    Need help installing ustreamer
    135
    10.8k
    • luckyflyerundefined
      luckyflyer
      tried it,
      pi@duet3:~ $ sudo chmod +x /etc/systemd/system/ustreamer@.service
      chmod: cannot access '/etc/systemd/system/ustreamer@.service': No such file or directory
        luckyflyer
        @gtj0 @bearer
        Been reading up on the cat command, was wondering if that would be a good way to create and save the missing file?
        A Former User? 2 Replies Last reply Reply Quote 0
          A Former User @luckyflyer
          hmm, does the filename have a : at the end?
          sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service
            luckyflyer
            @gtj0 said,
            @luckyflyer Are you sure the ustreamer@.service file is located in /etc/systemd/system and that it's named exactly that?
            I noticed that in
            ls -al /etc/systemd/system
            that in line 29 it is
            ustreamer@.service:
            With a colon, instead of
            ustreamer@.service
            Is this a problem?
              luckyflyer
              They say great minds think alike................ maybe, I don't know lol.
                @luckyflyer said in Need help installing ustreamer:
                well, you can use cat and heredoc to create files like so
                cat << EOF > /tmp/yourfilehere
                These contents will be written to the file.
                        This line is indented.
                EOF
                but redirects and sudo gets messy so you'd need something like
                cat << EOF | sudo tee /tmp/yourfilehere
                EOF
                but you'll have to deal with escaping on the command line etc. i to use it from time to time, but its not always the best option.
                  luckyflyer
                  How would I get rid of the :
                    sudo mv renames it
                    edit thats better.
                      luckyflyer
                      tried,
                      pi@duet3:~ $ sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service sudo chmod +x /etc/systemd/system/ustreamer@.service
                      mv: target '/etc/systemd/system/ustreamer@.service' is not a directory
                      pi@duet3:~ $
                        tried,
                        pi@duet3:~ $
                        forum messed the formatting, scroll up to where i posted it
                          luckyflyer
                          same,
                          pi@duet3:~ $
                            @luckyflyer thats the same, its two commands, forum made it one line when i made it a quote. look for one that is two lines, i'm not gonna quote it again just to have the forum mess it up again
                              luckyflyer
                              I copy and pasted, nothing else to do right?
                                luckyflyer
                                roger one moment
                                  luckyflyer
                                  ok colon now gone,
                                  pi@duet3:~ $ ls -al /etc/systemd/system
                                  total 76
                                  drwxr-xr-x 17 root root 4096 May 31 00:25 .
                                  drwxr-xr-x  5 root root 4096 May 19 06:26 ..
                                  -rw-r--r--  1 root root 1551 Apr  7 06:06 autologin@.service
                                  drwxr-xr-x  2 root root 4096 May 19 07:56 basic.target.wants
                                  drwxr-xr-x  2 root root 4096 May 19 06:36 bluetooth.target.wants
                                  lrwxrwxrwx  1 root root   42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service
                                  lrwxrwxrwx  1 root root   37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
                                  lrwxrwxrwx  1 root root   40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
                                  lrwxrwxrwx  1 root root   45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service
                                  lrwxrwxrwx  1 root root   34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service
                                  lrwxrwxrwx  1 root root   35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service
                                  drwxr-xr-x  2 root root 4096 May 19 06:26 getty.target.wants
                                  drwxr-xr-x  2 root root 4096 May 19 06:31 getty@tty1.service.d
                                  drwxr-xr-x  2 root root 4096 May 19 07:58 graphical.target.wants
                                  drwxr-xr-x  2 root root 4096 May 19 06:35 halt.target.wants
                                  drwxr-xr-x  2 root root 4096 May 25 20:04 multi-user.target.wants
                                  drwxr-xr-x  2 root root 4096 May 19 06:28 network-online.target.wants
                                  drwxr-xr-x  2 root root 4096 May 19 06:35 poweroff.target.wants
                                  drwxr-xr-x  2 root root 4096 May 19 06:38 rc-local.service.d
                                  drwxr-xr-x  2 root root 4096 May 19 06:35 reboot.target.wants
                                  drwxr-xr-x  2 root root 4096 May 19 06:36 remote-fs.target.wants
                                  drwxr-xr-x  2 root root 4096 May 19 08:03 sockets.target.wants
                                  lrwxrwxrwx  1 root root   31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service
                                  drwxr-xr-x  2 root root 4096 May 19 06:36 sysinit.target.wants
                                  lrwxrwxrwx  1 root root   35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service
                                  drwxr-xr-x  2 root root 4096 May 19 06:29 timers.target.wants
                                  -rwxr-xr-x  1 root root  217 May 30 12:24 ustreamer@.service
                                  pi@duet3:~ $
                                    ok colon now gone,
                                    should help, do the daemon-reload and start stuff again?
                                    luckyflyerundefined 1 Reply Last reply Reply Quote 0
                                      luckyflyer
                                      Now,
                                      cat /etc/systemd/system/ustreamer@.service
                                      looks like,
                                      pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service
                                      [Unit]
                                      Description=UStreamer for %I
                                      [Service]
                                      Type=simple
                                      ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
                                      [Install]
                                      WantedBy=multi-user.target
                                      pi@duet3:~ $
                                        luckyflyer @A Former User
                                        daemon-reload? Sorry 12:30 am I pretty dingy can't last much longer.
                                          this post https://forum.duet3d.com/post/157829
                                            luckyflyer
                                            It took it all now rebooting
