    Oddly shaped holes?
    106
    6.1k
    • arhiundefined
      arhi @Surgikill
      @Surgikill said in Oddly shaped holes?:
      @arhi Here's the latest test piece. It definitely looks butter, but it's still sticking. Not sure how long these bushings need to "wear in" but I've probably put over 20-25 hours on them so far, so they should be pretty worn in.
      As long as they are not slopy they are IMO not part of this problem.
      I have to do a bunch of BS to remove the extruder. I might be able to tape a pen to the side and then try and manually home it.
      tape a pen πŸ˜„ hotglue a pen... something like that .. or do a single layer print with extruder but pen is much faster, no need to wait for anything to heat up πŸ™‚
      I ordered some regular LM16UU bearings. I'd really like to get this figured out with the bushings if possible though. They are definitely quieter and provide smoother operation.
      If the bushings are not showing slop it's not up to them I'm sure
      as I said, start writing some manual gcode to see where the problem is ..
      you say if you move in diagonal only one motor motor moves .. so test something like
      ; add here your temperature stuff for bed and extruder, your normal start code
      ; do the test
      M83               ; RELATIVE extruder move
      G0X0Y20Z0.25      ; go to start position, 0.25mm layer
      G0X10Y10
      G1X50Y50F600E2.352
      G1X80Y10F600E2.352
      G1X100Y30F600E1.176
      G1X70Y70F600E2.352
      G1X50Y50F600E1.176
      G0Z20
      ; turn off your bed and extruder heaters now
      all moves should be single motor only, and last move should hit exactly the 50,50 coordinate that first move ends at but from different
      Surgikillundefined 1 Reply Last reply Reply Quote 0
      • Surgikillundefined
        Surgikill @arhi
        @arhi said in Oddly shaped holes?:
        I don't think it's slop that's the issue. I think they are sticking. It seems to happen more towards the extreme y axis.
        ; do the test
        G0X10Y10
        G1X50Y50F600E2.352
        G1X80Y10F600E2.352
        G1X100Y30F600E1.176
        G1X70Y70F600E2.352
        G1X50Y50F600E1.176
        G0Z20
        I'm pretty bad with gcode. What is that drawing exactly? A box? I'll make it up and see what happens.
        • arhiundefined
          arhi @Surgikill
          If they are binding then you have skipped steps, but possible they are binding in a way that for microstepping you are inprecise.
          There is a super simple test for that, turn off interpolation as set microstepping to 2 (half step only), and reduce your step/mm for XY 8 times (if you are at 1/16 now) .. the movement will be jerky and circle will be "stepped" and not smooth but should be circle, not that thing you have now.
          if you plan on doing a lot of 3d printing, learn it πŸ˜„ it's rather simple
          it moves your head "to some coordinate" so
          if you follow the gcode
          go to 0,20 then to 10,10, then to 50,50, then to 80,10 -> 100,30 ->70,70 -> 50,50 and finally go to Z20 (raise head or drop table whatever moves in your case)
          so if you look at 50,50 point, extruder will in first arrive there from 10,10 but coming from "above" from 0,20, then it will change direction coming from 100,30 to 70,70 so when it returns to 50,50 it will be misaligned for the backlash in one of two motors.
          You can't make this as "object" as you don't have control in slicer of the direction of the travel, these type of g-codes you have to write yourself to test stuff you want to test... you should then make a mirror of this move to test the other motor (assuming I guessed right the single motor movement on coreXY as I said, zero experience in that department)
          BTW if you lock your motors, any direction you can move your head for a fraction of mm ?
            Surgikill @arhi
            Yea I just wrote that gcode out and it did nada. It didn't even extrude any filament. I'm going to mess with it and see what I can do.
            EDIT: Yea I have no idea what it's trying to do, but it's air printing and not extruding anything. I'm just going to try and make a thin wall part and try it.
            • arhiundefined
              arhi @Surgikill
              you need to add the start code before it (heat your bed, then heat your nozzle, then home.... ) as it will print in the air if it's not homed and will not extrude if it's cold πŸ™‚
              I just put the "action" part in, the rest depends on your printer.
              problem with that is that you don't know what side the slicer with make the path come from
                Surgikill @arhi
                @arhi I did all of that. I took start and end gcode I have for my slicer and pasted it in there. Not sure what the issue is. I changed the F value as well because I think it was a little too low. I had 1800 in my setup.
