    Need help installing ustreamer
    135
    10.8k
    • gtj0undefined
      gtj0 @A Former User
      @bearer said in Need help installing ustre sure the camera is plugged in.
      eamer
      thats intentional. %I gets escaped so it doesn't contain special characters, which is needed for the name (and i suspect gtj0 would have corrected it if I was mistaken:)
      Correct. It's just in the description anyway.
      @luckyflyer start simple...
      ### Move the rules file out of the way
      $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/
      ### Reload systemd
      $ sudo systemctl daemon-reload
      ### Enable ustreamer@video0 to start on boot.
      $ sudo systemctl enable ustreamer@video0
      Created symlink /etc/systemd/system/multi-user.target.wants/ustreamer@video0.service → /etc/systemd/system/ustreamer@.service.
      ### Make sure the camera is plugged in.
      ### Reboot.
      $ sudo systemctl reboot
      ###  When the Pi is back up, check the status of the service...
      $ sudo systemctl status ustreamer@video0
      • luckyflyerundefined
        luckyflyer
        @gtj0 Thanks for your help and sorry to be such a pain.
        I enter each command and this is what I get.
        pi@duet3:~ $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/
        pi@duet3:~ $ sudo systemctl daemon-reload
        pi@duet3:~ $ sudo systemctl enable ustreamer@video0
        Failed to enable unit: Unit file ustreamer@video0.service does not exist.
        I have followed the previous steps exactly and several times using copy and paste. I'm using nano3.2 and do ctrl X Yes then enter to save and then reboot. I do this for both of the files. I'm at a loss to for why the service does not exist.
        One thing I've noticed is when I go back into the editor the text that I previously entered
        ACTION=="add", KERNEL=="video0", SUBSYSTEM=="video4linux", TAG+="systemd", ENV{SYSTEMD_WANTS}+="ustreamer@%k.service"
        ACTION=="remove", KERNEL=="video0", SUBSYSTEM=="video4linux", RUN+="/bin/systemctl --no-block stop ustreamer@%k.service"
        and
        [Unit]
        Description=UStreamer for %I
        [Service]
        Type=simple
        ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
        [Install]
        WantedBy=multi-user.target
        are still there, is this normal? I have the feeling that the files are not being saved. I'm wondering if I don't have permissions set correctly but get no error stating that I don't. Doing research to understand about permissions.
        • gtj0undefined
          gtj0 @luckyflyer
          @luckyflyer Are you sure the ustreamer@.service file is located in /etc/systemd/system and that it's named exactly that?
          Try ls -al /etc/systemd/system then cat /etc/systemd/system/ustreamer@.service
            luckyflyer
            @gtj0
            pi@duet3:~/ustreamer $ ls -al /etc/systemd/system
            total 76
            drwxr-xr-x 17 root root 4096 May 29 22:30 .
            drwxr-xr-x  5 root root 4096 May 19 06:26 ..
            -rw-r--r--  1 root root 1551 Apr  7 06:06 autologin@.service
            drwxr-xr-x  2 root root 4096 May 19 07:56 basic.target.wants
            drwxr-xr-x  2 root root 4096 May 19 06:36 bluetooth.target.wants
            lrwxrwxrwx  1 root root   42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service
            lrwxrwxrwx  1 root root   37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
            lrwxrwxrwx  1 root root   40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
            lrwxrwxrwx  1 root root   45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service
            lrwxrwxrwx  1 root root   34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service
            lrwxrwxrwx  1 root root   35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service
            drwxr-xr-x  2 root root 4096 May 19 06:26 getty.target.wants
            drwxr-xr-x  2 root root 4096 May 19 06:31 getty@tty1.service.d
            drwxr-xr-x  2 root root 4096 May 19 07:58 graphical.target.wants
            drwxr-xr-x  2 root root 4096 May 19 06:35 halt.target.wants
            drwxr-xr-x  2 root root 4096 May 25 20:04 multi-user.target.wants
            drwxr-xr-x  2 root root 4096 May 19 06:28 network-online.target.wants
            drwxr-xr-x  2 root root 4096 May 19 06:35 poweroff.target.wants
            drwxr-xr-x  2 root root 4096 May 19 06:38 rc-local.service.d
            drwxr-xr-x  2 root root 4096 May 19 06:35 reboot.target.wants
            drwxr-xr-x  2 root root 4096 May 19 06:36 remote-fs.target.wants
            drwxr-xr-x  2 root root 4096 May 19 08:03 sockets.target.wants
            lrwxrwxrwx  1 root root   31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service
            drwxr-xr-x  2 root root 4096 May 19 06:36 sysinit.target.wants
            lrwxrwxrwx  1 root root   35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service
            drwxr-xr-x  2 root root 4096 May 19 06:29 timers.target.wants
            -rw-r--r--  1 root root  217 May 30 12:24 ustreamer@.service:
            pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service
            cat: /etc/systemd/system/ustreamer@.service: No such file or directory
            Looks like the first one is there, but not the second.
            I think it's something with my editor but don't know how to check to see.
              A Former User @luckyflyer
              @luckyflyer maybe try making it executable?
              sudo chmod +x /etc/systemd/system/ustreamer@.service
              (long shot)
                luckyflyer
                tried it,
                pi@duet3:~ $ sudo chmod +x /etc/systemd/system/ustreamer@.service
                chmod: cannot access '/etc/systemd/system/ustreamer@.service': No such file or directory
                  luckyflyer
                  @gtj0 @bearer
                  Been reading up on the cat command, was wondering if that would be a good way to create and save the missing file?
                  A Former User? 2 Replies Last reply Reply Quote 0
                    hmm, does the filename have a : at the end?
                    sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service
                      luckyflyer
                      @gtj0 said,
                      I noticed that in
                      that in line 29 it is
                      ustreamer@.service:
                      With a colon, instead of
                      ustreamer@.service
                      Is this a problem?
                        luckyflyer
                        They say great minds think alike................ maybe, I don't know lol.
                          @luckyflyer said in Need help installing ustreamer:
                          well, you can use cat and heredoc to create files like so
                          cat << EOF > /tmp/yourfilehere
                          These contents will be written to the file.
                                  This line is indented.
                          EOF
                          but redirects and sudo gets messy so you'd need something like
                          cat << EOF | sudo tee /tmp/yourfilehere
                          EOF
                          but you'll have to deal with escaping on the command line etc. i to use it from time to time, but its not always the best option.
                            luckyflyer
                            How would I get rid of the :
                              sudo mv renames it
                              edit thats better.
                                luckyflyer
                                tried,
                                pi@duet3:~ $ sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service sudo chmod +x /etc/systemd/system/ustreamer@.service
                                mv: target '/etc/systemd/system/ustreamer@.service' is not a directory
                                pi@duet3:~ $
                                  tried,
                                  pi@duet3:~ $
                                  forum messed the formatting, scroll up to where i posted it
                                    luckyflyer
                                    same,
                                    pi@duet3:~ $
                                      @luckyflyer thats the same, its two commands, forum made it one line when i made it a quote. look for one that is two lines, i'm not gonna quote it again just to have the forum mess it up again
                                        luckyflyer
                                        I copy and pasted, nothing else to do right?
                                          luckyflyer
                                          roger one moment
                                            luckyflyer
                                            ok colon now gone,
                                            pi@duet3:~ $ ls -al /etc/systemd/system
                                            total 76
                                            drwxr-xr-x 17 root root 4096 May 31 00:25 .
                                            -rwxr-xr-x  1 root root  217 May 30 12:24 ustreamer@.service
                                            pi@duet3:~ $
