    3.1.0 firmware reboots periodically
    1.6k
    • k3lagundefined
      k3lag
      I installed 3.1.0 on my Duet2Wifi a bit ago and since then it has restarted several times. Once in the middle of a print and several times while idle. Here is the M122 output:
      console-2.txt
        Thanks for your report. Please try the internal build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0 and let me know whether it fixes the problem. If it does, please run M122 after the printer has been on for some time (and preferably done at least one print) and post the result here again.
          PS - @k3lag, please provide your config.g file.
          • k3lagundefined
            k3lag
            I just installed the internal build. I'll let you know how it goes in a few hours. Here is my config.g.
            config.g
            There is a commented out M575 line in there for the PanelDue. I wasn't sure I needed it since I'm using the ribbon cable only.
              dc42 administrators @k3lag
              You actually have two M575 P1 lines in config.g, of which the second is commented out. You need a M575 P1 command to support PanelDue even if you are using the ribbon cable.
              k3lagundefined 1 Reply Last reply Reply Quote 0
              • k3lagundefined
                k3lag @dc42
                @dc42 said in 3.1.0 firmware reboots periodically:
                I missed the first one when I was checking to make sure I had one. That explains why it worked when I commented it out. 😊
                I'm in the middle of a print and so far so good.
                • Thaliosundefined
                  Thalios
                  Having same issue with my Duet 3. Will install the build linked and report back.
                  My M122 reports:
                  m122
                  RepRapFirmware for Duet 3 MB6HC version 3.1.0 running on Duet 3 MB6HC v0.6 or 1.0
                  Board ID: 08DJM-956L2-G43S4-6J9D0-3SD6Q-9U5GF
                  Used output buffers: 1 of 40 (11 max)
                  Static ram: 154804
                  Dynamic ram: 163068 of which 44 recycled
                  Exception stack ram used: 328
                  Never used ram: 74972
                  Tasks: NETWORK(ready,68) ETHERNET(blocked,436) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,204) MAIN(running,4520) IDLE(ready,76)
                  Owned mutexes:
                  Last reset 00:00:22 ago, cause: software
                  Last software reset at 2020-05-16 13:30, reason: Stack overflow, spinning module GCodes, available RAM 74648 bytes (slot 0)
                  Software reset code 0x4103 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f80e BFAR 0x00000000 SP 0x2045ffb4 Task NETW
                  Stack: 204120c0 204120f4 00463465 00000000 20412228 0000000a ffffffff 00020021 00462a89 2041211c 20417e30
                  Error status: 0
                  MCU temperature: min 45.4, current 45.6, max 45.8
                  Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                  Driver 0: standstill, reads 44331, writes 15 timeouts 0, SG min/max 0/0
                  Driver 1: standstill, reads 44332, writes 15 timeouts 0, SG min/max 0/0
                  Driver 2: standstill, reads 44333, writes 15 timeouts 0, SG min/max 0/0
                  Driver 3: standstill, reads 44334, writes 14 timeouts 0, SG min/max 0/0
                  Driver 4: standstill, reads 44338, writes 11 timeouts 0, SG min/max 0/0
                  Driver 5: standstill, reads 44339, writes 11 timeouts 0, SG min/max 0/0
                  Date/time: 2020-05-16 13:30:50
                  Slowest loop: 5.78ms; fastest: 0.15ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 3.1ms, write time 0.0ms, max retries 0
                  === MainDDARing ===
                  === AuxDDARing ===
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 4.94ms; fastest: 0.03ms
                  HTTP sessions: 2 of 8
                  - Ethernet -
                  State: active
                  Error counts: 0 0 0 0 0
                  Socket states: 2 2 2 2 2 0 0 0
                  === Filament sensors ===
                  Extruder 0: pos -3.87, errs: frame 7 parity 0 ovrun 0 pol 0 ovdue 0
                  === CAN ===
                  Messages sent 88, longest wait 0ms for type 0
                  === Linux interface ===
                  State: 0, failed transfers: 0
                  Last transfer: 22277ms ago
                  RX/TX seq numbers: 0/1
                  SPI underruns 0, overruns 0
                  Number of disconnects: 0
                  Buffer RX/TX: 0/0-0
                  Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                  Heavily modified Ender 3 Pro (Duet 3 6HC)
                  Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                  CR-10S Pro V2 (Duet 3 Mini 5+)
                  and a bunch of SLA printers..
                  • Thaliosundefined
                    Thalios
                    On first firmware upgrade to 3.1.0, it would reset every 30 sec to 1 minute. Now with the one from Dropbox, it has been stable for 10 minutes.
