    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    21.9k
    • zaptaundefined
      zapta @Danal
      Project's documentation looks very clear and professionalWould be interesting to see here sample videos.
      The layer sync without a wired connection to the printer is a creative idea. Is it possible to achieve somehow the 'stationary print head' effect? https://youtu.be/S2cpHMoK8mw?t=13
      Edit: a feature idea, include automatically music in the generated video.
      Edit: another feature idea, add automatic time indication in the generator video. E.g. an analog clock at the corner, or digital time.
      Danalundefined 3 Replies Last reply Reply Quote 0
      • Danalundefined
        Danal @zapta
        @zapta said in DuetLapse available for Alpha testing:
        This is already implemented. Add -movehead 10 15 to flags that either detect or force pauses. The numbers are X and Y respectively.
        • Danalundefined
          Danal @zapta
          Not a bad idea. I will add that to the "to do" list.
          • Danalundefined
            Danal @zapta
            Probably going to let people do that in post-processing.
            • PaulHewundefined
              PaulHew
              @Danal
              It has stopped processing at image46 out of 200.
              I had this issue with the other Timelapse, and dropped the resolution of the images.
              Is there somewhere I can tweak the resolution?
              I am not a Python Guru, my skills lie elsewhere.
              Regards,
              Paul.
              • PaulHewundefined
                PaulHew
                @Danal
                Following on, I added the -q 25 to the DuetLapse.py for the Raspistill
                        cmd = 'raspistill -o -q 25 '+fn
                I am getting some errors and it seems to be taking pictures whilst my bed leveling is happening
                End of print will be sensed, and frames will be converted into video.
                Capturing frame     0 at X25.00 Y25.00 Z117.31
                Invalid command line option (25)
                Capturing frame     1 at X25.00 Y25.00 Z121.31
                Capturing frame     2 at X-10.00 Y25.00 Z117.31
                Capturing frame     3 at X-10.00 Y25.00 Z121.31
                Capturing frame     4 at X-10.00 Y-8.00 Z117.31
                Capturing frame     5 at X150.00 Y150.00 Z122.31
                • zaptaundefined
                  zapta @Danal
                  @Danal said in DuetLapse available for Alpha testing:
                  Very nice! You are doing magic with network connections to the Duet.
                  • zaptaundefined
                    zapta @Danal
                    While you do it you can add other visual indicators such as Z height, and filament used.
                    • Danalundefined
                      Danal @PaulHew
                      @PaulHew said in DuetLapse available for Alpha testing:
                      @Danal
                      Yes, those errors are from the flag you added. Don't add a flag between -o and the file name.
                      Also, the raspistill default is 35, so there is not much point in overriding to 25, that's not all that different.
                      If you have a bed leveling command in the print job, then yes, it will be capturing pictures, because the printer is running a job.
                      If you are manually initiating the bed leveling, do not start the script until after you bed level, but before you start the print job.
                      If there is some other situation, let me know.
                      • Danalundefined
                        Danal @PaulHew
                        @Danal
                        Regards,
                        Paul.
                        What camera? What command did you issue to start the script?
                        PaulHewundefined 1 Reply Last reply Reply Quote 0
                        • Danalundefined
                          Danal @zapta
                          Keep the ideas coming!
                          • PaulHewundefined
                            PaulHew @Danal
                            Morning Danal
                            I used ./DuetLapse.py -camera pi -duet 192.168.0.7
                            • PaulHewundefined
                              PaulHew
                              Using -q 40 with the other TL program my filesizes are ...
                              This is the line it used.
                              raspistill -bm -q 40 -w 640 -h 480 -o $snapshot && curl -X POST http://localhost:8000/snapshot -d '{"name":"'$snapshot'"}'
                              These are the sizes of the files using DuetLapse
                              I was getting 'malloc' errors with the other program and it would fail when running the FFMPEG but when I dropped the filesize using the -q it worked. Do not know if the 640x480 had a part in it also.
                              I can try if it helps you.
                              As I previously mentioned, I am not a Linux / Python guru, just trying to help and fix things myself and also contribute.
                              Regards,
                              Paul
                              • chas2706undefined
                                chas2706
                                @Danal
                                Absolutely brilliant. It works a treat.
                                Fantastic work!
                                • Danalundefined
                                  Danal @PaulHew
                                  @PaulHew You can add the -q 25 (or whatever you wish to try), just put it before the -o. Or, more correctly, not between the -o and the filename.
                                  At this moment, none of my Pi cameras can reach to see a printer. Ribbon too short. I have some longer ribbon, and an Arducam, on the way. Amazon keeps moving the date (which I totally understand). I'll be able to fine tune this more when I receive that stuff.
                                  Meanwhile, keep the specifics coming! (And, you are a lot more of a Guru than you think)
                                  • gtj0undefined
                                    gtj0
                                    Just about to try it but noticed that it seems to be opening and closing the unix socket twice a second. Not usually an issue except I run the DCS with debug logging so it's kinda distracting. Any chance of just keeping the socket open or better yet, just getting the model updates as they happen?
                                    • gtj0undefined
                                      gtj0
                                      Getting
                                      # python3 ./DuetLapse.py -camera usb -duet 127.0.0.1 -seconds 5 -detect none
                                      Attempting to connect to printer at 127.0.0.1
                                      Connected to a Duet V3 printer at http://127.0.0.1
                                      # Options in force for this run: #
                                      # camera   = usb                 #
                                      # printer  = 127.0.0.1           #
                                      # seconds  = 5.0                 #
                                      # detect   = none                #
                                      # pause    = no                  #
                                      # movehead =   0.00   0.00       #
                                      Waiting for print to start on printer 127.0.0.1
                                      Print start sensed.
                                      Capturing frame     0 after 1586032541.73 seconds elapsed.
                                      Unable to find a compatible palette format.
                                      Capturing frame     1 after 5.01 seconds elapsed.
                                      Nothing written to /tmp/DuetLapse.
                                      Any ideas?
                                      • Danalundefined
                                        Danal
                                        Which USB camera?
                                        • Danalundefined
                                          Danal @gtj0
                                          @gtj0 said in DuetLapse available for Alpha testing:
                                          It doesn't touch the unix socket. It is opening and closing a websocket connection, and not persisting it. This was a design choice in startup to not track state. I will look into persisting that connection.
                                          • zaptaundefined
                                            zapta @Danal
                                            Danal, here is an idea, not necessary specific for this timelapse app, but since you know how to monitor the duet during printing and generate visualization, would be interesting to have something that plot the different time left estimations that the Duet provides.
                                            Think of an x/y graph. X is print time from 0 to total print time T. Y is the time left for completion. The ideal reporting is a straight line from (0,T) to (T,0). And then you can sample the duet and plot the time left graphs by the various methods the Duet uses.
                                            The output can be an actual graph or a csv file that can be plotted with a spreadsheet and the likes.
