    2 weeks and already went bad? Duet 2 Wifi?
    1.4k
    • EzeEundefined
      EzeE @Phaedrux
      @Phaedrux @Phaedrux said in 2 weeks and already went bad? Duet 2 Wifi?:
      @EzeE said in 2 weeks and already went bad? Duet 2 Wifi?:
      Also now when I try to home Y access I get a message saying phase A may be disconnected while it actually runs X motor and not Y.
      Check your wiring. With CoreXY two motors produce the X and Y motion, not just one. So if only one is moving and it's complaining that there may be phases disconnected, it's probably right. Check you crimps on the motors cables.
      Not sure exactly what you mean about checking the wiring they were working fine, no nicks felt wires look the same, none are loose. When I would hit home previous times it would move the Y motor just fine in fact it moved and homed it prior to the print. Now it throws an error and the X motor turns on when I hit home on the Y with no changes in wiring. Crimps look tight, I assumed they would I used proper crimping tool.
      Also again Hotbed and Hotend both started reading 2k at same time, and z probe not working. I thought Z-probe was just cheap and I was using z-stop instead so didn't think much of it since I was going to replace with a BL-touch.
      Hitting E-stop on webpage should not cause a board to wig out. If it does cause Duet problems why is it there?
      • EzeEundefined
        EzeE @Phaedrux
        @Phaedrux I also understand that the X and Y motors produce the movement. If I take the belt off the y motor is does not spin. If I move my z cable to the Y motor it spins. If I use Y cable on X motor it spins. If I plug any motor into Y port it does not spin.
          It sounds like you've had a failure of the Y driver for sure. Possibly more.
          Can you post some close up well lit high res photos of the board? Do you see any areas that look damaged, burnt, etc?
          EzeEundefined 1 Reply Last reply Reply Quote 0
          • EzeEundefined
            EzeE @Phaedrux
            @Phaedrux I'll take some pictures just post them here? Nothing looks burned that I can tell, I do know I do not smell any of that lovely ozone of burnt electronics.
              Yes please post them here, or on an online file sharing folder like dropbox or google drive.
              • EzeEundefined
                EzeE @Phaedrux
                @Phaedrux Hopefully this works
                https://drive.google.com/file/d/1l2wgaa3ZwHttCgenJIocm9l2QrbCGfBl/view?usp=sharing
                https://drive.google.com/file/d/12Wt7HpUuwI5AxnGoN1vUtaYQgV5DXQV4/view?usp=sharing
                https://drive.google.com/file/d/1maniM2el2XS4bAmyNfQ9xHAxUgfsI_gy/view?usp=sharing
                https://drive.google.com/file/d/1A0D3gYaJUDsKnR63bWMDxyIBUiGFhl0R/view?usp=sharing
                https://drive.google.com/file/d/1byWBEEtQa-88TeLkCA9kk5uMx245rpxX/view?usp=sharing
                https://drive.google.com/file/d/1dD33aAgnptyP5pg68S3bUfBujc2Z32J4/view?usp=sharing
                https://drive.google.com/file/d/1HD7ZJEE6i7H-KXD0x2lMC1UCaxksfRVa/view?usp=sharing
                  I can't see any obvious signs of burnt chips.
                  Are you using the nylon washers to isolate the board from the mounting screws?
                  • EzeEundefined
                    EzeE
                    yes I am using nylon washers and stand off posts
                    • elmoretundefined
                      elmoret
                      @dc42 , does this quality for warranty replacement?
                        Phaedrux Moderator @EzeE
                        I started a print and the bed did not trip my z stop
                        What exactly do you mean by this? Was there a head crash? The Y driver not working is one thing, but the thermistor reading 2000 would indicate a possible short.
                        EzeEundefined 3 Replies Last reply Reply Quote 0
                        • EzeEundefined
                          EzeE @Phaedrux
                          @Phaedrux
                          So when I started the print the X, Y, and Z all homed properly. The Z axis moved down and the extruder moved to the center of the bed. What should have happened but didn't is the Z should have moved up which usually trips Z sensor. Instead it sat there like it maybe thought it made the move and then started extruding with the bed not in place. Which is why I tripped the stop.
                          The Z not moving into position could be my fault since I unplugged z probe since it stopped working, but code is still in there.
                          There was no bed crash.
                          • EzeEundefined
                            EzeE @Phaedrux
                            @Phaedrux
                            Also when the Hot end started reading 2l the Bed went to 2k as well.
                            • EzeEundefined
                              EzeE @Phaedrux
                              @Phaedrux
                              Just fixed the Thermistors reading 2k. Found an old post about a delta printer having similar issue and the M305 lines being commented out. Scrolled up to look at config.g I posted and my M305 were commented. Loaded the backed up config.g file from printer and readings are 21 degrees idle.
                              So now just the Y not working. And possibly z-probe.
                                droftarts administrators @EzeE
                                @EzeE Please send M115 to the Duet, and post reply, to report the firmware version.
                                Were the X and Y axes moving particularly fast when you pressed estop? What motors do you have on X and Y? Standard TronXY X5ST-500? I notice you have the max speed, accelerations and motor currents set quite high:
                                M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
                                M201 X3000.00 Y3000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                                M906 X1680 Y1680 Z1680 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                                Thinking maybe sudden stop during fast move caused a voltage spike back through the driver, killing the driver.
                                EzeEundefined 2 Replies Last reply Reply Quote 0
                                  @Phaedrux
                                  So... how did you manage to start the print? Did you send the M305 commands by hand? And I thought you said the probe wasn't working anyway (which is why it started printing 6mm off the bed)?
                                  • EzeEundefined
                                    EzeE @droftarts
                                    @droftarts
                                    The z probe worked for couple days then stopped. so I unplugged it while I await a new one one. I set it in slicer to move down 6mm for initial move to center then up 6mm to start the print.
                                    No I loaded my backed up config.g which do not have the lines commented out. I'm not entirely sure how they got commented out in the first place. That is one I will be pondering for awhile.
                                    Is it possible it somehow loaded the config.g.bak? I wouldn't think so but at this point I'm really confused.
                                    • EzeEundefined
                                      EzeE @droftarts
                                      @droftarts
                                      It just started initial extrusion and brim print so not fast at all.
                                      Motors are SL42STH40-1684A
                                      I looked at RepRap.org chart to get rates currents which it shows listed at 1.68 Amps
                                      • EzeEundefined
                                        EzeE @droftarts
                                        @droftarts
                                        4/21/2020, 2:46:28 PM M115
                                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-12-13b1
                                        droftartsundefined 2 Replies Last reply Reply Quote 0
                                          @droftarts
                                          You shouldn't run motors at 100% of their rated current; they will get hot quickly. The recommendation is 50 to 85% of their current, so 840mA to 1420mA. See https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Rated_current
                                          But it's unlikely this will have burnt out the driver, just got the motor hot.
                                            @EzeE To get you up and running again, as you have a spare driver on the Duet, plug the Y axis into E1, and change the M584 line in your config.g to:
                                            M584 X0 Y4 Z2 E3 ; set drive mapping
                                            config.g is the file that is used at startup. Unless another file is called . I expect you commented out the temperature and heater lines (M305 and M143) instead of the Z probe lines by mistake, when your probe stopped working.
                                            For your probe, check the continuity of the wiring; sounds more like a loose connection or bad joint. What probe is it, and how was it connected? See: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                                            Or, until you get your BLTouch, you could set the probe type to P0, which is manual probing. When a G30 command is encountered, a popup shows in DWC, asking you to jog the hot end until it touches the bed, so you set it manually.
