    Another Predator
    204
    14.7k
    • Cabaretundefined
      Cabaret
      I would prefer switching to firmware 2.05.1.
      Carloundefined 1 Reply Last reply Reply Quote 0
        jay_s_uk @Carlo
        @Carlo
        I found it would lose its ability to let plastic stick to it.
        I now have a removable print surface and it works very well
        • Carloundefined
          Carlo @Cabaret
          @Cabaret
          I have tried that particular flavor with no change.
          Cheers
          • Carloundefined
            Carlo @jay_s_uk
            @jay_s_uk
            Ah odd never had an issue with them my ender won't let go until I hear the crackling.
            • Carloundefined
              Carlo @Carlo
              @Carlo
              OK so I tried again now I mentioned that the motion is odd and it will accelerate mid print move the below image
              illustrates this everywhere the print has gaps is an acceleration or travel when it should be extruding its travelling mid
              print.
              That's Odd right ?
              Single probe before print no mesh enabled.
              Initial layer is 40mm/s
              Thoughts?
              • Carloundefined
                Carlo
                Is it worth doing a wipe of the firmware and start again? as I mentioned this thing doesn't know what its doing
                when I do a delta calibration it probes at varying speeds across the bed really fast double tap moves and does a really slow double tap then slow then randomly mixes it up also the end stops are suddenly as much as -10mm + 7mm off
                Or is it time to just write the board off?
                Cheers
                Carlo
                  You can upload the 2.05 zip file and it will update everything to that version. Worth a shot.
                  Would it be possible to post a video of the behaviour you're describing?
                  Carloundefined 2 Replies Last reply Reply Quote 0
                  • Carloundefined
                    Carlo @Phaedrux
                    @Phaedrux
                    I'll try that version have tried 2.0.5.1 already ...once I've updated I'll upload a video in the hope that the video I upload is of it printing.
                    Appreciate the help.
                      It looks as though it is starting the print a little high. So try setting the trigger height (G31 Z parameter) a little less negative, for example -0.05 instead of -0.12.
                      • Carloundefined
                        Carlo @Phaedrux
                        @Phaedrux
                        I've done the backdate to 2.0.5 as suggested and now I don't seem to have odd movement don't get me wrong it's still not printing and the endstops are way off still..but now I've noticed and this is new the smart effector light is flashing constantly while stationary ...not every second or 2 seconds but randomly all the time ,interference ?
                          dc42 administrators @Carlo
                          @Carlo said in Another Predator:
                          @Phaedrux
                          That suggests either a bad connection to the 8-way connector, or interference from the fan. Does it still flash with the fans turned off?
                          • Carloundefined
                            Carlo @dc42
                            I'll try that now
                            Thanks for your help
                            • Carloundefined
                              Carlo @dc42
                              No just unplugged and it has stopped plugged back in and not flashing that must be a poor connection on the fan?
                              I'll change it now to fair I have had this apart once or twice.
