2 weeks and already went bad? Duet 2 Wifi?
can you disconnect the hotend thermistor and measure the resistance across the connector with a multimeter? you should get to the terminals on the inside from the back side of the connector. it should read close-ish to 100k most likely.
then (with power off) measure from the vssa pin on the thermistor header on the board and to the Vin ground. (ref wiring diagram) it should be close to 0.
@bearer said in 2 weeks and already went bad? Duet 2 Wifi?:
115k on thermistor, VSSA to V-in Gnd 1 ohm
that should be all good.
maybe add your config and any config-override file, but given the description not sure its a config issue
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 04 2020 15:16:06 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"Tronxy X5ST-500" ; set printer nameM667 S1 ; select CoreXY mode
M550 PTronxy X5S ; Set machine name
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S1 ; physical drive 2 goes backwards
M569 P3 S1 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E142.00 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
M906 X1680 Y1680 Z1680 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y500 Z600 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; set active low and disabled endstops; Z-Probe
M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P600 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
;M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
;M143 H0 S120 ; set temperature limit for heater 0 to 120C
;M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
;M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@bearer No overrides
@EzeE said in 2 weeks and already went bad? Duet 2 Wifi?:
Also now when I try to home Y access I get a message saying phase A may be disconnected while it actually runs X motor and not Y.
thats kinda relevant i suspect, but i'll defer to the others for config and corexy stuff.
meanwhile, maybe throw in the homeall, homex and homey files
; homex.g
; called to home the X axis
G91 ; relative positioning
G1 H1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 H1 Z-605 F1800 ; move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
Check your wiring. With CoreXY two motors produce the X and Y motion, not just one. So if only one is moving and it's complaining that there may be phases disconnected, it's probably right. Check you crimps on the motors cables.
This post is deleted! -
@Phaedrux @Phaedrux said in 2 weeks and already went bad? Duet 2 Wifi?:
Not sure exactly what you mean about checking the wiring they were working fine, no nicks felt wires look the same, none are loose. When I would hit home previous times it would move the Y motor just fine in fact it moved and homed it prior to the print. Now it throws an error and the X motor turns on when I hit home on the Y with no changes in wiring. Crimps look tight, I assumed they would I used proper crimping tool.
Also again Hotbed and Hotend both started reading 2k at same time, and z probe not working. I thought Z-probe was just cheap and I was using z-stop instead so didn't think much of it since I was going to replace with a BL-touch.
Hitting E-stop on webpage should not cause a board to wig out. If it does cause Duet problems why is it there?
@Phaedrux I also understand that the X and Y motors produce the movement. If I take the belt off the y motor is does not spin. If I move my z cable to the Y motor it spins. If I use Y cable on X motor it spins. If I plug any motor into Y port it does not spin.
It sounds like you've had a failure of the Y driver for sure. Possibly more.
Can you post some close up well lit high res photos of the board? Do you see any areas that look damaged, burnt, etc?
@Phaedrux I'll take some pictures just post them here? Nothing looks burned that I can tell, I do know I do not smell any of that lovely ozone of burnt electronics.
Yes please post them here, or on an online file sharing folder like dropbox or google drive.
@Phaedrux Hopefully this works
https://drive.google.com/file/d/1l2wgaa3ZwHttCgenJIocm9l2QrbCGfBl/view?usp=sharing
https://drive.google.com/file/d/12Wt7HpUuwI5AxnGoN1vUtaYQgV5DXQV4/view?usp=sharing
https://drive.google.com/file/d/1maniM2el2XS4bAmyNfQ9xHAxUgfsI_gy/view?usp=sharing
https://drive.google.com/file/d/1A0D3gYaJUDsKnR63bWMDxyIBUiGFhl0R/view?usp=sharing
https://drive.google.com/file/d/1byWBEEtQa-88TeLkCA9kk5uMx245rpxX/view?usp=sharing
https://drive.google.com/file/d/1dD33aAgnptyP5pg68S3bUfBujc2Z32J4/view?usp=sharing
https://drive.google.com/file/d/1HD7ZJEE6i7H-KXD0x2lMC1UCaxksfRVa/view?usp=sharing -
I can't see any obvious signs of burnt chips.
Are you using the nylon washers to isolate the board from the mounting screws?
yes I am using nylon washers and stand off posts
@dc42 , does this quality for warranty replacement?
I started a print and the bed did not trip my z stop
What exactly do you mean by this? Was there a head crash? The Y driver not working is one thing, but the thermistor reading 2000 would indicate a possible short.
So when I started the print the X, Y, and Z all homed properly. The Z axis moved down and the extruder moved to the center of the bed. What should have happened but didn't is the Z should have moved up which usually trips Z sensor. Instead it sat there like it maybe thought it made the move and then started extruding with the bed not in place. Which is why I tripped the stop.
The Z not moving into position could be my fault since I unplugged z probe since it stopped working, but code is still in there.
There was no bed crash.