                    Here's my config.g
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 29 2020 20:50:30 GMT-0400 (EDT)
                    G90                                                ; send absolute coordinates...
                    M83                                                ; ...but relative extruder moves
                    M550 P"Ender 3 Pro"                                ; set printer name
                    M918 P1 E4 F2000000                                ; configure direct-connect display
                    M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
                    M586 P0 S1                                         ; enable HTTP
                    M586 P1 S0                                         ; disable FTP
                    M586 P2 S0                                         ; disable Telnet
                    M569 P0.0 S1 D3                                    ; physical drive 0.0 goes forwards
                    M569 P0.1 S1 D3                                    ; physical drive 0.1 goes forwards
                    M569 P0.2 S0 D3                                    ; physical drive 0.2 goes backwards
                    M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
                    M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
                    M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z400.00 E141.32                  ; set steps per mm
                    M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
                    M203 X9000.00 Y9000.00 Z250.00 E6000.00            ; set maximum speeds (mm/min)
                    M201 X300.00 Y300.00 Z200.00 E5000.00            ; set accelerations (mm/s^2)
                    M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                            ; Set idle timeout
                    M208 X0 Y0 Z0 S1                                   ; set axis minima
                    M208 X245 Y225 Z230 S0                             ; set axis maxima
                    M574 X1 S1 P"io0.in"                               ; configure active-high endstop for low end on X via pin io0.in
                    M574 Y1 S1 P"io1.in"                               ; configure active-high endstop for low end on Y via pin io1.in
                    M574 Z1 S2			                               ; configure to use z-probe
                    M558 P1 C"io6.in+io6.out" H2.5 F100 T9000          ; set Z probe type to unmodulated and the dive height + speeds
                    G31 P500 X-22 Y4 Z1.30                             ; set Z probe trigger value, offset and trigger height
                    M557 X30:195 Y25:200 P5                            ; define mesh grid
                    M308 S0 P"temp1" Y"thermistor" T100000 B4092       ; configure sensor 0 as thermistor on pin temp1
                    M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
                    M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                    M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
                    M140 H0                                            ; map heated bed to heater 0
                    M308 S1 P"temp0" Y"thermistor" T100000 B4092       ; configure sensor 1 as thermistor on pin temp0
                    M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
                    M143 H1 S270                                       ; set temperature limit for heater 1 to 270C
                    M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                    M950 F0 C"out8" Q500                               ; create fan 0 on pin out8 and set its frequency
                    M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                    M950 F1 C"!out4" Q25000                             ; create fan 1 on pin out4 and set its frequency
                    M106 P1 S1 H1 T45								   ; set fan 1 value. Thermostatic control is turned on
                    M950 F2 C"!out6" Q25000							   ; create fan 2 on pin out6 and set its frequency
                    M106 P2 S1 H1 T20                                  ; set fan 2 value. Thermostatic control is turned on
                    M563 P0 D0 H1 F-1                                  ; define tool 0
                    G10 P0 X-5 Y0 Z0                                   ; set tool 0 axis offsets
                    G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                    ; Custom settings
                    M591 D0 P5 C"io3.in" R25:130 E3 S1 A0              ; Enable and set Filament monitor
                    T0                                                 ; select first tool
                    M501                                               ; Load config overrides
                      Thanks. When it has been running for a while, please run M122 and post the report here.
                      • k3lagundefined
                        k3lag
                        Just completed a 1hr 42min print with no issues. Here is the M122 after the print:
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0+ running on Duet WiFi 1.02 or later + DueX5
                        Board ID: 08DGM-917DA-G4MSJ-6JKDJ-3S46L-TVPMB
                        Used output buffers: 3 of 24 (18 max)
                        Static ram: 28260
                        Dynamic ram: 93992 of which 60 recycled
                        Exception stack ram used: 544
                        Never used ram: 8216
                        Tasks: NETWORK(ready,92) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1640) IDLE(ready,80)
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 01:49:28 ago, cause: software
                        Last software reset at 2020-05-16 12:21, reason: User, spinning module GCodes, available RAM 8496 bytes (slot 3)
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                        Error status: 8
                        MCU temperature: min 31.1, current 33.5, max 37.0
                        Supply voltage: min 24.2, current 24.5, max 24.9, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: standstill, SG min/max 0/1023
                        Driver 1: standstill, SG min/max 0/1023
                        Driver 3: standstill, SG min/max 0/1023
                        Driver 5: standstill, SG min/max 0/257
                        Driver 6: standstill, SG min/max 0/272
                        Driver 7: standstill, SG min/max 0/281
                        Date/time: 2020-05-16 14:10:39
                        Slowest loop: 82.69ms; fastest: 0.14ms
                        === Storage ===
                        SD card longest read time 1.7ms, write time 2.1ms, max retries 0
                        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 118, MaxWait: 290918ms
                        === MainDDARing ===
                        Scheduled moves: 47669, completed moves: 47669, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                        === AuxDDARing ===
                        Heater 0 is on, I-accum = 0.0
                        Heater 1 is on, I-accum = 0.4
                        Segments left: 0
                        === Network ===
                        Slowest loop: 22.55ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        - WiFi -
                        Network state is active
                        WiFi firmware version 1.23
                        WiFi MAC address ec:fa:bc:01:d6:19
                        WiFi Vcc 3.43, reset reason Unknown
                        WiFi flash size 4194304, free heap 20336
                        WiFi IP address 192.168.1.16
                        WiFi signal strength -30dBm, reconnections 0, sleep mode modem
                        === DueX ===
                        Read count 1, 0.01 reads/min
                        Update: It's been another 2+ hours and no restarts. It seems happy now.
