    What do you think about Dragon Hotend
    43
    8.6k
      deckingman @arhi
      @arhi This is getting off topic I know, but I'm beginning to think that an all metal mixing hot end just isn't possible. My latest design iteration will confirm that (if I've managed to cure all the leaks). The reason why I'm beginning to believe that is because when one has multiple inputs, inevitably some of those filaments will not be moving forward at all for maybe hours. Regardless of how efficient the heat break is, it is inevitable that the filament itself will conduct some heat. Maybe a periodic purge of the "unused" filaments might help. Or maybe I restrict myself to never printing PLA. Or maybe I try and make my own custom heat breaks with PTFE liners and only print low temperature filaments. Dunno - we'll have to see.....
      BTW, I hope you don't mind my pointing this out but I know that English isn't your first language. You are using the word "trough" when I think you mean "through". A "trough" is a long narrow open container, often for animals to eat or drink from. So "heat creep trough filament" doesn't make much sense, whereas "heat creep through filament" makes perfect sense. 🙂 Hope you don't mind me pointing that out but if you'd rather I didn't, just say so.
      arhiundefined 1 Reply Last reply Reply Quote 1
      • arhiundefined
        arhi @deckingman
        @deckingman said in What do you think about Dragon Hotend:
        Maybe @Phaedrux can rip the off-topic part of our discussion into a new topic about all metal hotends - pros/cons/history/ideas... might be useful discussion 🙂
        That is the reason I never wanted to use all those "two nozzles single heater" nor "two input single nozzle" solutions popping up since day one. The major reason is that I'd be going either "main+support" or "hard+soft" combo of materials so 99% of the time only one will be printed while the other material will 99% of the time sit still and cook... not to mention when they require different temps (like TPU/PVA + ABS/PETG/HIPS/ASA combo). That is also why I never seriously looked at the diamond as the "color" aspect is fairly irrelevant for what I print (if it needs color it will be post-processed).
        IMHO the "purge" should work. In theory, you could measure how much heat would creep up in set amount of time so you can know exactly how much you need to purge at what interval. Question is only how to actually do it as this is something a firmware would have to support as you have no idea in G-Code what amount of time passed. Some half-way solution, of course, would be to do it from g-code and purge "more than required" and "more often than required" but should work IMHO.
        I think there are 2 problems there
        1. cooking of the filament
        2. heat creep leading to filament swelling and blocking of the filament path
        I am confident that some fancy machining could solve the heat creep by introducing the water cooling of the cold side of the melt chamber. I did some tests with arcol back in the day and steel is pretty resilient to being cold and hot on a very short distance, the downside is a requirement of a more powerful heater and more energy waste keeping the few mm's of a steel tube at 200C temp differential. We were even trying to find a company willing to make us a Peltier element with a 3.2mm hole that we would cement the tube trough (as just drilling a Peltier plate just kills the darn thing, we tried 😄 ).
        The bigger issue is the cooking of the filament as a most filament (especially ABS in my experience) will change properties if it stay on the extrusion temperature long enough. Many will start to carbonize, others will decompose; ABS will for e.g. go dark, start to harden (maybe crystalize?) and some oily thing (super flammable) will start to separate.
        The only thing I can see the "cooking" problem being solved on a "single heater" hotend would be to purge the filament from time to time, and since purging also solves the heat creep...
        Or maybe I try and make my own custom heat breaks with PTFE liners and only print low-temperature filaments.
        You still get the "cooking" issue. I don't have enough experience with PLA (I don't think PLA reached even 1% of the filament I printed), maybe it does not suffer from that too much but it's still a problem.
        As for low temp vs high temp, looking through history, all the fancy all metal hotends have some kind of issue with low temp filaments, OTOH the hotends that play nice with those low temp materials will be terrible at the high temp ones. IMHO the only real solution is to have a "head per material" setup.
        This is something I do since day one.. on my rapman I had 4 complete extruder assemblies one for PP and HDPE, one for ABS with .5mm nozzle and one for ABS with .25mm nozzle.. for e.g. for my I3 style printer I made a modular X carriage so I can easily swap the head (single screw)
        https://www.thingiverse.com/thing:2039960
        and there I have a PTFE lined hotend (some old design of mine) for PLA, again my design for 3mm filament with 1mm nozzle for PP/HDPE, some all metal 3mm with bmg, all metal 1.75mm with remote direct drive, dual hexagon full metal with dual remote direct drive etc etc..
