    Need help installing ustreamer
    135
    10.8k
    • luckyflyerundefined
      luckyflyer
      @gtj0 @bearer
      Been reading up on the cat command, was wondering if that would be a good way to create and save the missing file?
      A Former User? 2 Replies Last reply Reply Quote 0
        A Former User @luckyflyer
        hmm, does the filename have a : at the end?
        sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service
        sudo chmod +x /etc/systemd/system/ustreamer@.service
          luckyflyer
          @gtj0 said,
          @luckyflyer Are you sure the ustreamer@.service file is located in /etc/systemd/system and that it's named exactly that?
          I noticed that in
          ls -al /etc/systemd/system
          that in line 29 it is
          ustreamer@.service:
          With a colon, instead of
          ustreamer@.service
          Is this a problem?
            luckyflyer
            They say great minds think alike................ maybe, I don't know lol.
              @luckyflyer said in Need help installing ustreamer:
              well, you can use cat and heredoc to create files like so
              cat << EOF > /tmp/yourfilehere
              These contents will be written to the file.
                      This line is indented.
              EOF
              but redirects and sudo gets messy so you'd need something like
              cat << EOF | sudo tee /tmp/yourfilehere
              EOF
              but you'll have to deal with escaping on the command line etc. i to use it from time to time, but its not always the best option.
                luckyflyer
                How would I get rid of the :
                  sudo mv renames it
                  edit thats better.
                    luckyflyer
                    tried,
                    pi@duet3:~ $ sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service sudo chmod +x /etc/systemd/system/ustreamer@.service
                    mv: target '/etc/systemd/system/ustreamer@.service' is not a directory
                    pi@duet3:~ $
                      tried,
                      pi@duet3:~ $
                      forum messed the formatting, scroll up to where i posted it
                        luckyflyer
                        same,
                        pi@duet3:~ $
                          @luckyflyer thats the same, its two commands, forum made it one line when i made it a quote. look for one that is two lines, i'm not gonna quote it again just to have the forum mess it up again
                            luckyflyer
                            I copy and pasted, nothing else to do right?
                              luckyflyer
                              roger one moment
                                luckyflyer
                                ok colon now gone,
                                pi@duet3:~ $ ls -al /etc/systemd/system
                                total 76
                                drwxr-xr-x 17 root root 4096 May 31 00:25 .
                                drwxr-xr-x  5 root root 4096 May 19 06:26 ..
                                -rw-r--r--  1 root root 1551 Apr  7 06:06 autologin@.service
                                drwxr-xr-x  2 root root 4096 May 19 07:56 basic.target.wants
                                drwxr-xr-x  2 root root 4096 May 19 06:36 bluetooth.target.wants
                                lrwxrwxrwx  1 root root   42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service
                                lrwxrwxrwx  1 root root   37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
                                lrwxrwxrwx  1 root root   40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
                                lrwxrwxrwx  1 root root   45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service
                                lrwxrwxrwx  1 root root   34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service
                                lrwxrwxrwx  1 root root   35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service
                                drwxr-xr-x  2 root root 4096 May 19 06:26 getty.target.wants
                                drwxr-xr-x  2 root root 4096 May 19 06:31 getty@tty1.service.d
                                drwxr-xr-x  2 root root 4096 May 19 07:58 graphical.target.wants
                                drwxr-xr-x  2 root root 4096 May 19 06:35 halt.target.wants
                                drwxr-xr-x  2 root root 4096 May 25 20:04 multi-user.target.wants
                                drwxr-xr-x  2 root root 4096 May 19 06:28 network-online.target.wants
                                drwxr-xr-x  2 root root 4096 May 19 06:35 poweroff.target.wants
                                drwxr-xr-x  2 root root 4096 May 19 06:38 rc-local.service.d
                                drwxr-xr-x  2 root root 4096 May 19 06:35 reboot.target.wants
                                drwxr-xr-x  2 root root 4096 May 19 06:36 remote-fs.target.wants
                                drwxr-xr-x  2 root root 4096 May 19 08:03 sockets.target.wants
                                lrwxrwxrwx  1 root root   31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service
                                drwxr-xr-x  2 root root 4096 May 19 06:36 sysinit.target.wants
                                lrwxrwxrwx  1 root root   35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service
                                drwxr-xr-x  2 root root 4096 May 19 06:29 timers.target.wants
                                -rwxr-xr-x  1 root root  217 May 30 12:24 ustreamer@.service
                                pi@duet3:~ $
                                  ok colon now gone,
                                  should help, do the daemon-reload and start stuff again?
                                  luckyflyerundefined 1 Reply Last reply Reply Quote 0
                                    luckyflyer
                                    Now,
                                    cat /etc/systemd/system/ustreamer@.service
                                    looks like,
                                    pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service
                                    [Unit]
                                    Description=UStreamer for %I
                                    [Service]
                                    Type=simple
                                    ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
                                    [Install]
                                    WantedBy=multi-user.target
                                    pi@duet3:~ $
                                      luckyflyer @A Former User
                                      daemon-reload? Sorry 12:30 am I pretty dingy can't last much longer.
                                        this post https://forum.duet3d.com/post/157829
                                          luckyflyer
                                          It took it all now rebooting
                                            luckyflyer
                                            Rebooted and logged on, went to http://192.168.0.181:8080/stream but no image. When I manually start pgm image is there.
