    Help: Temp Sensors and Homing Issues
    6.8k
      It looks like you updated to reprapfirmware 3 without updating your config.g. Substantial changes are required for RRF3.
      You'll need to either redo your config files using the online configurator tool, or revert to 2.05.
      I think it would be best to stick with 2.05 until you have everything working before making the jump to RRF3.
      • 94118undefined
        94118
        Reflashed entire firmware to 2.05 cannot home my axis, Hotend thermistor still does not read as well as my bed still states -273 their is NO Shorts or loose wires with either of them.
        • 94118undefined
          94118
          [0_1581127980987_config.zip](Uploading 100%) here is a copy of my current config files. i need to control these files like simplfy 3d with my Flashforge creator (i.e. X to home right, Y to Home Back, and Z to raise the bed)
            zip files won't work. just copy and paste the contents.
            • 94118undefined
              94118
              I did do a copy and paste:
              z is grinding when in the home position which is Raised to 0. any news about fixing my temp sensors
              Phaedruxundefined 3 Replies Last reply Reply Quote 0
                Phaedrux Moderator @94118
                @94118 said in Help: Temp Sensors and Homing Issues:
                Copy and paste the contents of the files into a forum post.
                You've uploaded them earlier. Have they changed since then?
                  The issues presented seem like wiring issues. Are you using extension cables at all? Are the crimps good?
                    I'm not sure what that means. Raised by 0.
                    • 94118undefined
                      94118
                      my z axis is at the top of the printer hitting my z endstop and loud grinding this happens every time i home the z and have to trigger an emergency stop and reset. Wiring is solid All Crimps and Ferrells i can send a current pict.(https://drive.google.com/open?id=1C2ZJ8UMBzF1jl2yiAGesEVCoj4MjkdAC)
                        ; homeall.g
                        ; called to home all axes
                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 06 2020 14:52:27 GMT-0800 (Pacific Standard Time)
                        G1 H2 Z5 F6000          ; lift Z relative to current position
                        At the start of the homing files there is usually a Z move to lift the Z axis to get it out of the way for travel. perhaps this is what's running it into the endstop?
                        But if that's the case, then I think you have the direction of the Z motor incorrect, because that Z move should be moving the bed AWAY from the endstop, not into it.
                        • 94118undefined
                          94118
                          okay i just changed the direction of the drive from backward to forward in the
                          config.g
                          • 94118undefined
                            94118
                            BTW does anyone know how to wire an RGBW Led Strip to a duet
                              config.g
                              And did that fix it?
                              M126 S[fan_speed_pwm]
                              M140 S[bed0_temperature] P0
                              M134 P0                                 ; stabilize bed temperature
                              M104 S[extruder0_temperature] H1
                              M133 H1                                 ; stabilize extruder temperature
                              G130 X127 Y127 Z40 A127 B127            ; default stepper Vrefs A0 ; zero extruder
                              G1 Z0.4                                 ; position nozzle
                              G1 E25 F300                             ; purge nozzle
                              G1 X-115 Y-65 Z0.15 F1200               ; slow wipe
                              G1 X-110 Y-60 Z0.5 F1200                ; lift
                              G92 A0                                  ; zero extruder
                              Do you actually have all that as part of your config.g?
                              • 94118undefined
                                94118
                                Yes it is part of the Priming and Purge code for the hotend when it was on my FFC
                                • 94118undefined
                                  94118
                                  it was running Sailfish on a mightyboard and it worked
                                    Some of those gcodes aren't supported in reprapfirmware. (M134, M133, G130) And the extruder in RRF is E, not A and B.
                                    It would be best practice to not have heating and axis movement commands in config.g since it is executed at startup.
                                    • 94118undefined
                                      94118
                                      ok i will rework the config.g file
                                      • 94118undefined
                                        94118
                                        console.txt Temp sensors register via RRF Ver 3.0
                                        Please see the enclosed file for errors in motor phases.
                                        • 94118undefined
                                          94118
                                          Now i cannot update the firmware for the paneldue 5i BOSSA software does not see the panel in windows 10 drivers database. I now have a blank white screen. Still have not seen any replies about the homing issues cause DWC states when i command the home buttons it states Insufficient Axis Homing and also my heaters tend to fail when i run the auto tune command. I Need so advice please!
                                            Post your current config files please.
                                            For the PanelDue, did you have it detected at one point and it no longer detects? Try a different USB cable/port/pc.
                                            I assume you're using this for updating steps? https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                                            For the rgb leds take a look here: https://forum.duet3d.com/search?term=rgb&in=titlesposts
                                            What exactly is the homing problem currently? For the insufficient axis take a look at this and see if it matches your situation: https://duet3d.dozuki.com/Wiki/FAQ#Section_I_get_this_error_message_Error_G0_G1_insufficient_axes_homed
                                            What error do you get when you try and tune the heaters? What command are you using the tune them?
