    DWC Randomly terminate print at start
    Duet Web Control
    538
    • jens55undefined
      jens55
      I don't know if this is related to your problem but your temperature graphs show substantial variance and that might cause a shutdown.
      Have you run tuning on heaters one and two?
      Does the shut-down coincide with the start of a cooling fan ?
        Does any message show in the gcode console?
        The temp swings could indicate a thermal shutdown.
        Firmware versions?
        • Ray11undefined
          Ray11
          Nope, nothing in console either. I think it is somewhat related to the heater. I sometimes got heating fault on the bed.
            Have you PID tuned the heaters?
            If you send M98 Pconfig.g in the console, do you get any error messages?
            • Ray11undefined
              Ray11
              @Phaedrux
              I get 3 warnings:
              Warning: heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C.
              Warning: heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 599C.
              Warning: heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 599C.
              Also, when I switch to bang-bang mode for the bed, it throws a heater fault in a couple of seconds. Even if I use M570 S999999 to basically disable the heater fault check.
              I am using a 12v bed with an additional power supply and when I do the auto-tune, the reported voltage is the system voltage of 24v. I wonder if that is a bug or something.
                Phaedrux Moderator @Ray11
                @Ray11 said in DWC Randomly terminate print at start:
                That's interesting. How do you have it all wired up? I wonder if the Duet is assuming you're using vin. Not sure how it would know...
                You should be using PID tuning for all heaters. Bang-bang is rarely appropriate.
                  Can you also send M122 after a print has failed and post the response.
                  Also post your config.g and config-override.g please.
                  • Ray11undefined
                    Ray11
                    @Phaedrux
                    Thank you so much for helping me with this!
                    Here is the M122 result after print was instantly terminated:
                    M122
                    RepRapFirmware for Duet 3 MB6HC version 3.01-RC5 running on Duet 3 MB6HC v0.6 or 1.0
                    Board ID: 08DJM-956L2-G43S4-6J1D6-3SD6R-KU5GF
                    Used output buffers: 2 of 40 (7 max)
                    Static ram: 154084
                    Dynamic ram: 161400 of which 44 recycled
                    Exception stack ram used: 216
                    Never used ram: 77472
                    Tasks: NETWORK(ready,1108) ETHERNET(blocked,444) HEAT(blocked,1196) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1468) TMC(blocked,216) MAIN(running,4388) IDLE(ready,80)
                    Owned mutexes:
                    Last reset 00:00:16 ago, cause: power up
                    Last software reset time unknown, reason: User, spinning module GCodes, available RAM 77276 bytes (slot 1)
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                    Error status: 0
                    Free file entries: 10
                    MCU temperature: min 25.8, current 27.4, max 27.5
                    Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                    12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                    Driver 0: standstill, reads 15368, writes 16 timeouts 0, SG min/max 0/0
                    Driver 1: standstill, reads 15369, writes 16 timeouts 0, SG min/max 0/0
                    Driver 2: standstill, reads 15369, writes 16 timeouts 0, SG min/max 0/0
                    Driver 3: standstill, reads 15371, writes 15 timeouts 0, SG min/max 0/0
                    Driver 4: standstill, reads 15371, writes 15 timeouts 0, SG min/max 0/0
                    Driver 5: standstill, reads 15372, writes 15 timeouts 0, SG min/max 0/0
                    Slowest loop: 4.12ms; fastest: 0.15ms
                    === MainDDARing ===
                    === AuxDDARing ===
                    Heater 1 is on, I-accum = 0.0
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 3.10ms; fastest: 0.03ms
                    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                    HTTP sessions: 1 of 8
                    - Ethernet -
                    State: active
                    Error counts: 0 0 0 0 0
                    === CAN ===
                    Messages sent 65, longest wait 0ms for type 0
                    === Linux interface ===
                    State: 0, failed transfers: 0
                    Last transfer: 16683ms ago
                    RX/TX seq numbers: 0/1
                    SPI underruns 0, overruns 0
                    Number of disconnects: 0
                    Buffer RX/TX: 0/0-0
                    And here is my config.g
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 01 2020 22:14:44 GMT-0500 (Central Daylight Time)
                    G90                                             ; send absolute coordinates...
