    Cambio elettronica
    124
    6.0k
    • Leblondundefined
      Leblond
      ok guardo
      • Leblondundefined
        Leblond
        quindi quando si parla di parte bassa si intende il davanti della stampante e parte alta il dietro, giusto?
        ho riportato i valori su S1 ma si spostano di pochi cm. e mi da errore, quindi presumo che bisogna far girare i motori al contrario?
        • Leblondundefined
          Leblond
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT+0200 (Ora legale dell’Europa centrale)
          M550 P"X5SA PRO" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S1 ; physical drive 0 goes backwards
          M569 P1 S1 ; physical drive 1 goes backwards
          M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
          M203 X6000.00 Y6000.00 Z100.00 E1200.00 ; set maximum speeds (mm/min)
          M84 S30 ; Set idle timeout
          M208 X-5 Y0 Z0 S1 ; set axis minima
          M208 X352 Y330 Z400 S0 ; set axis maxima
          M574 X1 S1 P"! xstop" ; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"! ystop" ; configure active-high endstop for low end on Y via pin ystop
          M558 P5 C"! zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          M557 X60:300 Y50:300 S20 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
          M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
          • Leblondundefined
            Leblond
            non funziona
            • Leblondundefined
              Leblond
              siamo ritornati al punto di partenza quando non andava
                Phaedrux Moderator @Leblond
                @Leblond said in Cambio elettronica:
                Correct.
                when we talk about the lower part we mean the front of the printer and the upper part the back, right?
                Correct.
                M208 X-5 Y0 Z0 S1; minimum axis set
                M208 X352 Y330 Z400 S0; set axis maxima
                M574 X1 S1 P "! Xstop"; configure active-high endstop for low end on X via pin xstop
                M574 Y1 S1 P "! ystop"; configure active-high endstop for low end on Y via pin ystop
                M574 Z1 S2; configure Z-probe endstop for low end on Z
                Correct.
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 16:46:31 GMT + 0200 (Central European
                Summer Time) G91; relative positioning
                G1 H2 Z5 F6000; lift Z relative to current position
                G1 H1 X-335 Y-335 F1800; move quickly to X or Y endstop and stop there (first pass)
                G1 H1 X-335; home X axis
                G1 H1 Y-335; home Y axis
                G1 X5 Y5 F6000; go back a few mm
                G1 H1 X-335 F360; move slowly to X axis endstop once more (second pass)
                G1 H1 Y-335; then move slowly to Y axis endstop
                G90; absolute positioning
                G1 X60 Y50 F6000; go to first bed probe point and home Z
                G30; home Z by probing the bed
                Correct.
                Now you must do these tests to find the correct motor settings.
                M569 P0 S1; physical drive 0 goes backwards
                M569 P1 S1; physical drive 1 goes backwards
                Change these to S0.
                Then move print head to the center and send G92 X100 Y100.
                Then send G91 G1 S2 X10 F3000
                If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
                When you have the X motor moving correctly, test the Y motor by sending from the console: G91 G1 S2 Y10 F3000
                If the head moves diagonally in the +X and -Y directions, all is well. If it moves in the -X and +Y directions, change the S parameter in the M569 P1 command to S1.
                • Leblondundefined
                  Leblond
                  m569 p0 s0 e m569 p1 s0 cambiati
                  • Leblondundefined
                    Leblond
                    @Phaedrux said in Cambio elettronica:
                    G92 X100 Y100 ;questo dice alla stampante che si trova a x100 e y100 giusto?
                    G91 G1 H2 X10 F3000 : si e' spostata in diagonale verso dx e rear
                      Correct
                      Correct.
                      Now move on to the next move G91 G1 S2 Y10 F3000
                      • Leblondundefined
                        Leblond
                        G91 G1 H2 Y10 F3000 ok si e' spostata a dx e front
                          Ok, so that means your settings should be good.
                          If you send G91 G1 X10 it should move right
                          If you send G91 G1 Y10 it should move to the back
                          If you use the homeall I quoted above, you should now be able to home correctly.
                          • Leblondundefined
                            Leblond
                            G91 G1 X10 ; va a dx - ok
                            G91 G1 Y10 ; va indietro - ok
                            Faccio L'homing ma invece di andare verso i finecorsa va dalla parte opposta😧
                              ; homeall.g
                              Does your homeall match this?
                              • Leblondundefined
                                Leblond
                                te lo mando
                                • Leblondundefined
                                  Leblond
                                  ; homeall.g
                                  G91 ; relative positioning
                                  G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                  G1 H1 X-335 ; home X axis
                                  G1 H1 Y-335 ; home Y axis
                                  G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
                                  G1 H1 Y-335 ; then move slowly to Y axis endstop
                                  G90 ; absolute positioning
                                  G1 X60 Y50 F6000 ; go to first bed probe point and home Z
                                  ;G91 ; relative positioning
                                  ;G90 ; absolute positioning
                                  • Leblondundefined
                                    Leblond
                                    si sposta verso il dietro e a dx
                                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European
                                      I think the problem may be here. The G91 must be on a new line.
                                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European Summer Time)
                                      • Leblondundefined
                                        Leblond
                                        😧 scusami errore mio M574 X1 S1 P"!xstop" avevo tolto "!"
                                        Adesso funziona😊 grazie della pazienza che mi hai dimotrato fratello
                                        • Leblondundefined
                                          Leblond
                                          ecco la configurazione funzionante per la tronxy x5sa pro con duet, in caso qualcun'altro ne avesse bisogno
                                          M569 P0 S0 ; physical drive 0 goes backwards
                                          M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
                                          M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
                                          • Leblondundefined
                                            Leblond
                                            Buona notte a tutti
