    Duet Buddy - a proof of concept remote monitor
    85
    8.4k
    • zaptaundefined
      zapta @Danal
      Thanks Danal. I am currently using '/rr_status?type=3' but this can be configured in the M5Stack SD card config file to any url. Picked =3 because this is what my DWC keeps polling.
      Currently the response parser looks for these json fields:
      status, fractionPrinted, coords.xyz[2], temps.current[0] and temps.current[1]. If RRF3 has them then it work with no change. Otherwise, adding them to the parser should be easy.
      Response parser is straight forward and anybody make changes for RRF3 please send me a pull request.
      https://github.com/zapta/misc/blob/master/duet3d_buddy/arduino/duet_parser.cpp
      • bricorundefined
        bricor @zapta
        @zapta I just set one up. Fairly straight forward, Monitoring a print job as I'm typing this. I may have missed it, is there a way to program the buttons to pause or stop the current job or does it only monitor the printer (one way device)? Thank you, it's a neat little device.
        • zaptaundefined
          zapta @bricor
          @bricor, awesome!!!
          Currently the buttons are not used but shouldn't be too difficult for any with some programming experience to program them to do things, for example, sending gcode commands to the printer.
          Here is a challenge, the first person that will program a button to send any command to the duet will the respect of the community and an amazon gift card of $25 (e.g. for a spool of filament). Challenge closes April 30. Please report your success here and ping me.
          bricorundefined 1 Reply Last reply Reply Quote 3
          • bricorundefined
            bricor @zapta
            @zapta I really apprecite the effort. I could only imagine what it took to put this together. For me, it was a challenge to put the bits and pieces in place to go from plugging in the usb cable to having a functioning device. Not difficult, but a challenge. I hope to figure out what you did here and the whole c programming stuff. Need to be able to toggle between machines (ip addresses) as well
            • zaptaundefined
              zapta @bricor
              @bricor, I plan to look for ways to simplify the deployment for people that don't want to deal with Arduino. M5Stack has a software tool called M5Burner and another option is to use the esptool program directly. Need to figure those out or possibly somebody here can come with a simple recipe to 'burn' the Duet Buddy firmware.
              bricorundefined 1 Reply Last reply Reply Quote 0
              • bricorundefined
                bricor @zapta
                @zapta I should’ve said fun challenge. Rewarding type
                • richardmckennaundefined
                  richardmckenna
                  dammit!!! you guys have just made, nay, forced me to buy this!. Grrrrrr
                  M5Stack and Battery module on their way.
                  • tekkydaveundefined
                    tekkydave
                    I have one on order from Bangood. Ordered the Grey one at £29.53 as it has the motion sensor built in.
                    ~ tekkydave ~
                    D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                    FreeCAD, PrusaSlicer
                    jay_s_ukundefined richardmckennaundefined 2 Replies Last reply Reply Quote 0
                      jay_s_uk @tekkydave
                      I ordered the grey one too from aliexpress for £28.51.
                      Still waiting for it to get dispatched due to the "extended" chinese new year.
                      Sounds as though that won't happen till around the 18/02
                        richardmckenna @tekkydave
                        @tekkydave ah I went with this one https://www.amazon.co.uk/MakerHawk-Development-Bluetooth-Expandable-Compatible/dp/B07M71ZG6N which has the built in MPU9250 - £13 more but I get it tomorrow 🙂
                          jay_s_uk @richardmckenna
                          @richardmckenna thats the grey one
                          zaptaundefined 1 Reply Last reply Reply Quote 1
                          • zaptaundefined
                            zapta @jay_s_uk
                            The github repository has now a script to download the firmware to a M5Stack Core. For now it's only for windows but writing a similar shell script for Mac or Linux should be easy.
                            With this script, the Arduino IDE is not needed anymore (unless if you want to make code changes) and it just requires the Silicon Labs USB/Serial driver (available at m5stack.com and silabs.com).
                            https://github.com/zapta/misc/tree/master/duet3d_buddy/release
                            Please let me know howit works and feel free to send me pull requests.
                              tekkydave
                              It's arrived 🙂
                              ~ tekkydave ~
                              • hayseed_byteundefined
                                hayseed_byte @zapta
                                Very cool project!
                                Is there a way to do something similar but display the status of multiple printers on a computer monitor? Maybe with the use of a raspberry pi? I have nine printers that I'd like to monitor from another room but I don't want to buy nine of those. 😄
                                https://wildbot.me/wildbot
                                Gcode Definitions for VSCode extension: https://github.com/hayseedbyte/rrf-gcode-definitions
                                  Phaedrux Moderator @hayseed_byte
                                  @hayseed_byte Perhaps something like this?
                                  https://github.com/DanalEstes/MultiDuetWebMonitor
                                  hayseed_byteundefined 1 Reply Last reply Reply Quote 1
                                    hayseed_byte @Phaedrux
                                    @Phaedrux That's perfect. Thanks! Don't know how I haven't come across that.
                                    • Danalundefined
                                      Danal
                                      I've never tried it, but that should run just fine in a Pi browser. Let me know if it does not.
                                      PM here, or danal (dot) estes (at) gmail (dot) com
                                        richardmckenna
                                        @zapta any chance you could move the duet buddy code to its own repo? It would make it easier to fork without pulling all your other misc stuff as well 🙂
                                          richardmckenna
                                          I did something!
                                          I added a battery level indicator and the printer name. Strangely the M5Stack API only returns the battery level in increments of 25, not sure if there is a way to get round this by skipping the M5Stack API method and going straight to requesting it from the I2C. Will have to look into it more, but from what I can discern from the basic docs and the Chinese datasheet for the IP5306 it only returns 1 of 4 values depending on the voltage range.
                                          This is the current method in the API:
                                          // Return percentage * 100
                                          int8_t POWER::getBatteryLevel() {
                                            uint8_t data;
                                            if (M5.I2C.readByte(IP5306_ADDR, IP5306_REG_READ3, &data) == true) {
                                              switch (data & 0xF0) {
                                                case 0x00:
                                                  return 100;
                                                case 0x80:
                                                  return 75;
                                                case 0xC0:
                                                  return 50;
                                                case 0xE0:
                                                  return 25;
                                                default:
                                                  return 0;
                                            return -1;
                                          I also don't quite know what is happening with the switch statement and data & 0xF0but that's just my lack of C++ knowledge and IC programming. So if someone can educate me that would be great 😉
                                          I'm going to try adding the charging status as well for when it is plugged in and maybe tweak the layout a bit, then if someone can test it, I'll create a pull request to Zapta's original 🙂
                                          • zaptaundefined
                                            zapta @richardmckenna
                                            @richardmckenna, very nice!
                                            The IP5306 seems to have only 25% increments for the LEDs and possibly the IP5306_I2C has the same resolution but with I2C interface instead of LEDs. Hard to find information about the IP5306_I2C.
                                            M5Stack Schematic
                                            http://community.m5stack.com/assets/uploads/files/1515402963959-97994060-2969-49dc-ad9c-7b3887d95a17-image.png
                                            IP5306 (non I2C) Datasheet
                                            https://datasheet.lcsc.com/szlcsc/1809201029_INJOINIC-IP5306_C181692.pdf
                                            The expression (data & 0xF0) returns the 8 bit value of 'data' with the four right bits forces to '0'.
                                            BTW, the two temperature fields in your picture seems to have extra characters. Is it intentional?
                                            richardmckennaundefined 1 Reply Last reply Reply Quote 0