                    M83                                             ; ...but relative extruder moves
                    M550 P"INAZUMA-IDEX"                            ; set printer name
                    M552 P0.0.0.0 S1                                ; enable network and acquire dynamic address via DHCP
                    M586 P0 S1                                      ; enable HTTP
                    M586 P1 S0                                      ; disable FTP
                    M586 P2 S0                                      ; disable Telnet
                    M569 P0.0 S0 D3                                   ; physical drive 0.0 goes forwards
                    M569 P0.1 S0 D3                                   ; physical drive 0.0 goes forwards
                    M569 P0.2 S0 D3                                   ; physical drive 0.2 goes forwards
                    M569 P0.3 S1 D3                                   ; physical drive 0.3 goes forwards
                    M569 P0.4 S0 D3                                   ; physical drive 0.4 goes forwards
                    M569 P0.5 S0 D3                                   ; physical drive 0.5 goes forwards
                    M584 X0.0 U0.1 Y0.2 Z0.3 E0.4:0.5                    ; set drive mapping
                    M350 X16 U16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
                    M92 X100.00 U100.00 Y80.00 Z1600.00 E410.00:430.00      ; set steps per mm
                    M566 X900.00 U900.00 Y900.00 Z12.00 E120.00:120.00      ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 U6000.00 Y6000.00 Z1000.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                    M201 X500.00 U500.00 Y500.00 Z20.00 E250.00:250.00      ; set accelerations (mm/s^2)
                    M906 X700 U700 Y800 Z600 E800:800 I30                ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                         ; Set idle timeout
                    M208 X-30 U26 Y0 Z0 S1                                ; set axis minima
                    M208 X260 U316 Y190 Z200 S0                          ; set axis maxima
                    M574 X1 S3                                      ; configure sensorless endstop for low end on X
                    M574 U1 S3
                    M574 Y1 S3                                      ; configure sensorless endstop for low end on Y
                    M574 Z1 S2                                      ; configure sensorless endstop for low end on Z
                    M915 X U Y S2 R1
                    M558 P1 I0 C"io3.in" H3 F2000 T6000                 ; set Z probe type to switch and the dive height + speeds
                    G31 P580 X0 Y0 Z0                            ; set Z probe trigger value, offset and trigger height
                    ;G31 P{sensors.probes[0].value[0] + 30}
                    ;G31 X0 Y0 Z0
                    M557 X60:270 Y15:195 S60                        ; define mesh grid
                    M570 S99999
                    M308 S0 P"temp0" Y"thermistor" T100000 B4138    ; configure sensor 0 as thermistor on pin temp0
                    M950 H0 C"out0" T0                              ; create bed heater output on out0 and map it to sensor 0
                    M143 H0 S80                                    ; set temperature limit for heater 0 to 120C
                    M307 H0 B0 S1.00 V11.0                               ; enable bang-bang mode for the bed heater and set PWM limit
                    M307 H0 A84.5 C473.8 D1.4
                    M140 H0                                         ; map heated bed to heater 0
                    M308 S1 P"temp1" Y"thermistor" T100000 B4138    ; configure sensor 1 as thermistor on pin temp1
                    M950 H1 C"out1" T1                              ; create nozzle heater output on out1 and map it to sensor 1
                    M143 H1 S240                                    ; set temperature limit for heater 1 to 240C
                    M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
                    M307 H1 A574.5 C154.9 D8.5 V24.0
                    M308 S2 P"temp2" Y"thermistor" T100000 B4138    ; configure sensor 2 as thermistor on pin temp2
                    M950 H2 C"out2" T2                              ; create nozzle heater output on out2 and map it to sensor 2
                    M143 H2 S240                                    ; set temperature limit for heater 2 to 240C
                    M307 H2 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
                    M307 H2 A574.5 C154.9 D8.5 V24.0
                    M950 F0 C"out7" Q500                            ; create fan 0 on pin out4 and set its frequency
                    M106 P0 L1.0 S0 H1 T60                               ; set fan 0 value. Thermostatic control is turned on
                    M950 F1 C"out8" Q500                            ; create fan 1 on pin out5 and set its frequency
                    M106 P1 S0 H-1                                  ; set fan 1 value. Thermostatic control is turned off
                    M950 F2 C"out4" Q500                            ; create fan 2 on pin out7 and set its frequency
                    M106 P2 L1.0 S0 H2 T60                               ; set fan 2 value. Thermostatic control is turned on
                    M950 F3 C"out9" Q500                            ; create fan 3 on pin out6 and set its frequency
                    M106 P3 S0 H-1                                  ; set fan 3 value. Thermostatic control is turned off
                    M563 P0 D0 H1 F0:1                              ; define tool 0
                    G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
                    G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
                    M563 P1 D1 H2 X3 F0:3                              ; define tool 1
                    G10 P1 U0.25 Y-1.8 Z-0.6                                 ; set tool 1 axis offsets
                    G10 P1 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
                    T0
                    • Ray11undefined
                      Ray11
                      @Phaedrux
                      Later, I did some experiments. It seemed like that whenever the actual bed temperature closed up with the target temperature within 0.5 degC, the print just terminate itself without any warnings.
                        Can you post a photo of how you have the bed wired?
                        • Ray11undefined
                          Ray11
                          @Phaedrux
                          Sorry for the wiring mess, I am still in the process of testing my printer.
                          What I did is I wired a 24 to 12v converter with my power supply and input the 12v into the out_0_power_in. The bed is connected to out_0.
                          • SneakyTikiundefined
                            SneakyTiki
                            I have this exact thing happen to me all the time.
                            I haven't been able to track down exactly why it happens, but for me it seems to revolve around the .gcode file name.
                            I know for sure that certain special characters seems to mess with it (things like $, %, etc.)
                            It seems that length of the filename is a factor (shorter is better.)
                            And it seems that if you are putting files into sub-folders the problem is exacerbated.
                            I've had some files print just fine the first time (right after I upload it), but then when I go to re-print, it does this. And without changing anything, just deleting and re-uploading it will work again. This has only happened with files I've put into sub-folders. I ultimately fixed this behavior by severely shortening the name of the file.
                            I have this using DWC 1.22.6 on a Duet Maestro running firmware v2.03, and remember versions of this behavior as far back as 1.19 on a Duet 2 WiFi and Duet 2 Ethernet (when I first started using Duet boards)
                            I would try deleting the file, renaming it to something very short and simple, and uploading again.
                            Hope this helps.
                              Phaedrux Moderator @SneakyTiki
                              @SneakyTiki said in DWC Randomly terminate print at start:
                              I'd have to go reread all the releases notes to be sure but I think some of this was resolved since then. Have you tried recently with DWC 2 and RRF 2.05?
                              SneakyTikiundefined 1 Reply Last reply Reply Quote 0
                              • Ray11undefined
                                Ray11
                                @SneakyTiki I recently updated to DWC 2.1.0 and beside the instant termination problem, the manual extrusion also seemed not working even if I heated the hotend up already. I mean I did write some macros to get around this but I wonder if this is a problem related to printers with multiple nozzles?
                                  @Ray11 I believe that was fixed with DWC 2.1.1
                                    SneakyTiki @Phaedrux
                                    @Phaedrux said in DWC Randomly terminate print at start:
                                    I have not, but thanks for letting me know. I'll check it out at some point when I can afford some down-time 🙂
