    PS_ON not working?
    2.1k
    • joehsmashundefined
      joehsmash
      i am also finishing up the wiring, when ever i plug ANY end stop into the y axis it causes the DUET to crash. it reboots the minute i unplug it.
      this board is starting to annoy me its been 4 days of messing around with it to get it working with one problem after another.
      is there any actual customer support or are we just delegated to using this forum and waiting weeks for some one to possibly help us?
      i mean its not like this board was cheap... it cost me 260 bucks. i could almost get a whole other printer for that.
      • Danalundefined
        Danal
        @joehsmash said in PS_ON not working?:
        That is symptomatic of a physically incorrectly wired endstop. Verify:
        • I am assuming you have physical switches, and will run them "NC" or "Normally Closed".
        • For NC on a three terminal switch, attach wire to the outer two terminals; leave the middle unconnected.
        • Duet2 Wifi endstop connectors are shown below. Verify that the switch is connect to "GND" and "STOP". This is different than a lot of other printers, and connecting 3.3V and Gnd will cause exactly what you are describing
        • Danalundefined
          Danal @Danal
          This post is deleted!
          • Danalundefined
            Danal
            Also, I STRONGLY suggest you start a new thread for each new problem. Example: "Endstop Switches not working" will get a lot more attention as a thread than a dozen posts down the "PS_ON not working" thread.
            P.S. I have no relation to Duet the company.
            joehsmashundefined 1 Reply Last reply Reply Quote 0
              joehsmash @Danal
              @Danal i gotcha, i have verified the wiring and changed the switches. Nothing has changed on my printer other than the duet. I have tested every switch with my meter as well.
                joehsmash @joehsmash
                i will try to redo the connectors tomorrow morning
                  T3P3Tony administrators
                  Hi @joehsmash thanks, looks correctly wired like this:
                  32f4d43e-9a50-4dd8-83a6-9d905b17aed8-image.png .
                  Assuming that wiring worked previously (the 5V SB goes to the correct place?) then it should work. please can you share your config.g just in case there is something odd going on that is interfering with M80/M81. Also please try the following tests:
                  1. Once started up send M98 P"/sys/config.g" to run config.g again. sometimes errors in the config file are not reported in the console during startup so this will run it again and report any errors.
                  2. send M122 and post the results here, see if they are any different before/after the M80 command
                  P.S. You can cut and paste images into your post or use the "upload image" button to attach images.
                  joehsmashundefined 2 Replies Last reply Reply Quote 0
                    joehsmash @T3P3Tony
                    @T3P3Tony here is my M122
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                    Board ID: 08DLM-996RU-N8PS4-7JKDA-3S86M-9BAZN
                    Used output buffers: 3 of 24 (17 max)
                    Static ram: 25712
                    Dynamic ram: 93140 of which 0 recycled
                    Exception stack ram used: 392
                    Never used ram: 11828
                    Tasks: NETWORK(ready,764) HEAT(blocked,904) MAIN(running,3824) IDLE(ready,160)
                    Owned mutexes:
                    Last reset 01:44:08 ago, cause: power up
                    Last software reset at 2020-05-05 21:39, reason: User, spinning module GCodes, available RAM 11836 bytes (slot 1)
                    Error status: 0
                    Free file entries: 10
                    MCU temperature: min 32.2, current 32.6, max 32.8
                    Supply voltage: min 2.0, current 2.0, max 6.5, under voltage events: 0, over voltage events: 0, power good: no
                    Driver 0: ok, SG min/max not available
                    Driver 1: ok, SG min/max not available
                    Driver 2: ok, SG min/max not available
                    Driver 3: ok, SG min/max not available
                    Driver 4: ok, SG min/max not available
                    Date/time: 2020-05-06 15:21:01
                    Slowest loop: 5.34ms; fastest: 0.05ms
                    Hiccups: 0, FreeDm: 160, MinFreeDm: 159, MaxWait: 7ms
                    === DDARing ===
                    Scheduled moves: 10, completed moves: 10, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                    Heater 0 is on, I-accum = 0.1
                    Heater 1 is on, I-accum = 0.0
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is idle in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 201.13ms; fastest: 0.08ms
                    HTTP sessions: 1 of 8
                    • WiFi -
                      Network state is running
                      Failed messages: pending 0, notready 0, noresp 2
                      WiFi firmware version 1.23
                      WiFi MAC address bc:dd:c2:2d:64:61
                      WiFi Vcc 3.38, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 23184
                      WiFi IP address 192.168.1.44
                      WiFi signal strength -42dBm, reconnections 0, sleep mode modem
                    it appears that i was using the stock connectors on the end stops and as such were wired up in 3.3v to gnd positions.
                    i remade the connectors appropriately and the end stops are no longer causing me an issue.
                    still have the PSON issue, but i have circumvented that by just shorting it on all the time now. i will come back to this one.
                    current issue is VIN not in spec?
                    joehsmashundefined 1 Reply Last reply Reply Quote 1
                      @T3P3Tony It looks like i have a blown fuse on my board.
                      the 7.5a mini blade fuse blew. i wonder what would have caused that. i know i head a kind of pop when i tried to turn on my hotend.
                      im not sure what would have caused it if it was the hot end, i just replaced the heater, and the thermistor. i also have replaced the line going straight back to the duet. there's only one connector just before the hot end if i ever need to disconnect it.
