    Help: Temp Sensors and Homing Issues
    6.8k
      Please see the post from DC42 above. https://forum.duet3d.com/post/134957
      You need YAT connected via USB so that we can see if there is communication between the paneldue and the duet.
      • 94118undefined
        94118
        Direct from YAT: with Duet 2 plugged in to USB talking to Paneldue
        Debugging enabled for modules: GCodes(3)<LF>Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) LinuxInterface(16)<LF>
        NO (aux: M408)
        What next
          Phaedrux Moderator @dc42
          dc42 said in Help: Temp Sensors and Homing Issues:
          If you are using the ribbon cable, make sure it is plugged into the CONN_SD socket on the Duet. Not CONN_LCD.
          In your first picture it shows the PanelDue ribbon cable plugged into the wrong port. Are you still connected that way? Have you tried the 4 wire cabling option?
          https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
          • 94118undefined
            94118
            disconnected ribbon cable now it shows Idle And Temps
              So it's working now? Your responses are so short it's hard to know what's actually going on, which makes it very challenging to help you out.
              • 94118undefined
                94118
                I have and got it working by removing the ribbon cable. Now i think its my endstops conflicting with homing controls and commands (https://drive.google.com/open?id=1DxrsV36-5PN991DjbJJKdIKGP0n85crk) picture included status of endstops state Yes
                  If the endstop state says that it' triggered when it's not, then it's likely been defined incorrectly for the switch type.
                  I don't know what type of switches you have, or how the endstops have been defined in config.g.
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
                  It's likely a case of needing to change an S0 to S1 or vice versa.
                  • 94118undefined
                    94118
                    Mechanical ENdstops
                    • 94118undefined
                      94118
                      Homing still an issue Please review my config.g File i will Send config.g
                        Phaedrux Moderator @94118
                        @94118 said in Help: Temp Sensors and Homing Issues:
                        Mechanical ENdstops
                        Yes, but what kind of switch is it? Normally open, or normally closed? Do you have a picture of the switch?
                        M574 X1 S1 P"xstop"                            ; configure active-low endstop for low end on X via pin xstop
                        M574 Y2 S1 P"ystop"                            ; configure active-low endstop for high end on Y via pin ystop
                        M574 Z1 S1 P"zstop"                            ; configure active-low endstop for low end on Z via pin zstop
                        As I mentioned above, you may need to change the S1 to S0.
                        With RRF3 you need to use a ! to invert the signal, so try
                        M574 X1 S1 P"!xstop"                            ; configure active-low endstop for low end on X via pin xstop
                        M574 Y2 S1 P"!ystop"                            ; configure active-low endstop for high end on Y via pin ystop
                        M574 Z1 S1 P"!zstop"                            ; configure active-low endstop for low end on Z via pin zstop
                        • 94118undefined
                          94118
                          Just replaced Hotend heater and Thermistor did Heater auto tune and it was successful with New 24v 40W Heater Cart. and an NTC 3950 Stud Thermistor
                          ![alt text](25bd99b3-f082-4f96-bf4f-d83736da1234-image.png image url)
                          Features:
                          Using 22AWG cable, the copper inside is very thick, it is resistant to current 2A, voltage 300V.
                          The nonconductor has a wide range of temperatures, up to 80 centigrade.
                          It is not easy to be snapped and convenient to be plugged in and unplugged.
                          For convenience, the plug on the other side is integrated , you can use the plug directly.
                          Connection description:
                          1. Bed wire connect VCC (+ of ramps)
                          2. Black wire connect GND (- of ramps)
                          3. Green wire connect SIGNAL (s of ramps)
                          One set includes:
                          1. 1x endstop switch
                          2. 1x 3-pin 27.5inch cable
                          What is in the package:
                          2 set endstop switches for RAMPS 1.4
                            Yes those switches would likely need to be inverted. See my post above.
                            What firmware version are you running exactly? Send M115 and post the response.
                            • 94118undefined
                              94118
                              console (2).txt Results posted Fixed my Z and Changed my endstops to inverted with the Exclamation Fix Thanks
                                M500: Warning: No M501 command was executed in config.g
                                Don't forget to add M501 to the end of config.g or your tuned values won't be loaded at boot.
                                • 94118undefined
                                  94118
                                  Ouickie: Is their a way to disable and enable motors so that i may level my bed with my Boro glass.
                                    M84
                                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M84_Stop_idle_hold
                                    • 94118undefined
                                      94118
                                      When homing Z at the end of run Command it is hitting my nozzle causing my bed to tilt a few degrees
                                        Post your homing files.
                                        Is it using a probe, or an endstop?
                                        If the nozzle is hitting the bed before the endstop is triggered you'll need to move the endstop so that it gets triggered first. If it's hitting the endstop but not stopping you should test the endstop switch to see if it's triggering at all when pressed.
                                        • 94118undefined
                                          94118
                                          ; homey.g
                                          ; called to home the Y axis
                                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 15:06:37 GMT-0800 (Pacific Standard Time)
                                          G91 ; relative positioning
                                          G1 H1 Y215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                          G1 H2 Y-5 F6000 ; go back a few mm
                                          G1 H1 Y215 F360 ; move slowly to Y axis endstop once more (second pass)
                                          G1 H2 Z-5 F6000 ; lower Z again
                                          G90 ; absolute positioning; homex.g
                                          ; called to home the X axis
                                          G1 H1 X235 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 H2 X5 F6000 ; go back a few mm
                                          G1 H1 X235 F360 ; move slowly to X axis endstop once more (second pass)
                                          ; homez.g
                                          ; called to home the Z axis
                                          G1 H1 Z205 F1800 ; move Z up until the endstop is triggered
                                          G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                          ;G91 ; relative positioning
                                          ;G90 ; absolute positioning
                                          Z axis goes a few mm beyond my Z Endstop which forces my endstop to slightly be tilited up
                                          https://drive.google.com/open?id=1E3CcR-HoAqUtBcpq_rlf7GUoT6-3kfUs
                                          https://drive.google.com/open?id=1DyAeQrRzdj33uJVOVafkc-4hT0_O2bQ1
                                            And if you hit the endstop with your finger does the status change in the machine specific tab?