                              Sorry I've changed my setting back to 2.0.5 could someone please have quick check of my configs as I've homed again and it's showing homed height way off but end stops fine,
                              Also Heater 1 is missing so figure I've missed something though it works
                              ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
                              ; Delta Settings
                              M665 L440.470:440.470:440.470 R232.088 H420.498 B185.0 X0.237 Y-0.015 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
                              M666 X-0.09 Y0.10 Z-0.01 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
                              M550 P"Street Predator" ; Set machine name
                              M551 P"" ; Set password
                              M552 P192.168.0.25 S1 ; Enable network and acquire dynamic address via DHCP
                              M586 P0 S1 ; Enable HTTP
                              M586 P1 S0 ; Disable FTP
                              M586 P2 S0 ; Disable Telnet
                              M569 P3 S0 ; Drive 3 goes backwards
                              M584 X0 Y1 Z2 E3:4:1.0:1.1
                              M92 X80.00 Y80.00 Z80.00 E867 ; Set steps per mm
                              M566 X3000 Y3000 Z3000 E40 ; Set maximum instantaneous speed changes (mm/min)
                              M203 X12000.00 Y12000.00 Z12000.00 E446 ; Set maximum speeds (mm/min)
                              M201 X9000.00 Y9000.00 Z9000.00 E9000.00 ; Set accelerations (mm/s^2)
                              M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              ; Retraction
                              M207 S0.4 F1200 R0.1 T1200 Z0.2 ; Firmware retraction
                              M208 Z0 S1 ; Set minimum Z
                              M574 X1 Y1 Z1 U1 S1 ; active high endstop switches, XYZ U at max
                              M558 P8 R0.4 F1200 H20 T2000 C"zprobe.in+zprobe.mod" ; Set Z probe type to switch and the dive height + speeds
                              G31 P100 X0 Y0 Z-0.05 ; Set Z probe trigger value, offset and trigger height
                              M557 R135 S16 ; Define mesh grid
                              ;Heated bed
                              M305 P0 T100000 B3950 ; bed heater uses a B3950 thermistor ; Disable bang-bang mode for the bed heater and set PWM limit
                              M143 P0 S125 ; Set temperature limit for heater 0 to 120C
                              ;Hotend
                              M305 P1 S"T0" X200 R395 W2 ; configure sensor 1 as PT100 on daughter board
                              M143 P1 S400 ; set temperature limit for heater 1 to 400C
                              M307 P1 B0 S1.00
                              M950 F0 Cfan0 Q500 ; create fan 0 on pin fan0 and set its frequency
                              M950 F1 Cfan1 Q500 ; create fan 1 on pin fan1 and set its frequency
                              M563 P0 D0 H1 ; Define tool 0
                              M591 P3 C3 S1 ; filament monitor connected to E0_stop
                              M404 N1.75 D0.4 ; Set for print monitor
                              M501 ; Load saved parameters from non-volatile memory
                              ; config-override.g file generated in response to M500 at 2020-03-15 13:17
                              ; Delta parameters
                              M665 L440.470:440.470:440.470 R232.163 H421.126 B185.0 X0.095 Y0.043 Z0.000
                              M666 X-2.720 Y-0.764 Z3.484 A0.00 B0.00
                              ; Heater model parameters
                              M307 H0 A113.4 C472.3 D0.6 S1.00 V23.8 B0
                              M307 H1 A655.5 C296.8 D4.5 S1.00 V24.0 B0
                              M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              G10 L2 P1 X0.00 Y0.00 Z0.00
                              G10 L2 P2 X0.00 Y0.00 Z0.00
                              G10 L2 P3 X0.00 Y0.00 Z0.00
                              G10 L2 P4 X0.00 Y0.00 Z0.00
                              G10 L2 P5 X0.00 Y0.00 Z0.00
                              G10 L2 P6 X0.00 Y0.00 Z0.00
                              G10 L2 P7 X0.00 Y0.00 Z0.00
                              G10 L2 P8 X0.00 Y0.00 Z0.00
                              G10 L2 P9 X0.00 Y0.00 Z0.00
                                The config files between 2.x and 3.x are not compatible. If you want to switch back to 2.x you'll have to use a backup of your config file, or if you don't have one, you might have to recreate one using the web configurator tool.
                                • Carloundefined
                                  Carlo @Phaedrux
                                  @Phaedrux
                                  I have switched the settings back all seems to be working except I get a homed error as per the picture above
                                  and the Heater 1 is missing so I can't activate or switch off via it.
                                  Actually the homed error is only if I M500 and have a config overide file if I delete that it shows what I assume is correct home height.
                                  Thanks for your help.
                                    Your config still has a lot of commands specific to 3.0.
                                    In the gcode console send M98 Pconfig.g and report back with any errors that come up.
                                    • Carloundefined
                                      Carlo @Phaedrux
                                      @Phaedrux
                                      It reported 2 fan command not supported which I corrected with M106 now only no config override but I deleted it.
                                        What do you mean by heater1 is missing?
                                        • Carloundefined
                                          Carlo @Phaedrux
                                          @Phaedrux
                                          If you look at the above screen shot its missing Heater 1 from Tools .
                                          Thanks
                                            Phaedrux Moderator @Carlo
                                            ;Hotend
                                            Your R value looks to be missing a 0.
