Cambio elettronica
124
6.3k
    Leblond
    non funziona
      Leblond
      siamo ritornati al punto di partenza quando non andava
        Phaedrux Moderator @Leblond
        @Leblond said in Cambio elettronica:
        Correct.
        when we talk about the lower part we mean the front of the printer and the upper part the back, right?
        Correct.
        M208 X-5 Y0 Z0 S1; minimum axis set
        M208 X352 Y330 Z400 S0; set axis maxima
        M574 X1 S1 P "! Xstop"; configure active-high endstop for low end on X via pin xstop
        M574 Y1 S1 P "! ystop"; configure active-high endstop for low end on Y via pin ystop
        M574 Z1 S2; configure Z-probe endstop for low end on Z
        Correct.
        ; homeall.g
        ; called to home all axes
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 16:46:31 GMT + 0200 (Central European
        Summer Time) G91; relative positioning
        G1 H2 Z5 F6000; lift Z relative to current position
        G1 H1 X-335 Y-335 F1800; move quickly to X or Y endstop and stop there (first pass)
        G1 H1 X-335; home X axis
        G1 H1 Y-335; home Y axis
        G1 X5 Y5 F6000; go back a few mm
        G1 H1 X-335 F360; move slowly to X axis endstop once more (second pass)
        G1 H1 Y-335; then move slowly to Y axis endstop
        G90; absolute positioning
        G1 X60 Y50 F6000; go to first bed probe point and home Z
        G30; home Z by probing the bed
        Correct.
        Now you must do these tests to find the correct motor settings.
        M569 P0 S1; physical drive 0 goes backwards
        M569 P1 S1; physical drive 1 goes backwards
        Change these to S0.
        Then move print head to the center and send G92 X100 Y100.
        Then send G91 G1 S2 X10 F3000
        If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
        When you have the X motor moving correctly, test the Y motor by sending from the console: G91 G1 S2 Y10 F3000
        If the head moves diagonally in the +X and -Y directions, all is well. If it moves in the -X and +Y directions, change the S parameter in the M569 P1 command to S1.
          Leblond
          m569 p0 s0 e m569 p1 s0 cambiati
            Leblond
            @Phaedrux said in Cambio elettronica:
            G92 X100 Y100 ;questo dice alla stampante che si trova a x100 e y100 giusto?
            G91 G1 H2 X10 F3000 : si e' spostata in diagonale verso dx e rear
            undefined 1 Reply Last reply 3 Apr 2020, 00:33 Reply Quote 0
              Correct
              Correct.
              Now move on to the next move G91 G1 S2 Y10 F3000
                Leblond
                G91 G1 H2 Y10 F3000 ok si e' spostata a dx e front
                  Ok, so that means your settings should be good.
                  If you send G91 G1 X10 it should move right
                  If you send G91 G1 Y10 it should move to the back
                  If you use the homeall I quoted above, you should now be able to home correctly.
                    Leblond
                    G91 G1 X10 ; va a dx - ok
                    G91 G1 Y10 ; va indietro - ok
                    Faccio L'homing ma invece di andare verso i finecorsa va dalla parte opposta😧
                      ; homeall.g
                      Does your homeall match this?
                        Leblond
                        te lo mando
                          Leblond
                          ; homeall.g
                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT+0200 (Ora legale dell’Europa centrale)
                          G91 ; relative positioning
                          G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                          G1 H1 X-335 ; home X axis
                          G1 H1 Y-335 ; home Y axis
                          G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
                          G1 H1 Y-335 ; then move slowly to Y axis endstop
                          G90 ; absolute positioning
                          G1 X60 Y50 F6000 ; go to first bed probe point and home Z
                          ;G91 ; relative positioning
                          ;G90 ; absolute positioning
                          undefined 1 Reply Last reply 3 Apr 2020, 00:49 Reply Quote 0
                            Leblond
                            si sposta verso il dietro e a dx
                              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European
                              I think the problem may be here. The G91 must be on a new line.
                              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European Summer Time)
                                Leblond
                                😧 scusami errore mio M574 X1 S1 P"!xstop" avevo tolto "!"
                                Adesso funziona😊 grazie della pazienza che mi hai dimotrato fratello
                                  Leblond
                                  ecco la configurazione funzionante per la tronxy x5sa pro con duet, in caso qualcun'altro ne avesse bisogno
                                  M550 P"X5SA PRO" ; set printer name
                                  M669 K1 ; select CoreXY mode
                                  M552 S1 ; enable network
                                  M586 P0 S1 ; enable HTTP
                                  M586 P1 S0 ; disable FTP
                                  M586 P2 S0 ; disable Telnet
                                  M569 P0 S0 ; physical drive 0 goes backwards
                                  M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
                                  M203 X6000.00 Y6000.00 Z100.00 E1200.00 ; set maximum speeds (mm/min)
                                  M84 S30 ; Set idle timeout
                                  M208 X-5 Y0 Z0 S1 ; set axis minima
                                  M208 X352 Y330 Z400 S0 ; set axis maxima
                                  M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
                                  M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
                                  M558 P5 C"! zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                  M557 X60:300 Y50:300 S20 ; define mesh grid
                                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                                  M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                                    Leblond
                                    Buona notte a tutti
                                      Glad you got it working.
                                        Leblond
                                        buongiorno a tutti voi.
                                        Sto completando la stampante per quanto riguarda l'elettronica ho letto qui https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing e non son sicuro di aver capito bene.
                                        allora ricapitolando, quello che cerco e' nel comando M591 se non erro ed e' il seguente
                                        M591 D0 P1 C "e0_stop" S1 corretto? l'interruttore rimane alto quando c'e' il filamento e viceversa quando non c'e' mi basta solo questo in config? o ho bisogno di altro?
                                          Leblond
                                          RISOLTO
                                          gdefrancundefined 1 Reply Last reply 15 Apr 2020, 14:00 Reply Quote 0
                                          101 out of 124
