    nozzle wipe
    3D Printing General Chat
    14
    83
    6.1k
    • arhiundefined
      arhi
      @deckingman cool, when this whole thing finish I'll try to get one strip 🙂 that looks perfect 🙂
      • arhiundefined
        arhi
        def. has potential but not ideal .. this .6 nozzle is rather leeky need to add some retraction to wipe procedure
        https://youtu.be/ze0WUGS4cQ4
        deckingmanundefined 1 Reply Last reply Reply Quote 1
          deckingman @arhi
          @arhi That video is private so I can't view it. For info, and in case you haven't seen it, you can see mine here from about 1min 40 secs https://www.youtube.com/watch?v=IG3AGKDzdH4
          arhiundefined 1 Reply Last reply Reply Quote 1
          • arhiundefined
            arhi @deckingman
            @deckingman thanks, I clicked on public and did not click on done but save and ... well happens 😄 should be public now 😄
            Yes, I have seen that video, and that's what inspired me to do this wiper in the first place as cleaning nozzle manually before homing is not very efficient due to the position of the printer and since I installed .6 nozzle there if I don't clean it before homing it will have nasty Z offset 😞
            I normally have some type of nozzle cleaner on every printer but I can't say I'm satisfied with any of them :(. This type is not possible on them as, usually, head can't move outside of the printbed area so anything mounted outside of the bed won't work. Here I have few cm so I used them 🙂 ... now just to make it work.
            IMO this will work for now but as soon as I can I'll add a second 2020 along side Y axis to hold on to the proper silicone strip.
            As for the glue, dunno, I think I'll go with mechanical option, silicone, ptfe, pp, hdpe are materials I never had luck gluing.
              deckingman @arhi
              @arhi Ref the YouTube videos - I discovered just the other day that you can also use "unlisted rather than "public". That way, they don't show up in your channel or any searches, but anyone with the link can view. Ref the "mechanical" option - if you had wide enough silicone, you could perhaps screw it to something flat, rather than sandwich it between two plates - might need some big washers. Just a thought........
              • jens55undefined
                jens55
                If you have a U channel, why not use a couple of push pins in previously drilled holes near the top of the U channel as a mechanical fix to prevent the strip from being pushed out?
                  deckingman @jens55
                  @jens55 said in nozzle wipe:
                  That should work. Although in my case, I milled a slot the right size so that the silicone stays put without the need ☺
                  • arhiundefined
                    arhi
                    I modified a bit height of the wiper and the script and I'm super happy with the results 😄
                    code that works
                    wipe.g
                    if !move.axes[0].homed || !move.axes[1].homed
                      echo "X and Y axes not homed, aborting the wipe"
                      M99
                    if sensors.analog[1].lastReading < 200
                      echo "Extruder too cold, no point wiping, aborting the wipe"
                      M99
                    ; Drop all motor currents down
                    M400
                    M913 X30 Y30 Z25
                    ; relative extruder (if I understand how push/pop work in RRF
                    ; this should be returned to what it was on exit from this macro)
                    M83
                    ; Wipe
                    G0 X-110 Y40  F9000
                    G0 X-135 Y40  F9000
                    G0 X-135 Y100 F9000
                    G0 X-90  Y80  F600
                    G0 X-110 Y40  F9000
                    G0 X-135 Y40  F9000
                    G0 X-135 Y100 F9000 E5
                    G0 X-123 Y100 F9000 E-0.2
                    G0 X-123 Y70  F9000 E-0.2
                    G0 X-90  Y100 F9000
                    G0 X-130 Y100 F9000 E-0.1
                    G0 X-130 Y70  F9000 E-0.1
                    G0 X-110 Y40  F9000
                    G0 X-135 Y40  F9000
                    ; Return all motor currents to 100%
                    M400
                    M913 X100 Y100 Z100
                    https://youtu.be/mOiIhcDv36Q
                    @deckingman yeah I know about unlisted but on this YT account I just send stuff and leave them there, nothing to hide, but nothing "consistent". But I used imovie for that prev video to join 2 videos
                      deckingman @arhi
                      @arhi Neat - I really must find time to stat looking at conditional gcode.
                      • Danalundefined
                        Danal
                        This works reasonably well. Orange silicone strip is aircraft baffling material. Just tried it because I have a ton of it. It is stiff enough that when dropped into a three sided slot, it wipes plenty well. Tool mounting always makes three passes over this; no intelligence, just does it every time.
