    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    23.0k
    • Danalundefined
      Danal @zapta
      @zapta said in DuetLapse available for Alpha testing:
      Edit: another feature idea, add automatic time indication in the generator video. E.g. an analog clock at the corner, or digital time.
      Not a bad idea. I will add that to the "to do" list.
      • Danalundefined
        Danal @zapta
        Edit: a feature idea, include automatically music in the generated video.
        Probably going to let people do that in post-processing.
        • PaulHewundefined
          PaulHew
          @Danal
          It has stopped processing at image46 out of 200.
          I had this issue with the other Timelapse, and dropped the resolution of the images.
          Is there somewhere I can tweak the resolution?
          I am not a Python Guru, my skills lie elsewhere.
          Regards,
          Paul.
          • PaulHewundefined
            PaulHew
            @Danal
            Following on, I added the -q 25 to the DuetLapse.py for the Raspistill
                    cmd = 'raspistill -o -q 25 '+fn
            I am getting some errors and it seems to be taking pictures whilst my bed leveling is happening
            End of print will be sensed, and frames will be converted into video.
            Capturing frame     0 at X25.00 Y25.00 Z117.31
            Invalid command line option (25)
            Capturing frame     1 at X25.00 Y25.00 Z121.31
            Capturing frame     2 at X-10.00 Y25.00 Z117.31
            Capturing frame     3 at X-10.00 Y25.00 Z121.31
            Capturing frame     4 at X-10.00 Y-8.00 Z117.31
            Capturing frame     5 at X150.00 Y150.00 Z122.31
            • zaptaundefined
              zapta @Danal
              @Danal said in DuetLapse available for Alpha testing:
              This is already implemented. Add -movehead 10 15 to flags that either detect or force pauses. The numbers are X and Y respectively.
              Very nice! You are doing magic with network connections to the Duet.
              • zaptaundefined
                zapta @Danal
                While you do it you can add other visual indicators such as Z height, and filament used.
                • Danalundefined
                  Danal @PaulHew
                  @PaulHew said in DuetLapse available for Alpha testing:
                  @Danal
                  Yes, those errors are from the flag you added. Don't add a flag between -o and the file name.
                  Also, the raspistill default is 35, so there is not much point in overriding to 25, that's not all that different.
                  If you have a bed leveling command in the print job, then yes, it will be capturing pictures, because the printer is running a job.
                  If you are manually initiating the bed leveling, do not start the script until after you bed level, but before you start the print job.
                  If there is some other situation, let me know.
                  • Danalundefined
                    Danal @PaulHew
                    @Danal
                    Regards,
                    Paul.
                    What camera? What command did you issue to start the script?
                    PaulHewundefined 1 Reply Last reply Reply Quote 0
                    • Danalundefined
                      Danal @zapta
                      Keep the ideas coming!
                      • PaulHewundefined
                        PaulHew @Danal
                        Morning Danal
                        I used ./DuetLapse.py -camera pi -duet 192.168.0.7
                        • PaulHewundefined
                          PaulHew
                          Using -q 40 with the other TL program my filesizes are ...
                          This is the line it used.
                          raspistill -bm -q 40 -w 640 -h 480 -o $snapshot && curl -X POST http://localhost:8000/snapshot -d '{"name":"'$snapshot'"}'
                          These are the sizes of the files using DuetLapse
                          I was getting 'malloc' errors with the other program and it would fail when running the FFMPEG but when I dropped the filesize using the -q it worked. Do not know if the 640x480 had a part in it also.
                          I can try if it helps you.
                          As I previously mentioned, I am not a Linux / Python guru, just trying to help and fix things myself and also contribute.
                          Regards,
                          Paul
                          • chas2706undefined
                            chas2706
                            @Danal
                            Absolutely brilliant. It works a treat.
                            Fantastic work!
                            • Danalundefined
                              Danal @PaulHew
                              @PaulHew You can add the -q 25 (or whatever you wish to try), just put it before the -o. Or, more correctly, not between the -o and the filename.
                              At this moment, none of my Pi cameras can reach to see a printer. Ribbon too short. I have some longer ribbon, and an Arducam, on the way. Amazon keeps moving the date (which I totally understand). I'll be able to fine tune this more when I receive that stuff.
                              Meanwhile, keep the specifics coming! (And, you are a lot more of a Guru than you think)
                              • gtj0undefined
                                gtj0
                                Just about to try it but noticed that it seems to be opening and closing the unix socket twice a second. Not usually an issue except I run the DCS with debug logging so it's kinda distracting. Any chance of just keeping the socket open or better yet, just getting the model updates as they happen?
                                • gtj0undefined
                                  gtj0
                                  Getting
                                  # python3 ./DuetLapse.py -camera usb -duet 127.0.0.1 -seconds 5 -detect none
                                  Attempting to connect to printer at 127.0.0.1
                                  Connected to a Duet V3 printer at http://127.0.0.1
                                  # Options in force for this run: #
                                  # camera   = usb                 #
                                  # printer  = 127.0.0.1           #
                                  # seconds  = 5.0                 #
                                  # detect   = none                #
                                  # pause    = no                  #
                                  # movehead =   0.00   0.00       #
                                  Waiting for print to start on printer 127.0.0.1
                                  Print start sensed.
                                  Capturing frame     0 after 1586032541.73 seconds elapsed.
                                  Unable to find a compatible palette format.
                                  Capturing frame     1 after 5.01 seconds elapsed.
                                  Nothing written to /tmp/DuetLapse.
                                  Any ideas?
                                  • Danalundefined
                                    Danal
                                    Which USB camera?
                                    • Danalundefined
                                      Danal @gtj0
                                      @gtj0 said in DuetLapse available for Alpha testing:
                                      It doesn't touch the unix socket. It is opening and closing a websocket connection, and not persisting it. This was a design choice in startup to not track state. I will look into persisting that connection.
                                      • zaptaundefined
                                        zapta @Danal
                                        Danal, here is an idea, not necessary specific for this timelapse app, but since you know how to monitor the duet during printing and generate visualization, would be interesting to have something that plot the different time left estimations that the Duet provides.
                                        Think of an x/y graph. X is print time from 0 to total print time T. Y is the time left for completion. The ideal reporting is a straight line from (0,T) to (T,0). And then you can sample the duet and plot the time left graphs by the various methods the Duet uses.
                                        The output can be an actual graph or a csv file that can be plotted with a spreadsheet and the likes.
                                        • gtj0undefined
                                          gtj0 @Danal
                                          Which USB camera?
                                          Teslong USB "Endoscope". It only supports MJPEG as a palette and I just noticed that you've got YUYV hard coded on the fswebcam command line. Maybe don't specify '-p' and let it default?
                                          Ah yeah, the websocket will result in the same messages. It's not critical so don't spend all that much time on it.
                                          • Danalundefined
                                            Danal @gtj0
                                            I think I did that and it required it for some reason. I will try a couple of different things to get it as automatic as possible.