                        • Thaliosundefined
                          Thalios
                          Same here, works great. 2h up time more or less, no more reboots.
                          M122 results:
                          m122
                          RepRapFirmware for Duet 3 MB6HC version 3.1.0+ running on Duet 3 MB6HC v0.6 or 1.0
                          Used output buffers: 3 of 40 (24 max)
                          Static ram: 154884
                          Never used ram: 74892
                          Tasks: NETWORK(ready,84) ETHERNET(blocked,436) HEAT(blocked,1112) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,204) MAIN(running,4536) IDLE(ready,76)
                          Owned mutexes:
                          Last reset 01:54:43 ago, cause: power up
                          Last software reset at 2020-05-16 15:58, reason: Stack overflow, spinning module Platform, available RAM 74648 bytes (slot 2)
                          Software reset code 0x4100 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443780e BFAR 0x00000000 SP 0x2045ffb4 Task NETW
                          Stack: 204120c0 204120f4 00463465 00000000 00000000 204121f0 00000000 a0000000 00462a89 204120fc 20417e30
                          Error status: 0
                          MCU temperature: min 45.1, current 45.4, max 45.6
                          Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                          Driver 0: standstill, reads 26432, writes 0 timeouts 0, SG min/max not available
                          Driver 1: standstill, reads 26431, writes 0 timeouts 0, SG min/max not available
                          Driver 2: standstill, reads 26432, writes 0 timeouts 0, SG min/max not available
                          Driver 3: standstill, reads 26433, writes 0 timeouts 0, SG min/max not available
                          Driver 4: standstill, reads 26432, writes 0 timeouts 0, SG min/max not available
                          Driver 5: standstill, reads 26434, writes 0 timeouts 0, SG min/max not available
                          Date/time: 2020-05-16 19:24:41
                          Slowest loop: 6.87ms; fastest: 0.15ms
                          === Storage ===
                          SD card longest read time 3.4ms, write time 0.0ms, max retries 0
                          === MainDDARing ===
                          === AuxDDARing ===
                          Segments left: 0
                          === Network ===
                          Slowest loop: 7.35ms; fastest: 0.03ms
                          - Ethernet -
                          State: active
                          Extruder 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                          === CAN ===
                          Messages sent 7589, longest wait 0ms for type 0
                          Last transfer: 6883973ms ago
                          Buffer RX/TX: 0/0-0
                          • luckyflyerundefined
                            luckyflyer
                            When will the internal build be available for a pi update?
                            • FBGundefined
                              FBG
                              Happen me the same, After update from RC12, in the first print (around 16h) in the middle (around 60%) the firmware reset...
                              this is the M122:
                              m122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet Ethernet 1.02 or later
                              Board ID: 08DGM-917DA-G4MSD-6JTD8-3SS6M-K8S38
                              Used output buffers: 3 of 24 (11 max)
                              Static ram: 28180
                              Dynamic ram: 93332 of which 20 recycled
                              Exception stack ram used: 256
                              Never used ram: 9284
                              Tasks: NETWORK(ready,136) HEAT(blocked,1224) MAIN(running,1816) IDLE(ready,80)
                              Owned mutexes:
                              Last reset 07:35:56 ago, cause: software
                              Last software reset at 2020-05-17 00:23, reason: Stack overflow, spinning module none, available RAM 8896 bytes (slot 2)
                              Software reset code 0x4111 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80e BFAR 0xe000ed38 SP 0x2001ffb4 Task NETW
                              Stack: 20002860 20002894 00455625 00000000 20000000 200029b8 20002a55 a0000000 00454c35 200028c4 200055f4
                              Error status: 0
                              MCU temperature: min 23.2, current 23.7, max 38.9
                              Supply voltage: min 23.8, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                              Slowest loop: 6.71ms; fastest: 0.12ms
                              === Storage ===
                              SD card longest read time 2.0ms, write time 0.0ms, max retries 0
                              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                              === MainDDARing ===
                              === AuxDDARing ===
                              Segments left: 0
                              === Network ===
                              Slowest loop: 5.53ms; fastest: 0.02ms
                              Interface state active, link 100Mbps full duplex
                              Extruder 0 sensor: ok
                              Extruder 1 sensor: ok
                              I go to install the new version of dropbox and i will comment...
