Help: Temp Sensors and Homing Issues
zip files won't work. just copy and paste the contents.
I did do a copy and paste:
z is grinding when in the home position which is Raised to 0. any news about fixing my temp sensors -
@94118 said in Help: Temp Sensors and Homing Issues:
Copy and paste the contents of the files into a forum post.
You've uploaded them earlier. Have they changed since then?
The issues presented seem like wiring issues. Are you using extension cables at all? Are the crimps good?
I'm not sure what that means. Raised by 0.
my z axis is at the top of the printer hitting my z endstop and loud grinding this happens every time i home the z and have to trigger an emergency stop and reset. Wiring is solid All Crimps and Ferrells i can send a current pict.(https://drive.google.com/open?id=1C2ZJ8UMBzF1jl2yiAGesEVCoj4MjkdAC)
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 06 2020 14:52:27 GMT-0800 (Pacific Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position
At the start of the homing files there is usually a Z move to lift the Z axis to get it out of the way for travel. perhaps this is what's running it into the endstop?
But if that's the case, then I think you have the direction of the Z motor incorrect, because that Z move should be moving the bed AWAY from the endstop, not into it.
okay i just changed the direction of the drive from backward to forward in the
BTW does anyone know how to wire an RGBW Led Strip to a duet
And did that fix it?
M126 S[fan_speed_pwm] M140 S[bed0_temperature] P0 M134 P0 ; stabilize bed temperature M104 S[extruder0_temperature] H1 M133 H1 ; stabilize extruder temperature G130 X127 Y127 Z40 A127 B127 ; default stepper Vrefs A0 ; zero extruder G1 Z0.4 ; position nozzle G1 E25 F300 ; purge nozzle G1 X-115 Y-65 Z0.15 F1200 ; slow wipe G1 X-110 Y-60 Z0.5 F1200 ; lift G92 A0 ; zero extruder
Do you actually have all that as part of your config.g?
Yes it is part of the Priming and Purge code for the hotend when it was on my FFC
it was running Sailfish on a mightyboard and it worked
Some of those gcodes aren't supported in reprapfirmware. (M134, M133, G130) And the extruder in RRF is E, not A and B.
It would be best practice to not have heating and axis movement commands in config.g since it is executed at startup.
ok i will rework the config.g file
console.txt Temp sensors register via RRF Ver 3.0
Please see the enclosed file for errors in motor phases.
Now i cannot update the firmware for the paneldue 5i BOSSA software does not see the panel in windows 10 drivers database. I now have a blank white screen. Still have not seen any replies about the homing issues cause DWC states when i command the home buttons it states Insufficient Axis Homing and also my heaters tend to fail when i run the auto tune command. I Need so advice please!
Post your current config files please.
For the PanelDue, did you have it detected at one point and it no longer detects? Try a different USB cable/port/pc.
I assume you're using this for updating steps? https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
For the rgb leds take a look here: https://forum.duet3d.com/search?term=rgb&in=titlesposts
What exactly is the homing problem currently? For the insufficient axis take a look at this and see if it matches your situation: https://duet3d.dozuki.com/Wiki/FAQ#Section_I_get_this_error_message_Error_G0_G1_insufficient_axes_homed
What error do you get when you try and tune the heaters? What command are you using the tune them?
My Current Config File:
Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Feb 08 2020 14:13:05 GMT-0800 (Pacific Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Flashforge Creator" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes backwards M569 P1 S1 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X230 Y210 Z200 S0 ; set axis maxima ; Endstops M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y2 S0 P"ystop" ; configure active-low endstop for high end on Y via pin ystop M574 Z1 S0 P"zstop" ; configure active-low endstop for low end on Z via pin zstop ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S150 ; set temperature limit for heater 0 to 150C M307 H0 B0 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs1 M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S230 ; set temperature limit for heater 1 to 230C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
Auto tuning Failure Heaters did not reach peak temp after step 2
BOSSA Refuses to find my com port for the panel due i have tried different cables also knowing that it might be a connection issue Windows listed it as USB Generic Host but was not seen in BOOSA as a comm port.
I got my panel reflashed Successfully Still does not show reads from duet board
How is it connected?
