    Cambio elettronica
    124
    6.4k
    • Leblondundefined
      Leblond
      no la stampante vista da "davanti", X si ferma a sx dove posizionato il finecorsa, Y si ferma davanti dove posizionato il finecorsa
      • Leblondundefined
        Leblond
        ti mando schizzo
        • Leblondundefined
          Leblond
            Phaedrux Moderator @Leblond
            @Leblond said in Cambio elettronica:
            no the printer seen from "front", X stops on the left where the limit switch is positioned, Y stops in front where the limit switch is positioned
            Ok, go back to my post above: https://forum.duet3d.com/post/142912
            You've managed to change the configuration to force it to work, but it's not working properly.
            If the endstops are on the low end it must be M574 X1 Y1.
            This also means the homing moves must be negative.
            If the motors do not move the right direction at this point you must do these tests to correct the motor rotation:
            https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
            • Leblondundefined
              Leblond
              ok guardo
              • Leblondundefined
                Leblond
                quindi quando si parla di parte bassa si intende il davanti della stampante e parte alta il dietro, giusto?
                ho riportato i valori su S1 ma si spostano di pochi cm. e mi da errore, quindi presumo che bisogna far girare i motori al contrario?
                • Leblondundefined
                  Leblond
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT+0200 (Ora legale dell’Europa centrale)
                  M550 P"X5SA PRO" ; set printer name
                  M669 K1 ; select CoreXY mode
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P0 S1 ; physical drive 0 goes backwards
                  M569 P1 S1 ; physical drive 1 goes backwards
                  M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
                  M203 X6000.00 Y6000.00 Z100.00 E1200.00 ; set maximum speeds (mm/min)
                  M84 S30 ; Set idle timeout
                  M208 X-5 Y0 Z0 S1 ; set axis minima
                  M208 X352 Y330 Z400 S0 ; set axis maxima
                  M574 X1 S1 P"! xstop" ; configure active-high endstop for low end on X via pin xstop
                  M574 Y1 S1 P"! ystop" ; configure active-high endstop for low end on Y via pin ystop
                  M558 P5 C"! zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                  M557 X60:300 Y50:300 S20 ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                  • Leblondundefined
                    Leblond
                    non funziona
                    • Leblondundefined
                      Leblond
                      siamo ritornati al punto di partenza quando non andava
                        Correct.
                        when we talk about the lower part we mean the front of the printer and the upper part the back, right?
                        Correct.
                        M208 X-5 Y0 Z0 S1; minimum axis set
                        M208 X352 Y330 Z400 S0; set axis maxima
                        M574 X1 S1 P "! Xstop"; configure active-high endstop for low end on X via pin xstop
                        M574 Y1 S1 P "! ystop"; configure active-high endstop for low end on Y via pin ystop
                        M574 Z1 S2; configure Z-probe endstop for low end on Z
                        Correct.
                        ; homeall.g
                        ; called to home all axes
                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 16:46:31 GMT + 0200 (Central European
                        Summer Time) G91; relative positioning
                        G1 H2 Z5 F6000; lift Z relative to current position
                        G1 H1 X-335 Y-335 F1800; move quickly to X or Y endstop and stop there (first pass)
                        G1 H1 X-335; home X axis
                        G1 H1 Y-335; home Y axis
                        G1 X5 Y5 F6000; go back a few mm
                        G1 H1 X-335 F360; move slowly to X axis endstop once more (second pass)
                        G1 H1 Y-335; then move slowly to Y axis endstop
                        G90; absolute positioning
                        G1 X60 Y50 F6000; go to first bed probe point and home Z
                        G30; home Z by probing the bed
                        Correct.
                        Now you must do these tests to find the correct motor settings.
                        M569 P0 S1; physical drive 0 goes backwards
                        M569 P1 S1; physical drive 1 goes backwards
                        Change these to S0.
                        Then move print head to the center and send G92 X100 Y100.
                        Then send G91 G1 S2 X10 F3000
                        If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
                        When you have the X motor moving correctly, test the Y motor by sending from the console: G91 G1 S2 Y10 F3000
                        If the head moves diagonally in the +X and -Y directions, all is well. If it moves in the -X and +Y directions, change the S parameter in the M569 P1 command to S1.
                        • Leblondundefined
                          Leblond
                          m569 p0 s0 e m569 p1 s0 cambiati
                          • Leblondundefined
                            Leblond
                            @Phaedrux said in Cambio elettronica:
                            G92 X100 Y100 ;questo dice alla stampante che si trova a x100 e y100 giusto?
                            G91 G1 H2 X10 F3000 : si e' spostata in diagonale verso dx e rear
                              Correct
                              Correct.
                              Now move on to the next move G91 G1 S2 Y10 F3000
                              • Leblondundefined
                                Leblond
                                G91 G1 H2 Y10 F3000 ok si e' spostata a dx e front
                                  Ok, so that means your settings should be good.
                                  If you send G91 G1 X10 it should move right
                                  If you send G91 G1 Y10 it should move to the back
                                  If you use the homeall I quoted above, you should now be able to home correctly.
                                  • Leblondundefined
                                    Leblond
                                    G91 G1 X10 ; va a dx - ok
                                    G91 G1 Y10 ; va indietro - ok
                                    Faccio L'homing ma invece di andare verso i finecorsa va dalla parte opposta😧
                                      ; homeall.g
                                      Does your homeall match this?
                                      • Leblondundefined
                                        Leblond
                                        te lo mando
                                        • Leblondundefined
                                          Leblond
                                          ; homeall.g
                                          G91 ; relative positioning
                                          G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                          G1 H1 X-335 ; home X axis
                                          G1 H1 Y-335 ; home Y axis
                                          G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
                                          G1 H1 Y-335 ; then move slowly to Y axis endstop
                                          G90 ; absolute positioning
                                          G1 X60 Y50 F6000 ; go to first bed probe point and home Z
                                          ;G91 ; relative positioning
                                          ;G90 ; absolute positioning
                                          • Leblondundefined
                                            Leblond
                                            si sposta verso il dietro e a dx
