Not Homing correctly At all. and nozzle issues
1.2k
    Phaedrux Moderator @moe.adams9093
    @moe-adams9093 said in Not Homing correctly At all. and nozzle issues:
    M569 P2 S0 ; physical drive 2 goes backwards
    You're going to need to define drive 4 for use as a second Z axis in config.g and change your bed.g to do the probing for the leveling adjustment.
    M569 P0 S1 ; physical drive 0 goes forwards (X axis)
    M569 P1 S1 ; physical drive 1 goes forwards (Y axis)
    M569 P2 S0 ; physical drive 2 goes backwards (Z1 axis)
    M569 P3 S0 ; physical drive 3 goes backwards (E axis)
    M569 P4 S0 ; physical drive 4 goes backwards (Z2 axis)
    M584 X0 Y1 Z2:4 E3 ; set drive mapping
    M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
    For the points in M671 you need to find the coordinates of your own bed to measure, you can't just use the example points.
    You will connect one Z motor to the Z1 (drive 2), put the jumpers back in the second port. Then connect the other Z motor to the E1 (drive 4)
    For bed.g you'll also have to find the points to probe with G30
    G28 ; home
    M401 ; deploy Z probe (omit if using bltouch)
    G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
    G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
    M402 ; retract probe (omit if using bltouch)
    The G30 P1 will likely be further to the right on your larger bed so adjust the CX position accordingly.
      moe.adams9093
      Thank you very much for all your help. I will make these adjustments tomorrow, but how can I find points in M671 coordinates of my own bed measuring, is their sort of documentation can explain how to find the coordinate positions of my bed. thank you again
        You just need to choose a point close to the lead screw but still on the bed and both need to be in line on the Y axis.
          moe.adams9093
          @Phaedrux said in Not Homing correctly At all. and nozzle issues:
          G28 ; home M401 ; deploy Z probe (omit if using bltouch) G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors M402 ; retract probe (omit if using bltouch)
          THANK YOU. it worked and I found my correct bed coordinate points. do I have to change any config for my BLtouch current settings are
          Z-Probe
          M558 P9 H2 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y0 Z2 ; set Z probe trigger value, offset and trigger height
          M557 X5:350 Y5:350 S50 ; define mesh grid
          I have version 3
            The dive height is a little low. It should be at least a mm more than the trigger height. Try M558 H3
            Also change G31 P500 to G31 P25
            Have you calibrated our probe and measured the offsets yet?
            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
              moe.adams9093
              so I have adjusted all the settings accordingly here's a photo of the hight mapScreenshot (4).png so I don't if that's ok or it should be 0 all the way I tried to print a file 340 x 340 and it looks like it's not adjusting probably. here's my updated file config.g
              ; Configuration file for Duet Maestro (firmware version 2.03)
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 30 2020 23:57:45 GMT-0500 (Central Daylight Time)
              M550 P"Ender5Plus" ; set printer name
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M671 X0:285 Y0:180 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
              M92 X80.00 Y80.00 Z800.00 E96.00 ; set steps per mm
              M566 X480.00 Y480.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X30000.00 Y30000.00 Z600.00 E3000.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
              M906 X960 Y980 Z960 E960 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X365 Y365 Z415 S0 ; set axis maxima
              M574 X1 Y1 S1 ; set active low and disabled endstops
              M558 P9 H3 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P25 X0 Y0 Z1.758 ; set Z probe trigger value, offset and trigger height
              M557 X5:335 Y5:335 S20 ; define mesh grid
              M141 H2 ;Assign chamber heater to heater 2
              M307 H2 A11 C99000 D2000 B1 ; chamber heater operates in bang-bang mode
              M305 P2 T10000 B3988 C0 R2200 ; Set thermistor + ADC parameters for bed
              M143 H2 S80 ; set temperature limit for heater 2 to 80C
              M305 P0 T98801 B4138 R2200 ; set thermistor + ADC parameters for heater 0
              M143 H0 S130 ; set temperature limit for heater 0 to 130C
              M305 P1 T98801 B4138 R2200 ; set thermistor + ADC parameters for heater 1
              M143 H1 S300 ; set temperature limit for heater 1 to 300C
              M106 P0 S0.5 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P1 S0.5 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
              T0 ; select first tool
              and file bed.g
              ; bed.g
              G28 ; home
              G30 P0 X0 Y180 Z-99999 ; probe near a leadscrew, half way along Y axis
              G30 P1 X285 Y180 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
              G29 S0
              G29 S1
              I don't know if i have to enable some settings to run hight map while it prints maybe from slicer or from DWC. thank you for all your help
                moe.adams9093
                does that meat its successfully calibrated.
                  moe.adams9093
                  please let me know if that looks good sorry I know I have been asking you a lot. Thanks again
                    Print a test file like this one with mesh enabled and again disabled. You should be able to tell if it's being applied correctly.
                    bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                      moe.adams9093
                      Yes I did what you told me and it looks like its not working properly. Any other suggestions would be helpful. Thanks
                      undefined 1 Reply Last reply 6 May 2020, 08:50 Reply Quote 0
                        PaulHew @moe.adams9093
                        @moe-adams9093 What slicer are you using? Please post your start GCode from your slicer.
                        Regards,
                        Paul
                          You need to measure your X and Y probe offset otherwise the corrections will be off in X Y position.
                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe?revisionid=HEAD#Section_Measuring_Probe_X_Y_Offset
                          The heightmap itself looks ok. After measuring the offset redo the G29 and reprint the test file to see if it's behaving better.
                            moe.adams9093
                            Thank you for the additional information so my x offset is 44mm and the y offset is -5mm but when I try to run mesh compensation its starting from 44 to 285 and my actual build volume is 350 x 350 so please correct me on that one am I loosing that left over space since it only probing from 44 to 285. Also when I checked my old configuration from the original bord it says offest x0 y0 z1.78 so I don't if that does matter or not. Please let me know thank you
                            27 out of 30
