Help: Temp Sensors and Homing Issues
But you are able to connect to the duet via the network and DWC?
When you connect the Duet via USB does it make the usb device detected sound?
Have you followed this part of the getting connected guide?
Have you installed the drivers?
It also covers YAT.https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s5
Duet to the network Yes. Duet to USB NO Sound from windows. Unable to install duet drivers cause DM states not compatible with 64bit
Request an update for recent message about the paneldue
Duet 2 wifi seems to good with USB but not the paneldue
Please see the post from DC42 above. https://forum.duet3d.com/post/134957
You need YAT connected via USB so that we can see if there is communication between the paneldue and the duet.
Direct from YAT: with Duet 2 plugged in to USB talking to Paneldue
Debugging enabled for modules: GCodes(3)<LF>Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) LinuxInterface(16)<LF>
NO (aux: M408)
What next
dc42 said in Help: Temp Sensors and Homing Issues:
If you are using the ribbon cable, make sure it is plugged into the CONN_SD socket on the Duet. Not CONN_LCD.
In your first picture it shows the PanelDue ribbon cable plugged into the wrong port. Are you still connected that way? Have you tried the 4 wire cabling option?
disconnected ribbon cable now it shows Idle And Temps
So it's working now? Your responses are so short it's hard to know what's actually going on, which makes it very challenging to help you out.
I have and got it working by removing the ribbon cable. Now i think its my endstops conflicting with homing controls and commands (https://drive.google.com/open?id=1DxrsV36-5PN991DjbJJKdIKGP0n85crk) picture included status of endstops state Yes
If the endstop state says that it' triggered when it's not, then it's likely been defined incorrectly for the switch type.
I don't know what type of switches you have, or how the endstops have been defined in config.g.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
It's likely a case of needing to change an S0 to S1 or vice versa.
Mechanical ENdstops
Homing still an issue Please review my config.g File i will Send config.g
@94118 said in Help: Temp Sensors and Homing Issues:
Mechanical ENdstops
Yes, but what kind of switch is it? Normally open, or normally closed? Do you have a picture of the switch?
; Endstops M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-low endstop for high end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-low endstop for low end on Z via pin zstop
As I mentioned above, you may need to change the S1 to S0.With RRF3 you need to use a ! to invert the signal, so try
; Endstops M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
Just replaced Hotend heater and Thermistor did Heater auto tune and it was successful with New 24v 40W Heater Cart. and an NTC 3950 Stud Thermistor
Features:
Using 22AWG cable, the copper inside is very thick, it is resistant to current 2A, voltage 300V.
The nonconductor has a wide range of temperatures, up to 80 centigrade.
It is not easy to be snapped and convenient to be plugged in and unplugged.
For convenience, the plug on the other side is integrated , you can use the plug directly.Connection description:
- Bed wire connect VCC (+ of ramps)
- Black wire connect GND (- of ramps)
- Green wire connect SIGNAL (s of ramps)
One set includes:
- 1x endstop switch
- 1x 3-pin 27.5inch cable
What is in the package:
2 set endstop switches for RAMPS 1.4 -
Yes those switches would likely need to be inverted. See my post above.
What firmware version are you running exactly? Send M115 and post the response.
console (2).txt Results posted Fixed my Z and Changed my endstops to inverted with the Exclamation Fix Thanks
M500: Warning: No M501 command was executed in config.g
Don't forget to add M501 to the end of config.g or your tuned values won't be loaded at boot.
