    Help Core XY
    759
    • Davundefined
      Dav
      Hi
      I finished my corexy, I mad few prints and this is my result, who can help me to fix this kind of problem?
      This is my conf:
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
      M566 X600 Y600 Z60 E600 ; Maximum jerk in mm/min
      M203 X12000 Y12000 Z1200 E2500 ; set maximum speeds (mm/min)
      M201 X800 Y800 Z60 E1200 ; set accelerations (mm/s^2)
      M84 S30 ; Set idle timeoutWhatsApp Image 2020-03-03 at 20.00.07.jpeg WhatsApp Image 2020-03-03 at 20.00.07 (1).jpeg WhatsApp Image 2020-03-03 at 20.00.07 (2).jpeg
        Is your slicer changing your acceleration on you? The config values are pretty conservative, but the amount of ringing would indicate a very high acceleration or loose mechanics of some kind. Loose belts? Broken plastic part? Cheap stretchy belts?
        Davundefined 3 Replies Last reply Reply Quote 0
        • Davundefined
          Dav @Phaedrux
          @Phaedrux I'm using simplify 3d, I don't have special script.
          From simplify I print at 70mms.
          I don't know if can be the belts.
          I'm using 6mm belt, what do you suggest to buy?
          • Davundefined
            Dav @Phaedrux
            @Phaedrux this is a cube with the same configuration
            • Davundefined
              Dav @Phaedrux
              @Phaedrux do you suggest to change the 6mm belt with 9mm?
                deckingman @Dav
                @Dav 6mm belts are fine - 9mm won't cure your problems. What hot end and extrude are you using. How are they mounted? Is it Bowden or direct drive? Can you post some pictures of the printer.
                Davundefined 1 Reply Last reply Reply Quote 0
                • Davundefined
                  Dav @deckingman
                  @deckingman it's a sapphire plus printer, all mechanical parts are in metal, I changed the power supply with meanwell and motherboard with duet.
                  I use bowden configuration with bondtech.
                  At the moment the original parts are belt and e3d non original. 20200229_122921.jpg
                    Are you able to tension the belts?
                    Davundefined 2 Replies Last reply Reply Quote 0
                      deckingman @Dav
                      @Dav If you put a finger on the nozzle with the motors on and belts locked, can you move it back and forth or from left to right?
                      • Davundefined
                        Dav @Phaedrux
                        @Phaedrux I changed right now old belts with gates gt2 6mm,now I'm printing again same cube.
                        • Davundefined
                          Dav @deckingman
                          @deckingman no I can't
                          • Davundefined
                            Dav @Phaedrux
                            On the left old non original belts, on the right gt2 belts... Same result..
                            Do you have a profile for simplify or slic3r to test?
                              PrusaSlicer 2.2 RC config.csv
                              Rename it to config.ini. You'll need to change the nozzle size and extrusion width for your printer. I'm using 0.6mm nozzle.
                              If you disconnect the belts and move the print head around manually, does it feel smooth?
                              Are there any belt tensioners? Are both belts equally tensioned?
                              If you wiggle things around, is there anything that feels loose?
                              Are the belt teeth riding on toothed idlers or flat idlers?
                              • mrehorstdmdundefined
                                mrehorstdmd
                                If this is the same printer that was causing your Z axis problems, the belt layout is wrong for corexy and the belt tension is going to vary as the extruder moves around. That can easily lead to excessive ringing and the amount of it may vary depending on where the print sits on the bed. I suggest that you fix the belt path problem first, then tackle the print quality problems that remain.
                                  Phaedrux Moderator @mrehorstdmd
                                  @mrehorstdmd I don't think the diagram from the other thread is accurate to how the sapphire plus is actually laid out. At least not from any of the reviews I've seen of it. From what I gather it's a correctly designed corexy.
                                    mrehorstdmd @Phaedrux
                                    @Phaedrux It looks like the diagram came from an review of the Sapphire Plus and Sapphire Pro printers at All3DP. If that is a diagram supplied by 2Trees, it doesn't look good...
                                    • Davundefined
                                      Dav @Phaedrux
                                      @Phaedrux ok tried with your profile and I think is much better
                                      On the left your profile.
                                      I think there is something to change for jerk to optimise all edges.
                                      What do you think?
                                      Without belt x and y are very smooth, all mechanic I think is good and ok.
                                      Could you share your conf.g?
                                      • Stephen6309undefined
                                        Stephen6309
                                        This may help:
                                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M593_Configure_Dynamic_Acceleration_Adjustment
                                          Phaedrux Moderator @Dav
                                          @Dav said in Help Core XY:
                                          This isn't far off from my own config.g settings.
                                            It looks like it could be printed a bit hot. Do you know the thermistor settings for that hotend? Have you tried a temperature tower?
