    2 weeks and already went bad? Duet 2 Wifi?
    1.4k
    • EzeEundefined
      EzeE @A Former User
      @bearer No overrides
        A Former User @EzeE
        @EzeE said in 2 weeks and already went bad? Duet 2 Wifi?:
        Also now when I try to home Y access I get a message saying phase A may be disconnected while it actually runs X motor and not Y.
        M667 S1 ; select CoreXY mode
        thats kinda relevant i suspect, but i'll defer to the others for config and corexy stuff.
        meanwhile, maybe throw in the homeall, homex and homey files
        • EzeEundefined
          EzeE
          ; homex.g
          ; called to home the X axis
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 04 2020 15:16:06 GMT-0700 (Pacific Daylight Time)
          G91 ; relative positioning
          G1 H1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 X5 F6000 ; go back a few mm
          G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-5 F6000 ; lower Z again
          G90 ; absolute positioning
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 Y5 F6000 ; go back a few mm
          G1 H1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
          G1 H1 Z-605 F1800 ; move Z down until the endstop is triggered
          G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
            Check your wiring. With CoreXY two motors produce the X and Y motion, not just one. So if only one is moving and it's complaining that there may be phases disconnected, it's probably right. Check you crimps on the motors cables.
            EzeEundefined 3 Replies Last reply Reply Quote 0
            • EzeEundefined
              EzeE @Phaedrux
              This post is deleted!
              • EzeEundefined
                EzeE @Phaedrux
                @Phaedrux @Phaedrux said in 2 weeks and already went bad? Duet 2 Wifi?:
                Not sure exactly what you mean about checking the wiring they were working fine, no nicks felt wires look the same, none are loose. When I would hit home previous times it would move the Y motor just fine in fact it moved and homed it prior to the print. Now it throws an error and the X motor turns on when I hit home on the Y with no changes in wiring. Crimps look tight, I assumed they would I used proper crimping tool.
                Also again Hotbed and Hotend both started reading 2k at same time, and z probe not working. I thought Z-probe was just cheap and I was using z-stop instead so didn't think much of it since I was going to replace with a BL-touch.
                Hitting E-stop on webpage should not cause a board to wig out. If it does cause Duet problems why is it there?
                • EzeEundefined
                  EzeE @Phaedrux
                  @Phaedrux I also understand that the X and Y motors produce the movement. If I take the belt off the y motor is does not spin. If I move my z cable to the Y motor it spins. If I use Y cable on X motor it spins. If I plug any motor into Y port it does not spin.
                    It sounds like you've had a failure of the Y driver for sure. Possibly more.
                    Can you post some close up well lit high res photos of the board? Do you see any areas that look damaged, burnt, etc?
                    EzeEundefined 1 Reply Last reply Reply Quote 0
                    • EzeEundefined
                      EzeE @Phaedrux
                      @Phaedrux I'll take some pictures just post them here? Nothing looks burned that I can tell, I do know I do not smell any of that lovely ozone of burnt electronics.
                        Yes please post them here, or on an online file sharing folder like dropbox or google drive.
                        • EzeEundefined
                          EzeE @Phaedrux
                          @Phaedrux Hopefully this works
                          https://drive.google.com/file/d/1l2wgaa3ZwHttCgenJIocm9l2QrbCGfBl/view?usp=sharing
                          https://drive.google.com/file/d/12Wt7HpUuwI5AxnGoN1vUtaYQgV5DXQV4/view?usp=sharing
                          https://drive.google.com/file/d/1maniM2el2XS4bAmyNfQ9xHAxUgfsI_gy/view?usp=sharing
                          https://drive.google.com/file/d/1A0D3gYaJUDsKnR63bWMDxyIBUiGFhl0R/view?usp=sharing
                          https://drive.google.com/file/d/1byWBEEtQa-88TeLkCA9kk5uMx245rpxX/view?usp=sharing
                          https://drive.google.com/file/d/1dD33aAgnptyP5pg68S3bUfBujc2Z32J4/view?usp=sharing
                          https://drive.google.com/file/d/1HD7ZJEE6i7H-KXD0x2lMC1UCaxksfRVa/view?usp=sharing
                            I can't see any obvious signs of burnt chips.
                            Are you using the nylon washers to isolate the board from the mounting screws?
                            • EzeEundefined
                              EzeE
                              yes I am using nylon washers and stand off posts
                              • elmoretundefined
                                elmoret
                                @dc42 , does this quality for warranty replacement?
                                  Phaedrux Moderator @EzeE
                                  I started a print and the bed did not trip my z stop
                                  What exactly do you mean by this? Was there a head crash? The Y driver not working is one thing, but the thermistor reading 2000 would indicate a possible short.
                                  • EzeEundefined
                                    EzeE @Phaedrux
                                    @Phaedrux
                                    So when I started the print the X, Y, and Z all homed properly. The Z axis moved down and the extruder moved to the center of the bed. What should have happened but didn't is the Z should have moved up which usually trips Z sensor. Instead it sat there like it maybe thought it made the move and then started extruding with the bed not in place. Which is why I tripped the stop.
                                    The Z not moving into position could be my fault since I unplugged z probe since it stopped working, but code is still in there.
                                    There was no bed crash.
                                    • EzeEundefined
                                      EzeE @Phaedrux
                                      @Phaedrux
                                      Also when the Hot end started reading 2l the Bed went to 2k as well.
                                      • EzeEundefined
                                        EzeE @Phaedrux
                                        @Phaedrux
                                        Just fixed the Thermistors reading 2k. Found an old post about a delta printer having similar issue and the M305 lines being commented out. Scrolled up to look at config.g I posted and my M305 were commented. Loaded the backed up config.g file from printer and readings are 21 degrees idle.
                                        So now just the Y not working. And possibly z-probe.
                                          droftarts administrators @EzeE
                                          @EzeE Please send M115 to the Duet, and post reply, to report the firmware version.
                                          Were the X and Y axes moving particularly fast when you pressed estop? What motors do you have on X and Y? Standard TronXY X5ST-500? I notice you have the max speed, accelerations and motor currents set quite high:
                                          M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                          M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
                                          M201 X3000.00 Y3000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                                          M906 X1680 Y1680 Z1680 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                                          Thinking maybe sudden stop during fast move caused a voltage spike back through the driver, killing the driver.
                                          EzeEundefined 2 Replies Last reply Reply Quote 0
                                            @Phaedrux
                                            So... how did you manage to start the print? Did you send the M305 commands by hand? And I thought you said the probe wasn't working anyway (which is why it started printing 6mm off the bed)?
