    CoreXY Ringing
    1.7k
    • Gerrardundefined
      Gerrard
      Hi all,
      I've built a huge CoreXY printer - based loosely on a short lived design by FLSun. Currently its at the "proof of concept" stage while I iron out all the bugs.
      I've been trying to iron out the settings, and I spent a few hours on these forums last night looking for clues to a ringing problem I had on a large test cube.
      I added M593 to my config.g file (along with a few other tweaks) and that seems to have cured it completely. However, There is now a larger artifact at the very start of a long wall, then it fades away to nothing. - see image below.
      What could cause this? I'm assuming it's a G-Code thing since it wasn't there before.
      I've attached my config.g as well for reference. config.g
      (also appreciate if you notice anything in that config that I should attend too as well.
      Finally... Big thanks to dc42 and Phaedrux for all their wisdom - all the posts I found offered some valuable contribution from one or both of you.
      All the best.
      • fcwiltundefined
        fcwilt
        Is ringing affected by the print speed?
        Gerrardundefined 1 Reply Last reply Reply Quote 0
        • JoergS5undefined
          JoergS5
          I would try lowering the acceleration.
          There may be a part which is flexing (belt tenstion too low, some pulley or axis).
          • Gerrardundefined
            Gerrard @fcwilt
            @fcwilt
            This is the first print since I tweaked the settings, so I'm not sure...
            What action would I take in either case?
            • Gerrardundefined
              Gerrard @JoergS5
              @JoergS5
              Its likely that the gantry is flexing ... it's only 40x20 Vslot over 800mm long,
              I'll try reprinting on a different area of the bed (gantry closer to one end), and tweaking the accel...
              Keen to keep the suggestions coming, it'll keep me busy over the weekend.
              Cheers
              • fcwiltundefined
                fcwilt @Gerrard
                @Gerrard said in CoreXY Ringing:
                @fcwilt
                I have no idea. I was just wondering about this ringing issue which I don't think I have encountered in my prints BUT I don't try to print at very high speeds with 60 mm/s being my normal speed.
                • JoergS5undefined
                  JoergS5 @Gerrard
                  @JoergS5
                  Cheers
                  Sometimes it helps to make the gantry more stiff by adding some triangle connections at the corners. Steel/Aluminium plates or even steel wires could help.
                    It looks like you've traded one frequency of ringing for another. DAA has limitations, especially in a corexy where the X and Y axis may have different ringing frequencies. In the end, for my corexy, I had to find a jerk/accel combo that gave good quality on external walls, I also use Cura that allows me to set different jerk/accel per print move, so that infill, etc can be much faster than the walls need to be.
                    • Gerrardundefined
                      Gerrard
                      Hi All,
                      Quick updated. I spent most of today tuning settings and speeds - mostly in search of good quality and super high speeds.
                      I added an equal angle to the back of the gantry in the hope of curing some of the vibration, and it's done the trick for sure - which validates the flexing hypothesis.
                      I reduced the acceleration slightly (at the same time) and started cranking up the speed. I've managed to achieve 300mm/s on a simple thin walled square with only the faintest trace of ringing so I'm thrilled with that result. I did get a problem with under extrusion at about the 200mm/s mark, but I cured that by just turning the nozzle temp up to 220°C, and that cured it.
                      My final settings were
                      300mm/s for all surfaces (walls, top and bottom layers).
                      100mm/s for initial layers.
                      500mm/s^2 Accel (all conditions)
                      9mm/s Jerk.
                      I feel like I could go a fair bit higher on the accel, so I'm going to try pushing that a little harder over time.
                      I do however have another problem (pre-existing)... I'll start a new thread for that to keep this clean.
                      Thanks all.
                      • jens55undefined
                        jens55
                        On my printer (CR10 style) this would be caused by an incorrect pressure advance parameter.
                        • Gerrardundefined
                          Gerrard @jens55
                          Hi @jens55 - As above, it seems to be related to the stiffness of the gantry... increasing the stiffness made the problem go away.
                          • NitroFreakundefined
                            NitroFreak
                            DAA (M593) has an inherent flaw in that it only really works perfectly when there is 0 jerk.
                            Unfortunately it´s usually the jerk that causes most of the ringing...
                            • jens55undefined
                              jens55
                              I somehow missed the picture with the final settings when I replied earlier.
                              That surface finish is incredible! I have never seen finish like that before even at a much lower speed. It's amazing what can be done if you don't sling a 2 kg (or whatever) bed around !
                              Thanks for posting that ....
                              Hmmmm ..... food or new 3D printer ..... well this seems a good enough reason to go on a diet!
                              Gerrardundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
                              • Gerrardundefined
                                Gerrard @jens55
                                @jens55 It's worth noting that I was only printing at 0.2mm layer height. It's easy (easier?) to get a nice finish at lower layer height - there's less molten plastic to deal with.
                                • jens55undefined
                                  jens55
                                  At 300 mm/sec you can print as fast with 0.2 mm layers as I can go with a 1 mm layer height! It just amazes the hell out of me!
                                  I hope that you might have a chance to share more pictures of your build as it progresses (or when it's ready for prime time).
                                  • mrehorstdmdundefined
                                    mrehorstdmd @jens55
                                    @jens55 with acceleration at 500 mm/sec^2 and jerk at 9 mm/sec, the printer probably never actually achieves 300 mm/sec.
                                    • JoergS5undefined
                                      JoergS5 @jens55
                                      @jens55 said in CoreXY Ringing:
                                      With a good multipaterial printer you can print your food! 😉
                                      • Gerrardundefined
                                        Gerrard @mrehorstdmd
                                        @mrehorstdmd The bed is 800x870 so there's plenty of room to move. But you're right, you need a bigger print. I'll increase Accel and Jerk soon - I decreased them to help eliminate those defects initially.
                                          mrehorstdmd @Gerrard
                                          @Gerrard Now look at corners of a square print- at low jerk and accel they then to get fat and rounded. Everything is a trade off.
