    Print stuttering around curves, LaErrors
    58
    4.1k
    • Charlieundefined
      Charlie
      Are you sure that your M350 commands are all after your M584 commands?
      • Charlieundefined
        Charlie
        As an update, decreasing extruder jerk did not improve or worsen the artifacts. The issue persists.
          I'm about to try a print. The mesh isn't very high resolution though so the curves are pretty facetted.
            === DDARing ===
            Scheduled moves: 11250, completed moves: 11225, StepErrors: 0, LaErrors: 1, Underruns: 34, 0
            Only a few minutes into the print and there is 1 La error and a few under runs.
            • Charlieundefined
              Charlie
              Changing X, Y, and E instantaneous speed (jerk) settings dramatically (both high and low) did not affect the outcome.
              Changing pressure advance mid print (through M572 command on the gcode console during the print) also did not change the fact that it still stopped while traveling around the large radius arcs.
              Below is a link to the GCode for the affected print.
              https://drive.google.com/file/d/17gsPftKUcRSPVDl176A_GBqD7sG8GH9i/view?usp=sharing
              Please let me know if there is a better way to post gcode, as it exceeded the maximum file size for uploading.
                From the end of the print:
                === DDARing === Scheduled moves: 18, completed moves: 18, StepErrors: 0, LaErrors: 14, Underruns: 698, 0
                m122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                Board ID: 08DDM-9FAM2-LW4SD-6JKF0-3SN6N-T2ZBY
                Used output buffers: 1 of 24 (16 max)
                Static ram: 25712
                Dynamic ram: 93328 of which 228 recycled
                Exception stack ram used: 544
                Never used ram: 11260
                Tasks: NETWORK(ready,628) HEAT(blocked,1176) MAIN(running,3728) IDLE(ready,160)
                Owned mutexes:
                Last reset 03:48:36 ago, cause: power up
                Last software reset at 2020-03-30 17:04, reason: User, spinning module GCodes, available RAM 11148 bytes (slot 2)
                Error status: 0
                Free file entries: 10
                MCU temperature: min 27.2, current 29.2, max 30.7
                Supply voltage: min 23.7, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, SG min/max 0/1023
                Driver 1: standstill, SG min/max 0/1023
                Driver 2: standstill, SG min/max 0/279
                Driver 3: standstill, SG min/max 0/1023
                Date/time: 2020-04-26 19:43:09
                Slowest loop: 67.26ms; fastest: 0.07ms
                Hiccups: 0, FreeDm: 160, MinFreeDm: 98, MaxWait: 60049ms
                === DDARing ===
                Heater 0 is on, I-accum = 0.2
                Heater 1 is on, I-accum = 0.4
                Segments left: 0
                Stack records: 3 allocated, 0 in use
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 200.47ms; fastest: 0.08ms
                HTTP sessions: 1 of 8
                - WiFi -
                Network state is running
                Failed messages: pending 0, notready 0, noresp 2
                WiFi firmware version 1.23
                WiFi MAC address 5c:cf:7f:ef:4a:74
                WiFi Vcc 3.31, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 24512
                WiFi IP address 10.10.0.95
                WiFi signal strength -44dBm, reconnections 0, sleep mode modem
                I did not have any of the pausing I saw previously on the more detailed mesh.
                • Charlieundefined
                  Charlie
                  @Phaedrux Hmmm, seems like you still have LA Errors, though you didn't have any pausing. If you are using Cura, may I ask what your Maximum Resolution, Maximum Travel Resolution, and Maximum Deviation settings are? Mine are 0.833 mm, 0.7 mm, and 0.015 mm respectively. Do you think that this may be the cause of my issue? They may be too low.
                  NitroFreakundefined 1 Reply Last reply Reply Quote 0
                    No stutters this time, but the model was very low res by comparison. In the next couple days I'll be printing another bunch of high resolution curved models. I'll check again then.
