamm Again, thanks for the speedy reply.
                      Ok I have done that and I was able to eventually select Z-Probe and then select BLT. Thank you.
                      I program, but not what you clever guys write.
                      As another suggestion for the I/O mapping page, based on selecting the Ender3 template with a Maestro board could there be a tick box for say 'If using a BLTouch check this box'
                      Which then selects the correct options, using the Ender3 template with a Maestro board makes the changes needed to the I/O mapping page and the Endstop page.?
                      • renehundefined
                        reneh @Danal
                        @Danal
                        Hi, in google chrome i get such a popup but not in safari. In safari popups not blocked. strange phenomenon. Is there any other safari setting in safari that i need to consider?
                        Thank you
                        • infiniteloopundefined
                          infiniteloop
                          @reneh said in New RepRapFirmware config tool:
                          Have a look at this guide …
                            Technically it isn't a pop-up, it's just a div. @reneh try to clear your browser cache and it should work again.
                            • renehundefined
                              reneh
                              Hi all, it works. Thank you very much
                              Bye