                              Best Regards
                              • FBGundefined
                                FBG
                                Sorry again, inside the link of dropbox i see the file Duet2Conbinedfirmware.bin, and also show 3.1.0 folder, inside this folder also the file Duet2Conbinedfirmware.bin.
                                Which i must use?
                                • Thaliosundefined
                                  Thalios
                                  the file directly in the main folder, not the one in the sub folder. Version should show 3.1.0+ when you do M122
                                  FBGundefined 1 Reply Last reply Reply Quote 0
                                  • FBGundefined
                                    FBG @Thalios
                                    @Thalios thank you, testing...
                                      dc42 administrators @luckyflyer
                                      @luckyflyer said in 3.1.0 firmware reboots periodically:
                                      We'll do an 3.1.1 release within the next few days. Meanwhile you can install the new binary the old way, i.e. upload it through DWC.
                                        Unfortunately I have been unable to reproduce the original problem, or identify what it is in config.g that causes the network task to use more stack than on my test machines.
                                        Therefore, please can any of you who were experiencing this issue install the candidate RRF 3.1.1 binary from https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0, check that the issue remains resolved, and report the network task free stack from the M122 report after it has been running for a while. The network task free stack is this bit:
                                        I suspect that a good way to reproduce the original fault quickly may be to set the printer doing something that causes motion (e.g. homing) and refresh the browser tab several times while it is doing that.
                                        PS - please check the the build date you are using ends with 18b6.
                                        • Thaliosundefined
                                          Thalios
                                          Installing. Will report back.
                                          • Thaliosundefined
                                            Thalios
                                            Problem is back it seems.
                                            M122 result:
                                            M122
                                            RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0
                                            Used output buffers: 1 of 40 (24 max)
                                            Static ram: 154524
                                            Dynamic ram: 163148 of which 44 recycled
                                            Exception stack ram used: 560
                                            Never used ram: 74940
                                            Tasks: NETWORK(ready,148) ETHERNET(blocked,436) HEAT(blocked,1112) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1424) TMC(blocked,68) MAIN(running,4464) IDLE(ready,76)
                                            Owned mutexes:
                                            Last reset 00:45:42 ago, cause: software
                                            Error status: 0
                                            MCU temperature: min 47.0, current 47.3, max 47.5
                                            Supply voltage: min 24.0, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 0: ok, reads 48824, writes 0 timeouts 0, SG min/max 0/277
                                            Driver 1: ok, reads 48825, writes 0 timeouts 0, SG min/max 0/1017
                                            Driver 2: standstill, reads 48825, writes 0 timeouts 0, SG min/max 0/0
                                            Driver 3: ok, reads 48826, writes 0 timeouts 0, SG min/max 0/969
                                            Driver 4: standstill, reads 48825, writes 0 timeouts 0, SG min/max not available
                                            Driver 5: standstill, reads 48826, writes 0 timeouts 0, SG min/max not available
                                            Date/time: 2020-05-18 12:51:28
                                            Slowest loop: 6.49ms; fastest: 0.15ms
                                            === Storage ===
                                            Free file entries: 9
                                            SD card longest read time 3.3ms, write time 0.0ms, max retries 0
                                            Hiccups: 0(0), FreeDm: 370, MinFreeDm: 303, MaxWait: 0ms
                                            === MainDDARing ===
                                            Scheduled moves: 31056, completed moves: 31009, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
                                            === AuxDDARing ===
                                            Heater 0 is on, I-accum = 0.6
                                            Segments left: 1
                                            === Network ===
                                            Slowest loop: 6.90ms; fastest: 0.03ms
                                            - Ethernet -
                                            State: active
                                            Extruder 0: pos -7.73, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                                            === CAN ===
                                            Messages sent 315, longest wait 0ms for type 0
                                            Last transfer: 2742318ms ago
                                            Buffer RX/TX: 0/0-0
                                            I've been printing 2x 30 minutes jobs without hiccups, but it has reset on its own before i printed.
                                            version is 18b6 in machine-specific tab in DWC
