    nozzle wipe
    3D Printing General Chat
    14
    83
    6.2k
      deckingman @arhi
      @arhi I can't be sure but the stuff I used was more like this https://www.ebay.co.uk/itm/SOLID-SILICONE-RUBBER-STRIPS-3MMTHK-X-5MTRS-LONG-WHITE-60-SHORE-FDA-GRADE/331230136018?hash=item4d1edac6d2ⓂmM0icdmB-aIKG93gQRG6wvw. The listing is for 3mm thick (which is what I think I used), but the picture looks like 1mm thick. But it's definitely "solid".
      deckingmanundefined 1 Reply Last reply Reply Quote 1
        deckingman @deckingman
        This is what I have. The picture is a bit out of focus but it's solid and about 3mm x 10mm.
        • arhiundefined
          arhi
          @deckingman thanks, I was afraid of that "sponge" part too .. both looks spongy and title say sponge 😄 .. from what I see it is insulation strip so it's expected to be pressed between something I think...
            deckingman @arhi
            @arhi It might still work. Or to put it another way, I do know the solid stuff works, the spongy stuff might work but I don't know for sure if it will.
            • mwolterundefined
              mwolter
              Here's what I've been using with success. Tested the silicone blade and 250c nozzle temps didn't affect it. Also tried a soldering iron at 350c and it couldn't touch it. Should be safe with the temperatures I plan to use for ABS, PC and Nylon.
              Link to Product
              https://www.amazon.com/gp/product/B000BQU0CQ/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
              The blade itself is about 2.2mm wide, has a flat edge on one side and a round key on the other. Total height is about 20mm and it's 200mm long. Enough to do several printers.
              The blade is easily mounted and prevented from sliding out by a wall on the opposite side. Macro starts on the side closest to the camera and zig-zags away.
              • arhiundefined
                arhi
                I tried one blade and it didn't hold up on 200C 😞
                I ordered some of that spongy things + I found solid one too so ordered that too we'll see when/if arrives... found something super cool now amongst baby things need to test for temp might be a win ... another kitchen utencil, found between baby things ... temp. resistent 😄
                • zaptaundefined
                  zapta @arhi
                  @arhi said in nozzle wipe:
                  This one should sustain high temperature. It is used to hold hot solder iron tips.
                  https://www.tequipment.net/Metcal/AC-CP2/Soldering-Accessories/?Source=googleshopping
                  The one I have is 2.3mm in thickness and the square portion is 75mm x 75. It's a rubbery thing.
                  • arhiundefined
                    arhi @zapta
                    @zapta ha, I have exactly the same thing that I got with my PACE ages ago, you are supposed to use it to grab your hot tip to replace with another one 😄 but it's very soft, it's like the stuff I already have in the wiper right now. This "cup" will work great till I get the long strips, it is much stiffer, and when long strips arrive cup will be cool to hold the bits of plastic 😄
                    • Nuramoriundefined
                      Nuramori
                      One thing I did was collect all the old and torn silicone socks I had lying around and made a wipe. B97DC44A-85D2-417D-94F8-8FA5677E1E6A.jpeg
                      I just sliced off the sides and kept the face, then alternated them with washers. Used RTV on the bottom to bind them.
                      zaptaundefined 1 Reply Last reply Reply Quote 3
                      • zaptaundefined
                        zapta @Nuramori
                        Stumbled upon this one while searching for a silicon work mat.
                        E.g. the 50x50x20mm.
                        https://www.aliexpress.com/item/4000765138240.html
                        • zaptaundefined
                          zapta
                          The last 3D Printing Today (episode #349) discussed some magic 'inexpensive silicon foam' that works great to wipe the nozzle.
                          It starts at the 17 minutes mark. (Clicon on the POD icon to start playing, or find them on your favorite podcast player).
                          https://threedprintingtoday.libsyn.com/3d-printing-today-349
                          I think they were referring to something like this: https://www.amazon.com/Silicone-T-Shirt-Machine-Transfer-Cushion/dp/B07HNSWXDQ