                    Max res : 0.05
                    Max travel res 0.1094
                    Max deviation 0.05
                    And this last print was with that custom cura build from just the other day. Maybe give that build a try.
                    • NitroFreakundefined
                      NitroFreak @Charlie
                      @Charlie said in Print stuttering around curves, LaErrors:
                      I also had this suspicion per this video
                      https://www.youtube.com/watch?v=Hvw3DrVAeTA
                      I changed my values to 1.133, 0,75 and 0.075 respectively. No change in the stuttering.
                      Also, it is weird because the duet being 32 bit should not really have this problem?
                        NitroFreak
                        I´ve now captured it on video so that it´s easy to see.
                        100mm circle, 2 perimeters, no infill, Z seam always at the front.
                        I dropped the Z axis steps back to x16 and 800 steps /mm. Yes i did use Z hop but i can´t imagine how that would affect a mid layer line.
                        https://youtu.be/IbhTUJ972cE
                        It is really weird because i used to be able to print at 250mm/sec no problem.
                        https://www.youtube.com/watch?v=o-Qg3nTha1A
                        After that I didnt really change anything apart from some tpre, tfree and tpost files. But this is all single extrusion.
                        Here is another M122 after the circle
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
                        Board ID: 08DGM-917NK-F23T0-6J9DJ-3S86S-TWBWD
                        Used output buffers: 3 of 24 (16 max)
                        Static ram: 25680
                        Dynamic ram: 94004 of which 0 recycled
                        Exception stack ram used: 476
                        Never used ram: 10912
                        Tasks: NETWORK(ready,648) HEAT(blocked,1172) MAIN(running,3748) IDLE(ready,160)
                        Owned mutexes:
                        Last reset 00:29:05 ago, cause: software
                        Last software reset at 2020-04-27 10:32, reason: User, spinning module GCodes, available RAM 11076 bytes (slot 3)
                        Error status: 0
                        MCU temperature: min 36.7, current 38.2, max 40.0
                        Supply voltage: min 24.3, current 24.6, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 2: standstill, SG min/max 0/249
                        Date/time: 2020-04-27 11:02:02
                        Slowest loop: 43.29ms; fastest: 0.08ms
                        Hiccups: 1415, FreeDm: 169, MinFreeDm: 134, MaxWait: 32660ms
                        === DDARing ===
                        Scheduled moves: 6, completed moves: 6, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                        Heater 0 is on, I-accum = 0.3
                        Segments left: 0
                        === Network ===
                        Slowest loop: 202.38ms; fastest: 0.08ms
                        • WiFi -
                          Failed messages: pending 0, notready 0, noresp 1
                          WiFi MAC address b4:e6:2d:52:f6:45
                          WiFi Vcc 3.34, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 25032
                          WiFi IP address 192.168.0.93
                          WiFi signal strength -58dBm, reconnections 0, sleep mode modem
                        And here is my config.g
                        ; generated by RepRapFirmware Configuration Tool v2 on Sun Feb 03 2019 22:30:32 GMT+0100 (Central European Standard Time)
                        G90                                             ; Send absolute coordinates...
