    New RepRapFirmware config tool
    79
    10.3k
    • Vetiundefined
      Veti
      the tool tabs does not allow to select anything else that E0 for extruder, heater and fan
      steevebeckerundefined 1 Reply Last reply Reply Quote 0
      • steevebeckerundefined
        steevebecker @Veti
        @Veti I have partially the same problem
        in the I/O Mapping Tab, I have added : +1 Driver for the second extruder, +1 Heater, +1 Fan
        pin out everything
        but then in the Tool Tab, tools there is only FAN0 available for any tool.
        I/O TAB:
        Fan TAB seems ok:
        But then in the Tool TAB
        plant your ideas, water suggestions and questions, collect progress and do great things.
        • Vetiundefined
          Veti
          ignore my comment above its working.
          @steevebecker
          you need to disable thermostatic control for another fan.
            steevebecker
            @Veti Make sense ! It works
            • jlipavsky79undefined
              jlipavsky79
              is this stable for duet3 config?? Also..... im setting up a duet3 as a cnc controler...
              How about cnc stuff???? A tab for cnc config like for the spindle speed output setting, for turning on and forward and reverse. Configuring for a vac system for triggering through gcode.... maybe for coolant pumps through gcode..... probing like digitizer probe.....
                T3P3Tony administrators @jlipavsky79
                @jlipavsky79 that's a good point, we do need to extend the config tool for CNC and Laser modes of operation. I hope some of the CNC experienced on the forum can suggest good options and reasonable defaults.
                • renehundefined
                  reneh @chrishamm
                  @chrishamm Hi, great work. I try to use this tool in safari browser 13.04 bud I can not open/edit XYZ Offsets in the too tab. Could you tell me please how can I fix this?
                  • Danalundefined
                    Danal
                    You should get a "popup" or "overlay" like this:
                    Does safari have any way to turn off popup blocking?
                    renehundefined 1 Reply Last reply Reply Quote 0
                    • PaulHewundefined
                      PaulHew
                      Please could you look at the issue in regards to selecting BLTouch as a probe type for the Ender3 template with RRF3 in the config tool.
                      It is currently greyed out and is unselect-able.
                      I mentioned it in a previous post and DC42 informed me he would look into it.
                      Veti gave me the lines I need for it to work, mapping the pins.
                      Thanks
                      Paul
                      • chrishammundefined
                        chrishamm administrators @PaulHew
                        @PaulHew said in New RepRapFirmware config tool:
                        Thanks
                        Paul
                        I can select the BLTouch with RRF2 and RRF3 but in order to select it with RRF3, you need to assign the PWM Control Channel on the I/O Mapping page first. Then you can activate BLTouch on the Endstops page.
                        Duet software engineer
                        • PaulHewundefined
                          PaulHew
                          @chrishamm Thanks for the fast reply!
                          I have a Duet Maestro board.
                          On the I/O mapping page I cannot select any of the 'PWM Control Channels (BLTouch only).
                          I can see them in the drop down but they are not selectable.
                          My thinking was if I was able select BLT on the Endstops page it would automatically create the I/O mapping.
                          Edit: Also on the Endstops page I cannot select 'Z Probe' for the Z axis
                          Regards,
                          Paul.
                            @PaulHew You must set "Z Probe Mod Pin" to (not assigned) before you can use it in the input below. I'll consider that suggestion.
                              chrishamm administrators @reneh
                              @reneh There was a problem in the configtool that prevented the popup from being shown on OS X. It has been fixed in the latest version (2.1.8).
                                jay_s_uk
                                @chrishamm Is there a github repo for the config tool where issues can be raised to make them easier to track like there is for DWC?
                                  chrishamm administrators @jay_s_uk
                                  @jay_s_uk said in New RepRapFirmware config tool:
                                  Yes, it's on GitHub.
                                  • PaulHewundefined
                                    PaulHew
                                    @chrishamm Again, thanks for the speedy reply.
                                    Ok I have done that and I was able to eventually select Z-Probe and then select BLT. Thank you.
                                    I program, but not what you clever guys write.
                                    As another suggestion for the I/O mapping page, based on selecting the Ender3 template with a Maestro board could there be a tick box for say 'If using a BLTouch check this box'
                                    Which then selects the correct options, using the Ender3 template with a Maestro board makes the changes needed to the I/O mapping page and the Endstop page.?
                                    • renehundefined
                                      reneh @Danal
                                      @Danal
                                      Hi, in google chrome i get such a popup but not in safari. In safari popups not blocked. strange phenomenon. Is there any other safari setting in safari that i need to consider?
                                      Thank you
                                      • infiniteloopundefined
                                        infiniteloop
                                        @reneh said in New RepRapFirmware config tool:
                                        Have a look at this guide …
                                          Technically it isn't a pop-up, it's just a div. @reneh try to clear your browser cache and it should work again.
                                          • renehundefined
                                            reneh
                                            Hi all, it works. Thank you very much
                                            Bye