                • arhiundefined
                  arhi @Surgikill
                  @Surgikill I used 10mm/sec as "safe" πŸ˜„ .. you can increase .. you can try to increase the E values, maybe I was too conservative and put too low values
                  but it can't be printing in air
                  the first line after M83 (M83 just set extruder to relative positioning) is
                  G0X0Y20Z0.25
                  that's move (G0) to X=0 (X0) Y=20 (Y20) and Z=0.25 (Z0.25)
                  Z is not set after that so all moves here needs to be on Z=0.25mm
                  till the last code G0Z20 that moves Z straight up 20mm
                  The E value is maybe to low and maybe you need to prime it first, something like this:
                  ;bed temp, extruder temp, home..
                  M190 S60  ; bed 60
                  M109 S230 ; nozzle 230
                  M106 S0   ; fan off
                  G28       ; home
                  G21       ; millimeters
                  G90       ; absolute XY moves
                  M200 D0   ; no volumetric extrusion
                  G0X0Y0Z10 ; go to 0,0,10
                  G1E50F100 ; extrude a blob of plastic in the air to prime the nozzle
                  G1X0Y20Z0.25      ; go to start position, 0.25mm layer
                  G1X10Y10
                  G1X50Y50F600E2.352
                  G1X80Y10F600E2.352
                  G1X100Y30F600E1.176
                  G1X70Y70F600E2.352
                  G1X50Y50F600E1.176
                  G0Z20
                  M104 S0 ; turn off extruder
                  M140 S0 ; turn off bed
                  M106 S0 ; turn off fan
                  ; shut everything down here
                  Surgikillundefined 2 Replies Last reply Reply Quote 0
                    Surgikill @arhi
                    @arhi This is the start of one of my gcode files. I forget exactly what I had to do, but I think I wrote something special in there because I'm using 4 independent z motors to tram the bed.
                    M107
                    M107
                    M104 S235 ; set temperature
                    G32 ;home and level
                    G28 ;home
                    G21 ; set units to millimeters
                    G90 ; use absolute coordinates
                    M82 ; use absolute distances for extrusion
                    G92 E0
                    ; Filament gcode
                    M109 S235 ; set temperature and wait for it to be reached
                    G92 E0
                    G1 Z0.200 F7800.000
                    G1 E-2.00000 F2400.00000
                    G92 E0
                    G1 Z0.350 F7800.000
                    G92 E0
                    G1 X91.390 Y102.905 F7800.000
                    G1 E2.00000 F2400.00000
                    G1 F1800.000
                    G1 X93.026 Y102.689 E2.11451
                    G1 X117.999 Y102.489 E3.84808
                    G1 X179.410 Y102.488 E8.11097
                    G1 X207.724 Y102.689 E10.07646
                    G1 X208.948 Y102.812 E10.16187
                    G1 X209.906 Y103.069 E10.23068
                    G1 X210.823 Y103.463 E10.29994
                    G1 X211.673 Y103.985 E10.36920
                    G1 X212.434 Y104.621 E10.43802
                    G1 X213.273 Y105.598 E10.52746
                    G1 X215.387 Y108.621 E10.78349
                    G1 X215.889 Y109.505 E10.85410
                    I'm going to try adding your code in with the prime on the extruder. I usually use a skirt, so that's my priming.
                      Surgikill @arhi
                      @arhi Yea I just ran the updated Gcode and it's still printing in air and not extruding anything. This is what I have for the gcode.
                      M107
                      M107
                      G32 ;home and level
                      G28 ;home
                      G92 E0
                      ; Filament gcode
                      G92 E0
                      G1 Z0.200 F7800.000
                      G92 E0
                      G1 Z0.350 F7800.000
                      G92 E0
                      G1 F1800.000
                      G21       ; millimeters
                      G1X10Y10
                      G1X50Y50F600E2.352
                      G1X80Y10F600E2.352
                      G1X100Y30F600E1.176
                      G1X70Y70F600E2.352
                      G1X50Y50F600E1.176
                      G0Z20
                      G92 E0
                      M107
                      ; Filament-specific end gcode
                      ;END gcode for filament
                      M104 S0 ; turn off hotend
                      G28 X0 Y0  ; home X axis
                      G1 Z310  ;move Z to max
                      M84     ; disable motors
                      • arhiundefined
                        arhi @Surgikill
                        the extrusion, you can try increasing the E values in those codes
                        but "in the air" .. no idea, it must be at z 0.25 .. that is very close to table πŸ™‚ .. no clue how it messes up
                          Surgikill @arhi
                          @arhi This might help. The circles on the bottom of the picture are closest to Y max, and the circles at the top of the picture are closes to Y min. X min is right side, X max is left side. It definitely look like the circles get worse as it goes towards Y max.