                        M83                                             ; ...but relative extruder moves
                        M550 P"ARPEG"                                   ; Set machine name
                        M552 S1                                         ; Enable network
                        M587 S"KDG-4F519" P"ApbjYbr9nQu7"               ; Configure access point. You can delete this line once connected
                        M586 P0 S1                                      ; Enable HTTP
                        M586 P1 S0                                      ; Disable FTP
                        M586 P2 S0                                      ; Disable Telnet
                        M569 P0 S1                                      ; Drive 0 goes forwards (X1)
                        M569 P1 S1                                      ; Drive 1 goes forwards (X2)
                        M569 P2 S0                                      ; Drive 2 goes backwards (Z)
                        M569 P3 S1                                      ; Drive 3 goes forwards extruder
                        M569 P4 S1                                      ; Drive 4 goes backwards extruder 2
                        M569 P5 S0 T8:8:8:8                             ; Drive 5 minimum step pulse timing 3 microseconds (JMC servo minimum 2.5 microseconds)
                        M584 X0:1 Y5 Z2 E3:4                            ; Apply custom drive mapping
                        M350 Y1 Z16 ;E16:16I0                           ; Configure microstepping without interpolation
                        M350 X16:16 I1      E16:16 I1                   ; Configure microstepping with interpolation
                        M92 X88.89 Y360.00 Z800.00 E411:430            ; Set steps per mm, mk8 extruder 94.3
                        M566 X1000.00 Y1000.00 Z200.00 E1500.00:1500.00     ; Set maximum instantaneous speed changes (mm/min)
                        M203 X24000.00 Y24000.00 Z2000.00 E4200.00:4200.00 ; Set maximum speeds (mm/min)
                        M201 X5000.00 Y5000.00 Z700.00 E2000.00:1000.00  ; Set accelerations (mm/s^2)
                        M906 X1600.00 Y800.00 Z1100.00 E1100.00:1200.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                        M593 F24.5                                      ; Dynamic Acceleration Adjustment at 24.5 Hertz
                        M572 D0 S0.02                                   ; Pressure advance
                        M84 S30                                         ; Set idle timeout
                        ;M207 S0.2 F1800 Z0.8
                        M208 X5 Y5 Z0 S1                                ; Set axis minima
                        M208 X215 Y255 Z280 S0                          ; Set axis maxima
                        M574 X1 Y1 Z1 S1                                ; Set active high endstops
                        M558 P0 H5 F120 T6000                           ; Disable Z probe but set dive height, probe speed and travel speed
                        M557 X20:170 Y20:195 S20                        ; Define mesh grid
                        M307 H6 A-1 C-1 D-1                             ; Disables heater 6 output as heater output and configures it as General I/O port
                        M307 H7 A-1 C-1 D-1                             ; Disables heater 7 output as heater output and configures it as General I/O port
                        M570 H0 P10 T40                                 ; Lets the chamber deviate a max of 40C for max 10sec from its set temp (to not raise a fault when opening oven door)
                        ;M140 H-1                                       ; Tell the firmware there is no bed heater
                        M307 H0 B0 A188.1 C188.1 D3.5 S1.00             ; Disable bang-bang mode for the bed heater and set PWM limit (G=188.1, tc=275.7, td=-1.6)
                        M305 P0 T100000 B4138 R4700 S"Chamber"          ; Set thermistor + ADC parameters for heater 0
                        M143 H0 S240                                    ; Set temperature limit for heater 0 to 240C
                        M305 P1 X200    S"Model"                                ; Configure thermocouple for heater 1
                        M143 H1 S430                                    ; Set temperature limit for heater 1 to 430C
                        ;M305 P2 T100000 B4138 R4700 S"Support"           ; Configure Thermistor + ADC parameters for heater 2
                        ;M143 H2 S320                                    ; Set temperature limit for heater 2 to 290°C
                        M305 P2 X201    S"Support"                               ; Configure thermocouple for heater 2
                        M143 H2 S430                                   ; Set temperature limit for heater 2 to 430C
                        M307 H1 A225.2 C128.7 D4.1 V24.5 S1.0 B0        ; Set PID parameters for Extruder Heater 1 model: gain 952.0, time constant 389.2, dead time 5.2, max PWM 0.30, calibration voltage 24.3, mode PID, inverted no, frequency default
                        M307 H2 A225.2 C128.7 D4.1 V24.5 S1.0 B0        ; set preliminary PID for support extruder
        ; 12V Hotend autotune 390° while 212° chamber Heater 1 model: gain 495.4, time constant 164.7, dead time 2.9, max PWM 0.50, calibration voltage 23.1,
        ; 24V CTC Heater 1 model: gain 225.2, time constant 128.7, dead time 3.4, max PWM 1.00, calibration voltage 24.5
                        ;M307 H2 A468.7 C131.8 D4.3 V24.5 S0.3 B0         ; Heater 2 model: gain 468.7, time constant 131.8, dead time 4.3, max PWM 0.30, calibration voltage 24.5, (12v heizpatrone im alu block)
                        M106 P0 S0.3 I0 F500 H-1                        ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P1 S1 I0 F500 H1 T45                       ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        M563 P0 S"Model" D0 H1                          ; Define tool 0
                        G10 P0 X0 Y0 Z0                                 ; Set tool 0 axis offsets
                        G10 P0 R0 S0                                    ; Set initial tool 0 active and standby temperatures to 0C
                        M563 P1 S"Support" D1 H2                        ; Define tool 1
                        G10 P1 X24.93 Y1.18 Z-1.2                       ; Set tool 1 axis offsets
                        G10 P1 R0 S0                                    ; Set initial tool 1 active and standby temperatures to 0C
                        T0                                              ; Select first tool
                          NitroFreak
                          I remember, when i did the 250mm/s test, that it started to judder and slow down randomly at around 280mm/s.
