    Release 3.01-RC10
    2.8k
    • Leblondundefined
      Leblond @dc42
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 22:39:29 GMT+0200 (Ora legale dell’Europa centrale)
      G91 ; relative positioning
      G90 ; absolute positioning
      G1 X60 Y50 F6000 ; go to first probe point
      ;G91 ; relative positioning
      ;G1 Z10 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      • Leblondundefined
        Leblond
        now I have mounted the fw 2.05 to see if even with this it does the same problem
          Is the tool still selected when you have this problem? Send T by itself to report the current tool number.
          Leblondundefined 3 Replies Last reply Reply Quote 0
          • Leblondundefined
            Leblond @dc42
            @dc42 ok I reassemble the FW and then I tell you
            • Leblondundefined
              Leblond @dc42
              @dc42 made reloaded FW 3.01-RC10
              yes the tool is always active
              1/5/2020, 14:51:33 T
              Tool 0 is selected
              • Leblondundefined
                Leblond @dc42
                @dc42 I compress all the sd and send it to you?
                • Leblondundefined
                  Leblond
                  it still does not work
                  • Leblondundefined
                    Leblond
                    the engine practically vibrates as if it were stalled
                    • Leblondundefined
                      Leblond
                      @dc42 I confirm that with version 3 of the fw I have this problem, but with the version of FW 2.05 everything works great, so I will continue to use FW 2.05, until you can understand where the problem lies
                      • Leblondundefined
                        Leblond
                        Hi everyone, have you discovered anything about my problem?
                        • Leblondundefined
                          Leblond
                          good morning guys
                          I have found that by sending the axes home manually one at a time starting with x, y and z, the extruder works
                          • Leblondundefined
                            Leblond
                            but as soon as a g28 is made it no longer works and the extruder stalls
                            sebkritikelundefined 1 Reply Last reply Reply Quote 0
                            • Leblondundefined
                              Leblond
                              I also installed Release 3.01-RC12 ma niet
                              • Leblondundefined
                                Leblond
                                for @dc42 no idea?
                                • Leblondundefined
                                  Leblond
                                  Guys forgive me if I insist, but it seems strange to me that only I have a problem with a brand new card and you can't find a solution
                                  • sebkritikelundefined
                                    sebkritikel @Leblond
                                    @Leblond said in Release 3.01-RC10:
                                    When you send "G28" or "G28 Z" ?
                                    Can you post homeall.g?
                                    good morning guys
                                    G28 X
                                    Extruder Works
                                    G28 Y
                                    Extruder Works
                                    G28 Z
                                    Extruder Works
                                    G28
                                    Does not work?
                                    Large(ish?) IDEX - 6HC, 1HCL
                                    Stratasys Dimension 1200es to 6HC Conversion
                                    • Leblondundefined
                                      Leblond
                                      it is exact only when sending g28 the extruder stalls
                                      • Leblondundefined
                                        Leblond
                                        ; homeall.g
                                        ; called to home all axes
                                        M913 X50 Y50 ; Riduci la corrente al 50%
                                        G1 H1 X-9999 Y-9999 F4000 ; move quickly to X or Y endstop and stop there (first pass)
                                        G1 H1 X-9999 ; home X axis
                                        G1 H1 Y-9999 ; home Y axis
                                        G1 X5 Y5 F2000 ; go back a few mm
                                        G1 H1 X-9999 F360 ; move slowly to X axis endstop once more (second pass)
                                        G1 H1 Y-9999 ; then move slowly to Y axis endstop
                                        G1 X60 Y50 F9000 ; go to first bed probe point and home Z
                                        M913 X100 Y100 :Riporta la corrente al 100%
                                          ; homeall.g
                                          Can you try:
                                          ;homeall.g
                                          ;;;M913 X50 Y50 ; Riduci la corrente al 50%
                                          G1 H1 Y-9999 F360 ; then move slowly to Y axis endstop
                                          ;;;M913 X100 Y100 :Riporta la corrente al 100%
                                          Leblondundefined 2 Replies Last reply Reply Quote 0
                                          • Leblondundefined
                                            Leblond @sebkritikel
                                            @sebkritikel ok now i try
