    Stall Guard
    1.4k
    • BlueDustundefined
      BlueDust
      I don't know if this is actually relevant, but I also read that this Stall Guard may need some fine tuning pointing to this formula sheet.
      I filled it out best to my understanding, but do not know how to use it.
      Fun, that 3 letter word with "u" in the middle.
        Do you have a link to that sheet?
        BlueDustundefined 1 Reply Last reply Reply Quote 0
          Have you tried getting it to detect a stall on a pure diagonal move to isolate just a single motor?
          • BlueDustundefined
            BlueDust @Phaedrux
            @Phaedrux
            There is a link on the Sensorless homing wiki page that takes you to another page to talk about motors. This site has a link to download the calculation sheet I shared the screen shot of.
            https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
            • BlueDustundefined
              BlueDust @Phaedrux
              @Phaedrux
              I just printed a large print with long movements and held the belts still.
              I can try printing a large calibration cube and see what happens.
                dc42 administrators @BlueDust
                @BlueDust said in Stall Guard:
                M915 X Y S-10 F0 H200 R3
                With S-10 I would expect the motor to register stalled nearly all the time. You can check by sending M122 during a print and looking at the driver status.
                On my delta I have M915 set to warn about motor stalls. Using the same M915 settings as when I test sensorless homing on that machine, I get occasional (false) warnings. So I know that it is working at least some of the time.
                • BlueDustundefined
                  BlueDust @dc42
                  I have been having a lot of trouble with the nozzle getting stuck in the print, and breaking different Z probes and why I want to fix this feature. I am having a lot of Z probe issues again caused by the crashes and not able to bed level. I will run m122 after I can print again.
                  Thanks
                    I have this on my list to look at, but I need to get firmware 3.01-RC3 released first. Please remind me again on Monday, assuming 3.01-RC3 is released by then.
                    • BlueDustundefined
                      BlueDust
                      @dc42 said in Stall Guard:
                      M122
                      As I do use stall guard for homing, I wanted to compare both before and after I enabled it for printing...
                      This is before I enabled stall guard (printing)
                      M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet Ethernet 1.02 or later + DueX5
                      Board ID: 08DGM-9T6BU-FG3S0-7JTDL-3SN6N-TS6VG
                      Used output buffers: 3 of 24 (24 max)
                      Static ram: 25712
                      Dynamic ram: 93836 of which 0 recycled
                      Exception stack ram used: 656
                      Never used ram: 10868
                      Tasks: NETWORK(ready,628) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,1300) IDLE(ready,160)
                      Owned mutexes:
                      Last reset 70:56:51 ago, cause: software
                      Last software reset at 2020-02-28 21:23, reason: User, spinning module GCodes, available RAM 11240 bytes (slot 2)
                      Error status: c
                      Free file entries: 8
                      SD card longest block write time: 17.0ms, max retries 1
                      MCU temperature: min 33.7, current 36.2, max 39.4
                      Supply voltage: min 23.5, current 23.8, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: ok, SG min/max 0/201
                      Driver 1: ok, SG min/max 0/205
                      Driver 3: ok, SG min/max 0/1023
                      Driver 5: standstill, SG min/max not available
                      Driver 6: standstill, SG min/max not available
                      Driver 7: standstill, SG min/max 0/1023
                      Driver 8: standstill, SG min/max 0/1023
                      Driver 9: standstill, SG min/max 0/1023
                      Date/time: 2020-03-02 20:20:51
                      Slowest loop: 261.76ms; fastest: 0.08ms
                      Hiccups: 0, FreeDm: 157, MinFreeDm: 132, MaxWait: 21532997ms
                      === DDARing ===
                      Scheduled moves: 189, completed moves: 165, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      Heater 0 is on, I-accum = 0.2
                      Heater 1 is on, I-accum = 0.3
                      Segments left: 1
                      Stack records: 3 allocated, 0 in use
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is doing "G1 X170.351 Y213.116 E12.2842" in state(s) 0
                      serial is idle in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 372.96ms; fastest: 0.05ms
                      HTTP sessions: 1 of 8
                      Interface state 5, link 100Mbps full duplex
                      === Filament sensors ===
                      Extruder 0: pos 280.55, errs: frame 164 parity 0 ovrun 0 pol 5 ovdue 0
                      This is just what I had used to enable it this time...
                      M915 X Y S3 F1 H100 R3
                      Same print as above Diagnostic text. I just ran the M915 command mentioned above, printer rehomed itself, and I copied the M122 Diagnostic text.
                      M122
                      Used output buffers: 1 of 24 (24 max)
                      Static ram: 25712
                      Owned mutexes:
                      Last reset 71:04:28 ago, cause: software
                      Error status: c
                      MCU temperature: min 38.3, current 38.9, max 39.2
                      Supply voltage: min 23.7, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: ok, SG min/max 79/192
                      Driver 1: ok, SG min/max 80/184
                      Driver 7: standstill, SG min/max not available
                      Date/time: 2020-03-02 20:28:27
                      Slowest loop: 3.33ms; fastest: 0.09ms
                      Hiccups: 0, FreeDm: 142, MinFreeDm: 128, MaxWait: 0ms
                      === DDARing ===
                      Scheduled moves: 4941, completed moves: 4905, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      Segments left: 1
                      file is doing "G1 X208.678 Y124.970 E0.4618" in state(s) 0
                      === Network ===
                      Slowest loop: 6.89ms; fastest: 0.05ms
                      Extruder 0: pos 280.20, errs: frame 164 parity 0 ovrun 0 pol 5 ovdue 0
                      • BlueDustundefined
                        BlueDust @dc42
                        I know I am a little late with this... Reminder. 🙂
                        As always, Thank you for your help!
                          @BlueDust, have you tried RRF3 yet? That's where development is now focused.
                          • BlueDustundefined
                            BlueDust @dc42
                            No. I wanted to wait until there was an official release and not just an RC. Also after I got this working... That way I didn't have to troubleshoot with new code.
                            I may have the time to work on the conversation to RRF3 next weekend... I will follow up again after I upgrade the software and try this again.