                        dc42 administrators @joehsmash
                        Most likely you has a short circuit in the hot end heater or in the wiring to it.
                          joehsmash @dc42
                          yes i discovered last night after i ripped my printer appart that there was indeed a short between the hotend wire and the heater cartridge. some kapton and a some silicone sleeves and all is well there!
                            joehsmash @T3P3Tony
                            @T3P3Tony i feel like im getting pretty close, i have come back to the original issue here is my M122 pre M80
                            M122
                            Used output buffers: 3 of 24 (15 max)
                            Static ram: 25712
                            Exception stack ram used: 384
                            Never used ram: 11836
                            Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3752) IDLE(ready,160)
                            Owned mutexes:
                            Last reset 00:08:16 ago, cause: power up
                            Last software reset at 2020-05-07 00:48, reason: User, spinning module GCodes, available RAM 11780 bytes (slot 1)
                            Error status: 0
                            Free file entries: 9
                            MCU temperature: min 29.9, current 30.3, max 30.5
                            Supply voltage: min 0.6, current 0.7, max 0.7, under voltage events: 1, over voltage events: 0, power good: no
                            Date/time: 2020-05-07 16:34:14
                            Cache data hit count 1617214182
                            Slowest loop: 1.16ms; fastest: 0.05ms
                            Hiccups: 0, FreeDm: 158, MinFreeDm: 158, MaxWait: 0ms
                            === DDARing ===
                            Scheduled moves: 4, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                            Segments left: 0
                            Stack records: 1 allocated, 1 in use
                            Movement lock held by http
                            http is idle in state(s) 1 8
                            === Network ===
                            Slowest loop: 201.11ms; fastest: 0.08ms
                            • WiFi -
                              Failed messages: pending 0, notready 0, noresp 1
                              WiFi flash size 4194304, free heap 23112
                              WiFi signal strength -45dBm, reconnections 0, sleep mode modem
                            and here it is post M80
                            M122
                            Static ram: 25712
                            Owned mutexes:
                            Last reset 00:10:46 ago, cause: power up
                            Error status: 0
                            MCU temperature: min 30.1, current 30.8, max 30.8
                            Date/time: 2020-05-07 16:36:45
                            Cache data hit count 2209121988
                            Slowest loop: 2.06ms; fastest: 0.05ms
                            Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 0ms
                            === DDARing ===
                            Scheduled moves: 4, completed moves: 4, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                            Segments left: 0
                            === Network ===
                            Slowest loop: 202.11ms; fastest: 0.08ms
                            • WiFi -
                              WiFi Vcc 3.39, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 21648
                              WiFi signal strength -44dBm, reconnections 0, sleep mode modem
                            not much has changed
                              joehsmash
                              i cant find any reference to M80/81 in the config.g file, and i dont see it defined any where else,
                                joehsmash
                                i have now added the M80/81 commands at the beginning of the config.g and again no change
                                M80 ; Turns on the ATX power supply
                                M81 ; Turns off the ATX power supply
                                  joehsmash
                                  i have also measured with my meter, that i currently have 3.3v on the PSON connector that is feeding onto the DUET. i assumed that the duet would just ground that pin. but irregardless of m command it still retains the 3.3v.
                                  i also found a note in the forum from one of the duet employees that the GND isnt required so i have since removed it.
                                    joehsmash
                                    here is a copy of my config.g
                                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu May 07 2020 17:04:03 GMT-0600 (Mountain Daylight Time)
                                    M550 P"JoehBo3D" ; set printer name
                                    M552 S1 ; enable network
                                    M586 P0 S1 ; enable HTTP
                                    M586 P1 S0 ; disable FTP
                                    M586 P2 S0 ; disable Telnet
                                    M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
                                    M566 X1020.00 Y1020.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                    M201 X9000.00 Y9000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                                    M84 S30 ; Set idle timeout
                                    M208 X228 Y254 Z203 S0 ; set axis maxima
                                    M558 P1 H5 F-120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                    G31 P500 X-24 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                    M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                    M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                    ; Custom settings
                                    Topherundefined 1 Reply Last reply Reply Quote 0
                                    • Topherundefined
                                      Topher @joehsmash
                                      @joehsmash according to your config.g your supply turns on then the next line it turns off
                                        joehsmash @Topher
                                        @LeckieTech good catch, it still doesnt activate the psu tho 😞
                                        Topherundefined 2 Replies Last reply Reply Quote 0
                                        • Topherundefined
                                          Topher @joehsmash
                                          @joehsmash With that output, you can't really read it with a voltmeter unless you add a pull-up resistor. You could use any resistor you have between 1k-100k ohms and pull up to 5 volts.
                                          Send M81 - you should read 5 volts on the middle pin.
                                          Send M80 - you should read 0 volts on the middle pin.
                                          (sorry for the horrible drawing)
                                          • Topherundefined
                                            Topher @joehsmash
                                            @joehsmash I suspect that the output is working but isn't one of 2 things.
                                            1. on the same ground plane as the PSU
                                            2. not providing a strong enough ground to the PSU
