RepPanel - A DIY alternative to the PanelDue with WiFi support
Third-party software
39
243
30.0k
    Danal
    If you want to make it work with both RRF2 and 3, here is a possible jump start:
    https://github.com/DanalEstes/DuetWebAPI/blob/master/DuetWebAPI.py
    It is a little abstraction layer I wrote for that very purpose. Absolutely NOT a general interface, just a set of methods that work on both releases.
      dragonn
      It looks really nice, polished. But I don't like have it WiFi connected. Do you plan also supporting serial connection to Duet?
      undefined 1 Reply Last reply 31 Mar 2020, 06:24 Reply Quote 0
        seeul8er @dragonn
        @dragonn Planned ✅
        @Danal I am using the same calls as DWC for getting the data in WiFi mode. Seems the requests (rr_gcode etc.) haven't changed.
        undefined 1 Reply Last reply 31 Mar 2020, 06:46 Reply Quote 1
          Danal @seeul8er
          @seeul8er said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
          @dragonn Planned ✅
          Agreed. Network type, WiFi v Ether v ... is not relevant. the /rr_commands work via any form of IP connectivity.
          However, I was referring to V2 firmware vs V3 firmware. The calls are different for V3, and so is the returned JSON object.
            A Former User
            I think I'd opted for a optional $2-3 DT-06 wifi module with esp-link firmware or something to plug into the PanelDue port. Would give you the same g-code interface to deal with regardless of wired, wireless, rrf2 or rrf3.
            Looks good though!
              bberger
              Can you send me a few links for sourcing the hardware please. I want in on that project. This is exactly what I have been looking for and thinking about the past few weeks!
              AWESOME!
              undefined 1 Reply Last reply 1 Apr 2020, 06:00 Reply Quote 0
                seeul8er @bberger
                @bberger Cool! It's all in the GitHub repo, but I sent you a PM.
                undefined 1 Reply Last reply 1 Apr 2020, 09:09 Reply Quote 0
                  droftarts administrators @seeul8er
                  @seeul8er Someone (probably @Phaedrux) has added this to https://duet3d.dozuki.com/c/Community_Projects
                  undefined 1 Reply Last reply 1 Apr 2020, 13:00 Reply Quote 0
                    seeul8er @droftarts
                    @droftarts NIce. I'm OK with that 👍
                      Colten
                      seems to be some issues compiling what is in the git repo under windows. some define's and some missing font functions. I don't know enough about idf.py to begin fixing the issue however.
                      undefined 1 Reply Last reply 27 Apr 2020, 09:23 Reply Quote 0
                        seeul8er @Colten
                        @Colten I know. Should be fixed within the development branch. The current way is that you need to copy file content of main/lv_conf_back.hover to externals/lv_port_esp32/components/lvgl/lv_conf.h. You can find lv_conf_back.h in the dev branch.
                          seeul8er
                          Hi guys!
                          I am very happy to finally release v1.0.0 of RepPanel. It now supports UART/PanelDue wired connections as well as WiFi. All connections can be hot-swapped.
                          I also fixed lots of bugs related to memory issues. You can now have up to 16 macros/jobs per directory with file names up to 63 characters.
                          RepPanel with prototype case
                          I also tried to design the first prototype for a case. Still needs some tiny improvements but it already is very compact and clean. Together with a simple circuit board it is only 25mm thick. The images do not reflect the quality of the screen well. In reality, the contrast is a lot better.
                          1 Reply Last reply Reply Quote 5
                            seeul8er
                            First release of RepPanel
                            First test of RepPanel
                              pd
                              Hi
                              I have just started trying to get this to work as I have several applications. I have flashed the software onto an ESP devkit and connected your recommended screen. I have not however connected it to a duet board. I had hoped at least part of the screen would show up but I only get a faint outline in the top left hand corner. I suspect I have made a mistake in connecting to the screen but I would be grateful if you would confirm that is the case. Or does the duet need to be connected.
                                pandaym
                                Anywhere to get working hardware for this inside the EU?
                                  seeul8er
                                  @pd Sorry for the late reply! Can you share the link to your display, because there are multiple very similar versions of it and I already had a user that bought the wrong one 😞 I clarified it inside the GitHub project page. Can you also share the wiring and a picture of what you can see on screen?
                                  It is not necessary to connect the Duet. The app should start anyways.
                                  @pandaym Hi, the ESP32 is not an issue since it is generally available. I ordered the display directly from china. Since it was below 22€ it is tax free and shipping was OK-fast. There may be other ili9488 displays with SPI (+ supported touch controller) and the same resolution that work and that you can get within the EU. However, I have not tested any of them.
                                  undefined 2 Replies Last reply 29 Jun 2020, 18:06 Reply Quote 0
                                  • PCRundefined
                                    PCR
                                    Dear @seeul8er ,
                                    would you be intrested in a PCB. I will order some PCBs for other projects in China. If you want i could design one!
                                    Best
                                    Peter
                                    undefined 1 Reply Last reply 22 Jun 2020, 11:37 Reply Quote 1
                                      seeul8er @PCR
                                      @PCR I already thought about it but wanted to keep it as simple as possbile for others to follow for now. Non the less a custom PBC would be awesome!
                                      And if you are willing to give it a try why not.
                                      With that we would get a couple of options to choose from. We could dump the pin headers of the TFT module and use an FCC cable. The DevKit would also not be necessary since the ESP module could be soldered directly to the PCB. Or keep the devkit and and solder it to the PCB since it offers USB power and serial for a low price.
                                      The software does only support SPI connections so a 8bit parallel interface is currently not possible.
                                      ? 1 Reply Last reply 22 Jun 2020, 11:43 Reply Quote 0
                                        A Former User @seeul8er
                                        how much flash do you need? (ESP8285 is cheaper and smaller but only 1MB)
                                        undefined 1 Reply Last reply 22 Jun 2020, 12:16 Reply Quote 0
                                          seeul8er @A Former User
                                          @bearer Hardware-wise the ESP8285 is not enough (especially RAM - kind of maxed out on the ESP32). The image needs 1.4 MB at the moment. The software only supports the ESP32.
