    Dotstar questions?
    24
    2.3k
    • sibluesundefined
      siblues
      I would not even know where to start as far as coding goes. I just needed some lighting in order to check the prints while they are in progress and maybe for the camera lighting. I also wouldn't have minded maybe a color change to indicate print completion but it's no big deal maybe I will just use a simple on off set of single color LEDs for lighting.
      • frank26080115undefined
        frank26080115
        Since you got the DotStars already, it's a good thing to learn. They cost much more than plain RGB LED strips so I figured you got them for some fancy animations that required individual LED control. Go get an Arduino and practice a bit, there are plenty of example code for DotStars, including fancy animations. Check Adafruit's website, they'll have plenty of tutorials.
        For one idea, try programming your Arduino to be a I2C slave. When Duet starts or finishes a print, you can run a macro with the M260 code, then when the Arduino receives the I2C data, it can go into whatever color you want, white for printing, and maybe green for finished.
        Although if you are trying to save money, the better idea is probably just to use extra fan PWM signals for an ordinary dumb RGB LED strip. Save the DotStar strip for something that needs it (I made this last year https://eleccelerator.com/car-heads-up-display-using-led-strip/ )
        • sibluesundefined
          siblues
          I love that HUD you made that was a very cool idea.I will have the Dotstars handy for my next project.I must have almost 40 feet of leds here for my multirotors and other projects and I have tons of Teensy's and Nano's laying around so I am sure I will use them eventually.I guess I will pick up a set of 5v dumb led's for the simple on off set up I need.
            We have some code for driving DotStar LEDs. It's in the src/Fans subfolder of the RRF source. However, it's written to use a USART directly. For the Duet WiFi, it would be better to use the SharedSPI subsystem.
            In terms of hardware, the DotStar doesn't have a CS input. Therefore if you are sharing the SPI signals with other devices, you need to gate the clock signal. I would use a 74HCT02 as a driver for the DotStar. Use two of the gates in the package connected in series to level-shift the MOSI signal to 5V. Use the 3rd gate to invert the SCL signal, then use the 4th gate to gate the output of the 3rd gate with your chosen CS signal.
            I'd be happy to enable that code on in the standard build of RRF for the Duet WiFi, connected as described above.
            Caution: DotStar LEDs can take a lot of current, up to around 80mA per LED if you turn all of RGBW on. So you shouldn't use the 5V power output of the Duet to power more than about 15 of them.
            TKWARDundefined 1 Reply Last reply Reply Quote 0
            • sibluesundefined
              siblues
              I am still trying to grasp learning how to use the Duet which is a steep learning curve for me.The gates you are referring to and wiring them up correctly without frying something are probably a bit beyond my know how at the moment.I will probably stick to a strip of 5v white leds for simple on/off control in order to light the bed.
              • TKWARDundefined
                TKWARD @dc42
                David,
                Was this code ever implemented ?
                I presume connection is via the Therm Board connector ?
                I have a circuit diagram fleshed out based on your notes above ..... with CS jumpered to either CS1 through 4.
                The obvious caveat is that the thermocouple usage wold be limited to 2 max ?
                Also, what would the M150 command look like ? Eg .... for using CS3
                ( I have working discrete 24v LED driver strips working on other machines via the fan outputs .... I just fancy having a go at this.... maybe make a PCB if enough people are interested .... )
                Thanks
                Keith
                  dc42 administrators @TKWARD
                  @TKWARD said in Dotstar questions?:
                  Yes, in the standard firmware build for Duet 3. Not in the Duet 2 build. It could be added to the Duet 2 build but you would need some external gating and level shifting hardware to interface with the DotStar strip.
                  • TKWARDundefined
                    TKWARD
                    That's what I was alluding to. I can design a cheap pcb with the 74HCT02 and some connectors ( with a set of jumper to select an appropriate CS ).
                    Would the firmware changes be added just for this project ? Or, does it need to be added to the features 'wishlist' for Duet 2 firmware ?
                    I'll post a circuit diagram in the coming days for the potential design.
                    • TKWARDundefined
                      TKWARD @TKWARD
                      Will this work ?
                      Did you see my previous questions ?
                      Duet-LED-Driver.pdf
                      • TKWARDundefined
                        TKWARD @dc42
                        See replies below ...miss-tagged them ... there is a pdf with potential circuit diagram of addon board
                          I wouldn't use as much as 1000uF between Vcc and ground (100uF should be enough), but otherwise that should be OK. However, if you will be using a separate 5V supply to power the DotStar then you should take precautions against the Duet being powered but not the DotStar, or vice versa. A resistor of about 3K3 in series with each of Duet CS, SCLK and MOSI and the corresponding 74HCT02 connection should be sufficient.
                          Also the Duet and DotStar PSUs need a common ground, so it's probably best to link the grounds on that board.
                          • TKWARDundefined
                            TKWARD
                            @dc42 Thanks David.
                            The ground is definitely commoned.
                            I'll add the resistors as per your suggestion.
                            How would this be operated in terms of G code ? with M150 command ?
                            Also, assume that if a thermocouple board is used, only 2 of the CS would be available anyway ?
                            Thanks,
                            Keith
                              @dc42 Thanks David.
                              if you do ahead with this then I will enable DotStar support in RRF3. It will need a new configuration command (probably a variant of M150) to specify which CS line to use.
                              Yes.
                              Yes. So you might want to omit the jumper block and just wire it to use CS1. If you stack it on top of a daughter board then it would use CS3 instead automatically, because CS3 feeding into the daughter board is routed to the corresponding pin for CS1 on the top connector.
                              • TKWARDundefined
                                TKWARD
                                I'm going ahead with it.
                                Jumpers removed.
                                CS is set to CS_1.
                                Tank Capacitor value changed, and resistors added as per your suggestion.
                                Just waiting on an assembly price from Chinese supplier.
                                I'd like to send you a few boards to test with the firmware. ( Take this offline and get address etc via pm ?? )
                                Thanks
                                Keith
                                • nikschaundefined
                                  nikscha
                                  Any updates on the project so far? I'd be interested in the schematics for the board 🙂
                                  Stay in school
                                  • CanDo415undefined
                                    CanDo415
                                    Is it possible to skip some LEDs in the settings?
                                    Lets say LEDs 1-10 are set to different colors.
                                    I want to change LED2 without changing LED1.
                                      T3P3Tony administrators @CanDo415
                                      @cando415 no, just send the same setting again for the LEDS who do not change.
                                      • CanDo415undefined
                                        CanDo415
                                        can you store that info somewere? which LED should get what state?
                                          Phaedrux Moderator @CanDo415
                                          @cando415 said in Dotstar questions?:
                                          Possibly as a variable
                                          https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
                                          CanDo415undefined 2 Replies Last reply Reply Quote 1
                                          • CanDo415undefined
                                            CanDo415 @Phaedrux
                                            @phaedrux
                                            Oh! I have to upgrade my knolagebase!
                                            That makes it much better.
                                            Thx