                          What can cause the processor to overload like that with just 60mm/s?
                            deckingman @NitroFreak
                            @NitroFreak Your video is very reminiscent of problems I had when pressure advance was first introduced. Although, that was with multiple extruders feeding a mixing hot and with much higher PA values than you are using. Still, I wonder if it might be worth disabling PA just to see if it makes any difference or not?
                              Phaedrux Moderator @NitroFreak
                              @NitroFreak said in Print stuttering around curves, LaErrors:
                              No I don't think that would cause mid layer issues, but skipping steps on a z hop is a recipe for inaccurate layer heights.
                              • Charlieundefined
                                Charlie
                                @NitroFreak I love that channel! Your values are all a little higher than mine so I may want to change mine. But more importantly, I agree that I thought the 32 bit system should solve this issue. Is there any way to know if its an issue due to extensive mesh facets? I have no hiccups or underruns, and I thought that was where you would see the issue, but I must be mistaken.
                                  Do you have another SD card to test with?
                                  • Charlieundefined
                                    Charlie
                                    @Phaedrux Yes, I do have another SD card to test with. I will disable Pressure Advance in the config.g file (I only disabled it mid-print before) and report my findings. My duet is unfortunately buried deep in the printer case (hindsight 20/20, lol) so it may take some time to remove and reinstall the SD.
                                      Phaedrux Moderator @Charlie
                                      M566 X480.00 Y480.00 Z30.00 E10000.00 ; Set maximum instantaneous speed changes (mm/min)
                                      The other thing that occurs to me is low Z jerk value and using mesh compensation. I notice your Z jerk is very very low.
                                        I tried a saved gcode that was showing the slow down/pauses and it's still doing it, though I didn't have any LAErrors. Just some underruns. At least in the first few layers.
                                        Scheduled moves: 8454, completed moves: 8416, StepErrors: 0, LaErrors: 0, Underruns: 15, 0
                                        I resliced the model and printed it again, this time no stutters. The only difference was the Cura build version. The update notes between the two versions says
                                        20200424 - Upstream changes + fix 2 upstream regressions (skirt line print ordering and polygon simplification).
                                        20200328 - Upstream changes + smooth support area outlines to reduce line count (complex outlines will now slice and print faster, gcode size is reduced).
                                        Maybe the polygon simplification is the difference here?
                                        • brismaundefined
                                          brisma
                                          Try with Cura 4.5.0, the new official version 4.6.0 seems bugged.
                                            Underruns are usually caused by one of the following:
                                            • Printing over USB instead of from SD card (most hosts can't supply GCodes fast enough consistently)
                                            • SD card issues. Make sure the SD card is formatted with a high cluster size, preferably 64kb. Also confirm that you are using the built-in SD card of the Duet, because external SD cards use a slower interface.
                                            • Long sequences of very short movements in the GCode. Not usually a problem with modern slicers, but has been in the past especially with Simplify3D.
                                            If you have any small print files that consistent give rise to lookahead errors, please share them.
