    Another Predator
    204
    14.7k
    • Carloundefined
      Carlo @droftarts
      @droftarts
      Hi Ian,
      I used the original effector with the mag arms (printed the adapters) whats funny is I didn't even try to get anything level or square I literally slapped it together set the offset 1 level and it just worked.
      I have the effector still wired I can carefully attach it to the Duet2 and try it i cant fit the effector to the other board it's locked down
      but I've written this thing off now I don't expect this to ever work with duet but after spending all this time I do want to know whats wrong maybe it will help someone else some day...probably not
      I post a video of it once its fitted
      Thanks
      C
      • Carloundefined
        Carlo @NexxCat
        @NexxCat
        I'll do that now.
        Cheers
        C
        • Carloundefined
          Carlo @NexxCat
          @NexxCat
          Hi NexxCat,
          No its 0.1mm to high
          NexxCatundefined 1 Reply Last reply Reply Quote 0
          • NexxCatundefined
            NexxCat @Carlo
            @Carlo
            What is your current Z probe offset?
            Carloundefined 1 Reply Last reply Reply Quote 0
            • Carloundefined
              Carlo @NexxCat
              @NexxCat
              G31 P100 X0 Y0 Z-0.159
              • NexxCatundefined
                NexxCat @Carlo
                @Carlo
                I can't remember offhand which way to adjust the offset to bring it closer, but try both of these, one will certainly be too high, but the other, does that give you a 0.1mm gap when running the macro I posted?
                G31 P100 X0 Y0 Z-0.059
                G31 P100 X0 Y0 Z-0.259
                Carloundefined 1 Reply Last reply Reply Quote 1
                • Carloundefined
                  Carlo @NexxCat
                  @NexxCat
                  They have all been tried
                  it's 0.05 to bring it closer dc42 suggested 0.05 so I've tried all the -0. possible infact the video I posted is -0.05
                  • NexxCatundefined
                    NexxCat @Carlo
                    @Carlo
                    I know you've tried them whilst printing, but try -0.059 and run the macro. Is the gap 0.1mm?
                    • Carloundefined
                      Carlo @NexxCat
                      @NexxCat
                      Doing it now
                      Bang on
                      • NexxCatundefined
                        NexxCat @Carlo
                        @Carlo
                        So with -0.059, the gap is exactly 0.1mm after running the macro I posted. Correct?
                        • Carloundefined
                          Carlo @NexxCat
                          @NexxCat
                          Yes spot on 0.1mm
                          • NexxCatundefined
                            NexxCat @Carlo
                            @Carlo
                            Ok, set that in your config. Then create the bed mesh with G29 S0. Once the mesh is complete, try to print the levelling model.
                            I know you've done this so many times before, but let's try now we know the nozzle positioning is correct ok? Use the level_test.gcode I have you before, because I know it doesn't have anything in it to mess with the settings.
                            Carloundefined 3 Replies Last reply Reply Quote 1
                            • Carloundefined
                              Carlo @NexxCat
                              @NexxCat
                              Will do that now
                              Thanks
                              C
                              • Carloundefined
                                Carlo @NexxCat
                                @NexxCat
                                It failed but it's too close to the bed just I think but its the best its ever looked.
                                • NexxCatundefined
                                  NexxCat @Carlo
                                  @Carlo
                                  So it was sticking but not extruding because it was too close? Try changing the offset to say -0.1?
                                  • Carloundefined
                                    Carlo @NexxCat
                                    @NexxCat
                                    Sorry been having net issues i'll adjust it 0.01 increments see if it works better.
                                    It was extruding and really sticking but as it did the next pass it was squishing too hard almost transparent and curling up at the outer edges indented in the middle as it cooled
                                    Thanks
                                    C
                                    • Carloundefined
                                      Carlo @NexxCat
                                      @NexxCat
                                      Hi NexxCat,
                                      Can I ask is Z hop enabled in the bed level test file you kindly sliced for me ?
                                      Or is that controlled via config.g ? ...so print files call M207: Retraction if Z hop is set on M207 in config.g Z hop is invoked on all Retractions ?
                                      Thanks
                                      C
                                      Phaedruxundefined NexxCatundefined 2 Replies Last reply Reply Quote 0
                                        droftarts administrators @Carlo
                                        @Carlo said in Another Predator:
                                        This makes it sound like the first layer printed fine, but when printing the second layer it was too close, ie it didn't move correctly/far enough in Z. This made me think either you Z jerk or acceleration is too high, or your steps per mm are wrong (which would explain a lot!). I haven’t found the standard Marlin config for the Anycubic Predator, but did find https://github.com/halofx/Marlin-2.0-Predator/blob/master/Marlin/Configuration.h
                                        Steps per mm on each axis are 80, for standard 1.8 degree motors. You haven’t changed yours for 0.9 degree, have you?
                                        I haven’t been through the Marlin config for acceleration and jerk settings, as on phone with tiny screen! But would be worth checking. Just remember Marlin specifies speeds in mm/sec, RRF in mm/min. If you have the Marlin configuration.h you’re running on your standard board, even better; please post it.
                                          Phaedrux Moderator @Carlo
                                          Firmware retraction must be enabled in the slicer. That will replace any G1 E-# moves with a G10/G11 to retract and unretract. The config.g must then contain an M207 command to tell the firmware how much and how fast to unretract. Zhop can be added in the slicer and or firmware retraction command.
                                          If you don't have an M207 command in your config.g then nothing will happen when a G10/G11 is encountered in the gcode file.
                                          If you look at the gcode file itself you should be able to tell by looking for G10/G11.
                                          • Carloundefined
                                            Carlo @droftarts
                                            @droftarts
                                            Hi Ian,
                                            No they are set to 80 ...this is a Gorrila board which as far as I know is chit-tu based ? so M500 is like M8500 and not sure all the commands for it are known and the board is locked down... again as far as I know.
                                            I wish it was set wrong...NexxCat was kind enough to have sliced the test file for me and it's very close so just using that to adjust trigger height..
                                            it's really close but the Z hop seems to be an issue.
                                            Thanks
                                            C
