    Another Predator
    204
    14.6k
    • Carloundefined
      Carlo @Phaedrux
      @Phaedrux
      Hiya,
      Yeah both H0/H1 have and they are in the config.
      I'm calling it now..... I'm done off to research a replacement.
      Really appreciate all the help from everyone big THANK YOU!
      • NexxCatundefined
        NexxCat @Carlo
        @Carlo
        Did you use a single sheet of paper when it asked, just regular printer paper? Alternatively, if you have some feeler gauges, you can use a 0.10mm gauge.
        Carloundefined 2 Replies Last reply Reply Quote 0
          droftarts administrators @Carlo
          @Carlo From my earlier post: When you swapped the original board back in, did you also put the original effector back on, or did it use the smart effector? If you used the original effector (and presumably original probe), can you try that with the Duet? This would at least narrow down if it's the effector or the Duet.
          Carloundefined 1 Reply Last reply Reply Quote 0
          • Carloundefined
            Carlo @NexxCat
            @NexxCat
            Hi NexxCat
            I used the back off a sticker which is 0.1mm on my calipers.
            Just found my gauges !
            Thanks
            • Carloundefined
              Carlo @NexxCat
              @NexxCat
              So I used the well 0.102 feeler gauge though it is .10 with my calipers and 3 times got 3 heights.
              I did video the whole process but that won't help me
              The numbers don't actually help because they are not accurate though one of them is:
              M98 P"0:/macros/Z probe report"
              Z probe trigger height set to -0.159 mm
              I don't think it's the effector because it does what it is supposed to do and no matter what trigger height I put in G31 line its the same outcome and the effector does return the same probe heights all be it not one after the other 🙂
              maybe the drivers are not calculating correctly I don't know but it is what it is and that is not usable.
              Cheers for your help.
              C
              NexxCatundefined 1 Reply Last reply Reply Quote 0
              • NexxCatundefined
                NexxCat @Carlo
                @Carlo
                Ok, last thing I can think of, just to double check if the actual positioning is being repeatable. Run these commands one at a time, or save it as a macro:
                ; Disable any baby-stepping and the bed mesh
                M290 R0 S0
                G29 S2
                ; Home the effector
                G28
                ; Heat bed to 60C & nozzle to 130C
                M104 S130 T0
                M190 S60 T0
                M109 S130 T0
                ; Run delta calibration
                G32
                ; Move the effector to 0,0,Max height
                G1 X0 Y0 F4500
                G1 Z500 F4500
                ; Move the effector back to 10mm off the bed
                G1 Z10 F4500
                ; Slowly move down to 0.1mm
                G1 Z0.1 F600
                When the macro is finished, the nozzle is at 0.1 on the Z axis. Use the paper or a 0.1mm feeler gauge and see if the nozzle truly is at 0.1mm
                Carloundefined 2 Replies Last reply Reply Quote 1
                • Carloundefined
                  Carlo @droftarts
                  @droftarts
                  Hi Ian,
                  I used the original effector with the mag arms (printed the adapters) whats funny is I didn't even try to get anything level or square I literally slapped it together set the offset 1 level and it just worked.
                  I have the effector still wired I can carefully attach it to the Duet2 and try it i cant fit the effector to the other board it's locked down
                  but I've written this thing off now I don't expect this to ever work with duet but after spending all this time I do want to know whats wrong maybe it will help someone else some day...probably not
                  I post a video of it once its fitted
                  Thanks
                  C
                  • Carloundefined
                    Carlo @NexxCat
                    @NexxCat
                    I'll do that now.
                    Cheers
                    C
                    • Carloundefined
                      Carlo @NexxCat
                      @NexxCat
                      Hi NexxCat,
                      No its 0.1mm to high
                      • NexxCatundefined
                        NexxCat @Carlo
                        @Carlo
                        What is your current Z probe offset?
                        • Carloundefined
                          Carlo @NexxCat
                          @NexxCat
                          G31 P100 X0 Y0 Z-0.159
                          • NexxCatundefined
                            NexxCat @Carlo
                            @Carlo
                            I can't remember offhand which way to adjust the offset to bring it closer, but try both of these, one will certainly be too high, but the other, does that give you a 0.1mm gap when running the macro I posted?
                            G31 P100 X0 Y0 Z-0.059
                            G31 P100 X0 Y0 Z-0.259
                            Carloundefined 1 Reply Last reply Reply Quote 1
                            • Carloundefined
                              Carlo @NexxCat
                              @NexxCat
                              They have all been tried
                              it's 0.05 to bring it closer dc42 suggested 0.05 so I've tried all the -0. possible infact the video I posted is -0.05
                              • NexxCatundefined
                                NexxCat @Carlo
                                @Carlo
                                I know you've tried them whilst printing, but try -0.059 and run the macro. Is the gap 0.1mm?
                                • Carloundefined
                                  Carlo @NexxCat
                                  @NexxCat
                                  Doing it now
                                  Bang on
                                  • NexxCatundefined
                                    NexxCat @Carlo
                                    @Carlo
                                    So with -0.059, the gap is exactly 0.1mm after running the macro I posted. Correct?
                                    • Carloundefined
                                      Carlo @NexxCat
                                      @NexxCat
                                      Yes spot on 0.1mm
                                      • NexxCatundefined
                                        NexxCat @Carlo
                                        @Carlo
                                        Ok, set that in your config. Then create the bed mesh with G29 S0. Once the mesh is complete, try to print the levelling model.
                                        I know you've done this so many times before, but let's try now we know the nozzle positioning is correct ok? Use the level_test.gcode I have you before, because I know it doesn't have anything in it to mess with the settings.
                                        Carloundefined 3 Replies Last reply Reply Quote 1
                                        • Carloundefined
                                          Carlo @NexxCat
                                          @NexxCat
                                          Will do that now
                                          Thanks
                                          C
                                          • Carloundefined
                                            Carlo @NexxCat
                                            @NexxCat
                                            It failed but it's too close to the bed just I think but its the best its ever looked.