                        0:/sys/tpost0.g
                        ; Runs after firmware thinks Tool0 is selected
                        ; Note: tool offsets are applied at this point!
                        ; Note that commands prefixed with G53 will NOT apply the tool offset.
                        G53 G0 X1        F5000				; Square move to avoid diagonals.
                        G53 G0      Y350 F5000  ; Rapid to the approach position without any current tool.  This lets the human know the next command is waiting on this new tool.
                        M116 H1                 ; Wait for set temperatures to be reached
                        M302 P0                  ; Prevent Cold Extrudes, just in case temp setpoints are at 0
                        G53 G1 Y373 F2500        ; Move to the pickup position with tool0.
                        M98 P"/macros/tool_lock.g" ; Lock the tool
                        G53 G1 Y355 F2500        ; Retract the entire tool and wipe Backwards.
                        G53 G1 Y370 F5000        ; Wipe Forwards.
                        G53 G1 Y355 F5000        ; Wipe Backwards.
                        G53 G1 Y275 F5000       ; Wipe Backwards and get clear of tool row, in case next move is large X move.
                        G1 R2 Z0        ; Restore prior position now accounting for new tool offset
                        Sample resulting print, no cleanup at all, straight off the bed. NOT perfect (for one thing it needs more shells on the 'top' curved areas), but pretty good in terms of clean transitions. With a little bit of post process, it became really nice.
                        zaptaundefined 1 Reply Last reply Reply Quote 1
                          A Former User @arhi
                          I have been using soft brass bristle brushes with an auto wipe system for a long time, the nozzle travels between two rows of the brush bristles.
                          Nozzles are holding up well, so much so I have never even noticed them needing to be changed .
                          I didn't make too much of it, it just works.
                          Maybe too much thought on a simple problem is being applied.
                          • Danalundefined
                            Danal
                            @CaLviNx said in nozzle wipe:
                            Nah, this group would NEVER do that!!! 27 steppers and five switches to align something that snaps into place anyway? GREAT!
                            • jens55undefined
                              jens55
                              If we liked things simple we would just buy a printer and ... imagine that .... print stuff.
                              There is no fun in that 🙂
                                A Former User @jens55
                                If you say so.
                                • zaptaundefined
                                  zapta @Danal
                                  @Danal said in nozzle wipe:
                                  The results look very good. Any idea where one can source that or a similar material?
                                  • Danalundefined
                                    Danal @zapta
                                    @zapta said in nozzle wipe:
                                    You can buy a foot of it for $2.50. I'm not sure what their minimums are... shipping... etc. My orders are always big.
                                    https://www.aircraftspruce.com/catalog/appages/siliconecowlseals.php?clickkey=4767
                                    • zaptaundefined
                                      zapta @Danal
                                      @Danal, thanks, will give it a try. My goal is to wipe PETG every few layers. Need to figure out where to install it since my nozzle doesn't go beyond the bed.
                                      • SpoonUnitundefined
                                        SpoonUnit
                                        I use a silicone cooking brush - something along the lines of these:
                                        https://smile.amazon.co.uk/Silicone-Basting-Pastry-Brushes-Barbecue/dp/B077TJHT9G/ref=sr_1_10?dchild=1&keywords=silicone+cooking+brush&qid=1588030483&sr=8-10
                                        The only bit I'm interested is the brush, so the rest is cut off, and the tines are cut down to about 15mm, so they become reasonably stiff. The nice thing about passing the nozzle through the brush seems to be that a) the filament gets caught in the brush, and b) the brush cleans the underside of the hot end and nozzle if mounted at the right height. The hot end isn't in contact with it long enough to impart any significant heat, but even so, the silicone can handle pretty high temps.
                                        Here's how it ends up looking, with one mounted either side of the bed:
                                        I prime 30mm reasonably fast just infront of the brush to create a thickish string, pass back and forth through the brush along slightly different lines to avoid re-collection of the string, then move immediately to begin printing.
                                        Here's a closer view of the wipe:
                                        • arhiundefined
                                          arhi @SpoonUnit
                                          @SpoonUnit I was looking at that brush too but was afraid bristles are too soft to do anything
                                            A Former User @zapta
                                            Why do you feel you need to wipe the nozzle every few layers?
