    DWC2 bug: heater names not displayed correctly
    Duet Web Control
    8
    23
    1.1k
    • SIamundefined
      SIam
      The same Problem here
      Board: Duet WiFi 1.02 or later + DueX5
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
      Version von Duet WiFi Server: 1.23
      Duet Web Control 2.0.4
      in dwc1 the names are shown correctly
      in dwc2 the names are missing so its impossible to switch betwen on/aktiv/standby
      config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Jan 05 2020 16:17:09 GMT+0100 (Mitteleuropäische Normalzeit)
      G90                                                 ; send absolute coordinates...
      M83                                                 ; ...but relative extruder moves
      M550 P"hypercube"                                   ; set printer name
      M667 S1                                             ; select CoreXY mode
      M552 S1                                             ; enable network
      M586 P0 S1                                          ; enable HTTP
      M586 P1 S1                                          ; disable FTP
      M586 P2 S1                                          ; disable Telnet
      M569 P0 S0                                          ; physical drive 0 = X goes backwards
      M569 P1 S0                                          ; physical drive 1 = Y goes backwards
      M569 P2 S1                                          ; physical drive 2 = Z goes forwards
      M569 P3 S1                                          ; physical drive 3 = E0 goes forwards
      M569 P4 S1                                          ; physical drive 4 = Z goes forwards
      M569 P5 S0                                          ; physical drive 5 = Z goes backwards
      M569 P6 S1                                          ; physical drive 6 = E1 goes forwards
      M584 X0 Y1 Z2:4:5 E3                                  ; set drive mapping
      M671 X0:380:0 Y52:190:327 S3 F1.0; Leitspindeln links und rechts von der X-Achse ****
      M350 X16 Y16 Z16:16:16 E16 I1                          ; configure microstepping with interpolation
      M92 X200.60 Y200.60 Z797:797:797 E2666.67           ; set steps per mm
      M566 X600.00 Y600.00 Z300.00 E40.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z1200.00 E4800.00     ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z500.00 E120.00          ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1500.00 E500                        ; set motor currents (mA)
      M84 S0                                              ; Disable motor idle current reduction
      M208 X-1 Y0 Z-1 S1                                  ; set axis minima
      M208 X400 Y370 Z450 S0                              ; set axis maxima
      M574 X1 S1 P"xstop"                                 ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                 ; configure active-high endstop for low end on Y via pin ystop
      M558 P8 R0.4 C"^!zprobe.in+zprobe.mod" H5 F450 T6000 ;
      G31 P500 X0 Y0 Z-0.25                                 ; set Z probe trigger value, offset and trigger height
      M557 X15:390 Y15:370 S25                            ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" A"Heizbett" T100000 B3950      ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                               ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S100                                        ; set temperature limit for heater 0 to 100C
      M307 H0 B0 S1.00                                    ; disable bang-bang mode for the nozzle heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4276       ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S280                                        ; set temperature limit for heater 1 to 280C
      M307 H1 B0 S1.00                                    ; disable bang-bang mode for the nozzle heater and set PWM limit
      M950 F0 C"fan0" Q25500 ;H-1                              ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1 F25500 C"Bauteilkühlung"                                  ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan1" Q75 T45 ;H1                              ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45 F75 C"Hotend"                                    ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q250 ;H-1                              ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S0 H-1 F250 C"LED"                                  ; set fan 2 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                                  ; define tool 0              *****
      G10 P0 X0 Y0 Z0                                     ; set tool 0 axis offsets
      G10 P0 R0 S0                                        ; set initial tool 0 active and standby temperatures to 0C
      M501                                                ; load saved parameters from non-volatile memory
      T0                                                  ; select first tool
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      remopiniundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
      • remopiniundefined
        remopini @SIam
        @SIam You can still switch (by clicking on the blue "Bett" or "Werkzeug 0"), but it is highly annoying 🙂
        • SIamundefined
          SIam
          ok you are right 😮
          • wilrikerundefined
            wilriker
            OK, since in all cases there is no DuetSoftwareFramework in play this means it's a bug in either RRF or DWC. I'll take a quick look at it.
            EDIT: First result: DWC receives the list of correct names but fails to show them correctly in all places.
            Manuel
            My Tool Collection
            • DIY-O-Sphereundefined
              DIY-O-Sphere @SIam
              @SIam
              I have named tools (not the fans) and the heaters are clickable.
              ~~I see it that way, the fan names are displayed In the graph and the tool names are displayed in the menu. And they can differ.
              Maybe the graph should also display tools and not fans.
              Edit: The fan names are only displayed when no tool names are defined.~~
              (UTC+1)
              remopiniundefined 1 Reply Last reply Reply Quote 0
              • remopiniundefined
                remopini @DIY-O-Sphere
                @DIY-O-Sphere It's not fans, it's heaters and showing tools instead of heaters in a temperature chart is a bad idea, because there isn't necessarily one heater for one tool (a tool could have 2 or more heaters or none).
                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                  DIY-O-Sphere @remopini
                  @remopini
                  You are right. Forget about my post.
                  I thought that are the fan names, but that is not correct. ace702ec-93cf-4618-8df5-8e403390ef69-grafik.png
                  Who can read is clearly at an advantage. 👎
                  (UTC+1)
                  • SIamundefined
                    SIam
                    maybe another bug :
                    on the page /Job/Status only one from two (*three) Fan's shown:
                    here you see two fan's are enabled
                    if i only disable the bauteilkühler then i get the message that there are no fans
                    on the main page i think it's ok *because the third fan is for the hotend
                    • chrishammundefined
                      chrishamm administrators
                      Can you please check if this is fixed in DWC 2.0.6?
                      Duet software engineer
                      • SIamundefined
                        SIam
                        yes it works with 2.0.6 thank you !
