    Oddly shaped holes?
    106
    6.1k
    • gtj0undefined
      gtj0 @mrehorstdmd
      @mrehorstdmd Yeah isn't the definition of insanity "doing the same thing over and over again and expecting a different result"? 🙂 Still, as I've said in other posts, I learned a great deal in that exercise and would not trade it for anything. Some day someone will do something that "has been done 1000 times before" and discover something new.
      • mrehorstdmdundefined
        mrehorstdmd @gtj0
        @gtj0 If you can gain the knowledge by reading, watching a youtube video, or even just thinking a problem through, is it worthwhile to spend time and money testing the failure yourself? The whole point of people bothering to publish their results is to show others how something can be done or to show how something doesn't work so others don't have to duplicate the same errors/failure. That's the way progress is made. If everyone had to reinvent the wheel every time they needed a wheel, we'd still be living in caves.
        "Some day someone will do something that "has been done 1000 times before" and discover something new."
        No, they won't. Not if they do it the same way those 1000 other people did it. No one who knows what a hammer is has to hit their thumb with it to know it's going to hurt. You can try 1000...00 times and it's going to hurt every time.
        Phaedruxundefined gtj0undefined 2 Replies Last reply Reply Quote 0
        • arhiundefined
          arhi
          But many others have tried before with the same results.
          hm, I have igus on my M150 and it works flawlesly. not only it is silent I got rid of all the ringing I had with linear bearings fore that .. I changed to igus 'cause I seen some superb results from other ppl so I would not agree that it's a given that igus will bring you problem
            Phaedrux Moderator @mrehorstdmd
            @mrehorstdmd said in Oddly shaped holes?:
            Sometimes! I find the spark of creativity only comes when you're bashing your head against a problem with your own bare hands. Reading about it just doesn't generate the brain activity needed.
              mrehorstdmd @arhi
              @arhi I have no doubt that they can be made to work, especially if you follow the manufacturer's recommended methods of using them, which few people building 3D printers do.
              • gtj0undefined
                gtj0 @mrehorstdmd
                @mrehorstdmd The dozen or so patents I have are all for stuff others tried and found impossible to do. 🙂
                @Phaedrux +1
                  mrehorstdmd @gtj0
                  @gtj0 They don't hand out patents for doing the same thing everyone else has done.
                  • gtj0undefined
                    gtj0 @mrehorstdmd
                    No but people who try and fail don't usually apply for a patent. 🙂
                    All I'm saying is that there can be value in trying something that others have failed at. Maybe it's just personal growth or maybe the 1001th person will be smarter than the previous 1000. Or maybe it's just wasted time and money. Who knows?
                    Anyway I think we've probably derailed this thread enough. Sorry guys.
                    • Surgikillundefined
                      Surgikill @mrehorstdmd
                      @mrehorstdmd In my case, I watched a guy on youtube who had great success with the CF rods and IGUS bushings, so that's why I went with it. That was the only time I had seen it done.
                        mrehorstdmd @Surgikill
                        @Surgikill Well, that's the problem, isn't it? People post a snap-shot of their work at one point in time. Maybe after using it a while, they discover that it wears out quickly, or maybe they left out some details in what they did, so their result isn't reproducible. Details matter, but details are boring, so they are often left out. Getting something to work long enough to shoot a video and getting it to work for 5 years are two different problems. Few go back to show if something went wrong and what went wrong or why.
                        If you look at the printers people build from BOMs and plans posted around the web, you'll see a lot of variation in the final printer even though people built from the same plans/BOM. People make substitutions when they can't locate a specific part, or design changes when think they have a better way to do something, or their printed part quality doesn't match the original, or their assembly technique was different/sloppy, so everyone's Voron (just to choose a popular design) looks different from everyone elses, and some of them work and some don't. Details matter, especially in precision mechanisms like 3D printers.
                        CF rods and tubes aren't generally made for use as linear guides. The manufacturing techniques used to produce them don't generally result in precision surfaces or accurate shape or diameter.
                        What is the reason to substitute CF rods/tubes and plastic bushings for proper linear guides in a 3D printer?
                        What is the reason to substitute CF rod/tubes for the guide rails that the plastic bushings are specifically made to work with?
                        What are the chances that combining some random CF rod/tube, not made for precision linear guidance, with some random plastic bushing, will result in the precision linear motion needed in a 3D printer?