                          • arhiundefined
                            arhi
                            Sorry mate, I'm lost here. You really need someone who actually has experience with coreXY machine. With the CNC this type of error is always backlash. No clue how backlash on each motor affect this at all. Normally you can tweak backlash compensation in the firmware of your CNC machine, but AFAIK there is no support for that in RRF (not sure any 3d printing firmware supports it, I know there was try to implement it in marlin but I think they gave up, never entered master branch).
                              Surgikill @arhi
                              @arhi My theory here is that the igus bushings are binding up near Y max. This is causing 2 things:
                              1. I lose microstepping, which causes a loss in resolution
                              2. My belts stretch more (it's a pretty large printer, so the belts are pretty long) and that creates the "backlash" issue
                              I'll have the LM16UU bearings in this coming week. Those will get installed and hopefully this issue will be resolved.
                              • arhiundefined
                                arhi
                                It is a good theory as any. I see even on large printers ppl go with 2mm belts which is weird to me, the only reason to go with 2mm pitch is tight bend radius, but if you are on big printer you can design so that you don't need tight bend radius and go with 5mm pitch where for much less $$ you can get higher quality belts .. but ..
                                  Surgikill @arhi
                                  @arhi If I still have an issue, I'll re-design for 5mm pitch. I think the 2mm should be fine. I might need to upgrade to a non chinesium belt.
                                  • arhiundefined
                                    arhi @Surgikill
                                    @Surgikill even chinesium ones at 5mm work nice, the 2mm prc belts stretch, while a lot of ppl online try to say they don't my experience show different, also no proper reinforcement... 5mm you can chose if you want glass or steel, last a long time, only issue is if you go 180 degrees it has to go over large diameter (18 or 20 5mm pitch teeth is rather large circle) .. so the idea is to design motor to sit on the "straight" path of the belt with some idlers (3 point setup) rather then doing 180 around the motor forcing you to use large diameter driving pulley making 1 step of the motor move too many mm of belt πŸ™‚
                                    also, using 5-6mm wide belts on big printers... IMO 5mm is ok on something like 200x200mm print surface, you go over you need to step up to 10mm or more .. if you look at professional machines it's not hard to find belts that are in 10cm width class πŸ™‚ ... I remember some stratasys printer I was repairing back in the day motor was linked to extruder with belt that was 4-5cm wide, X and Y belts were both 6-7cm wide πŸ˜„ 5mm pitch belts ...
                                    • mwolterundefined
                                      mwolter
                                      LM16UU
                                      I think you’re on the right path regarding the igus bushings causing the oddly shaped circles. I bought into the hype of the polymer bushings but had print quality issues. In my case the sticktion could be felt when manually moving the axis with the belts removed. Either they were loose to prevent sticktion and had excessive play or they were tight and caused the oddly shaped circles like you are experiencing. Also found that the rods need to be completely dry and cleaned regularly. Not worth it, went back to LM16UU bearings and the issue went away.
                                        Surgikill @mwolter
                                        @mwolter Yup. I've had the same issues where they're either too loose or too tight. Hopefully the LM16UU fix that issue.
                                        • bondusundefined
                                          bondus
                                          Those IGUS bushings have pretty tight tolerances on how they are supposed to be mounted. There is a lot to read on their website.
                                          I have tried them a few times, but as many of you say they either bind or have play.
                                          They seem to be popular in the industry, "lubricated by dirt".
                                          zaptaundefined mendenmhundefined 2 Replies Last reply Reply Quote 0
                                          • zaptaundefined
                                            zapta @bondus
                                            Igus has plastic bushings that are encapsulated in a hard shell. This way you can clamp it without increasing the binding on the rod. E.g.
                                            https://www.amazon.com/gp/product/B00QZ7YJ7W
                                            Linear bearings are available in double length but I couldn't find double length igus bushings and installing two one after the other creates non co-linearity that increases the binding.
