    Help: Temp Sensors and Homing Issues
    6.8k
      Does the duet show up as a device in device manager?
      • 94118undefined
        94118
        NO it does not
          But you are able to connect to the duet via the network and DWC?
            When you connect the Duet via USB does it make the usb device detected sound?
              Have you followed this part of the getting connected guide?
              Have you installed the drivers?
              It also covers YAT.
              https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s5
              • 94118undefined
                94118
                Duet to the network Yes. Duet to USB NO Sound from windows. Unable to install duet drivers cause DM states not compatible with 64bit
                • 94118undefined
                  94118
                  Request an update for recent message about the paneldue
                  • 94118undefined
                    94118
                    Duet 2 wifi seems to good with USB but not the paneldue
                      Please see the post from DC42 above. https://forum.duet3d.com/post/134957
                      You need YAT connected via USB so that we can see if there is communication between the paneldue and the duet.
                      • 94118undefined
                        94118
                        Direct from YAT: with Duet 2 plugged in to USB talking to Paneldue
                        Debugging enabled for modules: GCodes(3)<LF>Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) LinuxInterface(16)<LF>
                        NO (aux: M408)
                        What next
                          Phaedrux Moderator @dc42
                          dc42 said in Help: Temp Sensors and Homing Issues:
                          If you are using the ribbon cable, make sure it is plugged into the CONN_SD socket on the Duet. Not CONN_LCD.
                          In your first picture it shows the PanelDue ribbon cable plugged into the wrong port. Are you still connected that way? Have you tried the 4 wire cabling option?
                          https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                          • 94118undefined
                            94118
                            disconnected ribbon cable now it shows Idle And Temps
                              So it's working now? Your responses are so short it's hard to know what's actually going on, which makes it very challenging to help you out.
                              • 94118undefined
                                94118
                                I have and got it working by removing the ribbon cable. Now i think its my endstops conflicting with homing controls and commands (https://drive.google.com/open?id=1DxrsV36-5PN991DjbJJKdIKGP0n85crk) picture included status of endstops state Yes
                                  If the endstop state says that it' triggered when it's not, then it's likely been defined incorrectly for the switch type.
                                  I don't know what type of switches you have, or how the endstops have been defined in config.g.
                                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
                                  It's likely a case of needing to change an S0 to S1 or vice versa.
                                  • 94118undefined
                                    94118
                                    Mechanical ENdstops
                                    • 94118undefined
                                      94118
                                      Homing still an issue Please review my config.g File i will Send config.g
                                        Phaedrux Moderator @94118
                                        @94118 said in Help: Temp Sensors and Homing Issues:
                                        Mechanical ENdstops
                                        Yes, but what kind of switch is it? Normally open, or normally closed? Do you have a picture of the switch?
                                        M574 X1 S1 P"xstop"                            ; configure active-low endstop for low end on X via pin xstop
                                        M574 Y2 S1 P"ystop"                            ; configure active-low endstop for high end on Y via pin ystop
                                        M574 Z1 S1 P"zstop"                            ; configure active-low endstop for low end on Z via pin zstop
                                        As I mentioned above, you may need to change the S1 to S0.
                                        With RRF3 you need to use a ! to invert the signal, so try
                                        M574 X1 S1 P"!xstop"                            ; configure active-low endstop for low end on X via pin xstop
                                        M574 Y2 S1 P"!ystop"                            ; configure active-low endstop for high end on Y via pin ystop
                                        M574 Z1 S1 P"!zstop"                            ; configure active-low endstop for low end on Z via pin zstop
                                        • 94118undefined
                                          94118
                                          Just replaced Hotend heater and Thermistor did Heater auto tune and it was successful with New 24v 40W Heater Cart. and an NTC 3950 Stud Thermistor
                                          ![alt text](25bd99b3-f082-4f96-bf4f-d83736da1234-image.png image url)
                                          Features:
                                          Using 22AWG cable, the copper inside is very thick, it is resistant to current 2A, voltage 300V.
                                          The nonconductor has a wide range of temperatures, up to 80 centigrade.
                                          It is not easy to be snapped and convenient to be plugged in and unplugged.
                                          For convenience, the plug on the other side is integrated , you can use the plug directly.
                                          Connection description:
                                          1. Bed wire connect VCC (+ of ramps)
                                          2. Black wire connect GND (- of ramps)
                                          3. Green wire connect SIGNAL (s of ramps)
                                          One set includes:
                                          1. 1x endstop switch
                                          2. 1x 3-pin 27.5inch cable
                                          What is in the package:
                                          2 set endstop switches for RAMPS 1.4
                                            Yes those switches would likely need to be inverted. See my post above.
                                            What firmware version are you running exactly? Send M115 and post the response.
