Connecting an expansion board - duet 3
@jay_s_uk said in Connecting an expansion board - duet 3:
I have a phone cable with a 6 pin connector at each end and only the 2 middle wires connected. Can I use this to connect the expansion board?
Yes. It should really be twisted pair, which you can find sold as "ADSL high speed" or "ADSL high quality" cables. However, if the cable length is short, you can get away with non-twisted pair cables. The wiring is straight-through unless you have a Duet 3 v0.5 prototype board.
A good source of twisted pair RJ11 cables in the UK is https://www.kenable.co.uk/en/search?controller=search&search_query=adsl+high+speed.
@dc42 said in Connecting an expansion board - duet 3:
ADSL high speed
I have a 6 pin cable I bought https://www.jaycar.com.au/1m-rj12-6p-6c-extension-cable/p/YT6033, and connected my expansion board. However I get errors.
M569 Response timeout CANN addr 1 req type 6018 RID=0
M350 Response timeout CANN addr 1 req type 6021 RID=1
M906 Response timeout CANN addr 1 req type 6017 RID=2Any suggestions dc42?
@mattbaker said in Connecting an expansion board - duet 3:
look closely at the ends, are the colours in the same order? Telephone cables like to swap things up.
@bearer Looks like they are.
thats a bit ambiguous; they are the same or crossed over?
@bearer Not crossed
This is my config.g file
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Jan 23 2020 12:19:31 GMT+1100 (AEDT); General preferences
M550 P"Duet 3" ; set printer nameM667 S1 ; select CoreXY mode
M569 P0.0 S0 ; physical drive 0.0 goes forwards
M569 P0.1 S0 ; physical drive 0.1 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes backwards
M569 P0.3 S1
M569 P0.4 S1
M569 P0.5 S0 ; physical drive 0.5 goes forwards
M569 P1.0 S0 ; physical drive 1.0 goes forwardsM584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5:1.0 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E3000.00:3000.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1500 E500:500 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeoutM671 X480.00:230.00:-10.00 Y440.00:-30.00:440 S100
M208 X450 Y450 Z550 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io2.in; Z-Probe
M574 Z1 S2
M558 P5 C"io2.in" I1 H10 F200 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X40 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X40:440 Y40:440 S80 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F-1 ; define tool 0
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
Is the LED on the expansion board flashing in sync with the one on the main board? If so then the cable is ok.
Have you set the address switches on the expansion board to address 1?
@dc42 I tried changing the switches , but no joy. I'll have to check the lights in the morning. Which ones should I be looking at? Colour etc?
@mattbaker If set to 0, would the drive number be P0.6 etc?
The expansion board cannot be set to 0 in use (only to trigger a firmware update) in the configuration "0.n" refers to the mainboard.
There is red LED on the main that flashes at about 1Hz. There is also a red LED on the expansion board which should also flash in synchronisation with the LED on the main board.
@deckingman The red light on the board flashes quickly, faster than that of the duet 3.
Checked and adjusted the switches set to 1.
I have even bought some cat 5 and rj11 plugs, and a crimper.
Still get the same error messages
@mattbaker I'd say that you probably need to do a reset of the board and possibly flash the firmware but I'll leave @dc42 to talk you through that procedure and/or suggest something else.
If it's flashing continuously at about twice the speed of the main board, that means it isn't receiving CAN messages.
Only the two middle pins of the RJ11/RJ12 cables need to be connected. The colours must be in the same order at bot ends. Flat cables often have the colours reversed. Round cables normally don't and should be OK.
Make sure you have the two CAN termination jumpers fitted correctly on the expansion board.
Problem appears to be solved. I was using 6 pins, wired straight through. Then I read in another thread only the 4 middle were retired, I grabbed a 4 pin, and red lets flash in sync. And m122 b1 gives a response now.
However didn't realise using a 6 pin cable wouldn't work.
Thanks for your help.
I'm glad you got it working; but I think your 6-pin cable is faulty. The unused 4 pins on each CAN connector on the expansion board are connected to the same pins on the other connector, but not to anything else.
Dang... now i bought a short twisted adsl 2 cable for 6hc 1.0 and a 1.0 Extension Board.
I've to reorder a non twisted one now? -
@Flex3D
Twisted is fine. It's crossed that you don't want. As long as the colours are in the same order at each end you'll be fine -
@jay_s_uk thanks, so i'm fine with it. When i hold the endings together they are in the same order but twisted from one end to the other.