        I have sitting in pieces the e3d's toolchanger (no time to assemble) that I hope will be the final solution... we'll see, in the meantime I'm looking to buy some el-cheapo UV printer so I can design and print a proper connector with pogo pins or something similar that I would like to use for the extruder assembly...
        After the political BS that happened here during 90's and creation of new nationalities and new languages English is now my 6th or 7th language 😞
        Real problem is that I never actually "learned" English, never took courses etc. I spent 8 years learning German in school (and apart of being able to read technical documentation I can't speak nor understand a word of it)... so while I do use it non stop I know I'm far from good at it (you should hear me speak, sounds like a comic exaggerating how a Russian criminal sounds like 😄 😄 😄 but I manage to get point across so I don't care much 😄 )
        Yeah, I am mixing those two often and spell checker does not catch it as "trough" is also a valid word :(. Thanks for the reminder I'll try to pay attention more :), I do appreciate any comment that helps me improve 🙂
        deckingmanundefined theruttmeisterundefined 2 Replies Last reply Reply Quote 0
          deckingman @arhi
          @arhi PLA doesn't "cook" but what it does do is hydrolyse. That is to say, the longer it is held at print temperature, the less viscous (more "runny") it becomes. So if it's sat at print temperature for an hour or more, when you do try to extrude some, the entire contents of the melt chamber comes out of the nozzle in one single runny stream. Then you get nothing until fresh filament fills up the melt chamber again. At least, that is what happens with the Diamond. So I'm kind of used to purging "unused" filaments.
          I've never had any problems with PET-G. Even after being held at print temperature for 8 hours or so.
          The Diamond suffers from heat creep - the 5 colour is much worse than the 3 colour due to the lower heat sink fins being reduced in diameter. But, they use E3D "lite" style heat breaks which have the PTFE Bowden tube going right through the heat break. So although the filament swells due to heat creep, it doesn't block the heat break. Of course, the PTFE liner limits the temperatures and therefore filament types that can be used.
          I haven't connected my RPI yet but I'm told that it would be possible to do "time based" purging using the SBC (something to do with a python program using the API).
          • arhiundefined
            arhi @deckingman
            Good to know, it's much easier to handle "empty" than "charred" nozzle :). I had nozzles that I had to redrill with a larger drill as it was impossible to clean up carbonised ABS.
            I'm waiting for that to become "a thing", especially the support for duet2+sbc before I invest some time to see what can be actually done with it. Slowly going trough Danal's work on the library and thinking about redoing (in go most probably, 'cause I need a reason to become more proficient in go) his library and porting the plugins I'm used to on octoprint to this new platform.. but for now I'm just patiently waiting to see where it all leads as for now I don't see a reason to go duet3 way and my bunch of duet2 boards so far don't know how to communicate with SBC.
            • theruttmeisterundefined
              theruttmeister @arhi
              @arhi said in What do you think about Dragon Hotend:
              Yes. There's an awful lot of people who are still building things like that dragon hotend, and have clearly never seen the early dev work done by NopHead.
              And the dragon hotend?
              Will suck with PLA. Heatsink is waaaaay too small.
              It actually looks like the hotend Prusa was waving around about 7 or 8 years ago that he never got to work.
              Based on the work I've done, thermal creep isn't the main issue. At least not if your heatsinks are large enough. But all the other things are problems.
              Snip!
              This is where I stopped my work. Basically, in all-metal hotends you need to have some clearance around the filament to allow for thermal expansion. PTFE is soft and slippery enough that you can have a tight seal. If you don't have that seal, molten material gets pushed up into the thermal break far enough it causes issues.
              Add the fact that my design requirement was to be able to print TPU and PETG in the same part. The TPU compresses and gets pushed back into the thermal break. Not good. Gave up.
              I did think about things like silicone seals at the base of the thermal break. But frankly I think mixing heads are just a bad solution and need far too much complexity to be worth it. So long as you can index the nozzles accurately between 2 or more extruders, there's no real advantage to mixing heads (unless you really are going to mix).
              At the end of the day you have a printhead that requires two (or more) filaments to even function at all. I don't think mixing heads have a large enough market to be worth the trouble.
              Although now I'm nostalgic for a 'mixing' head I saw several years ago at the NY maker faire... he wanted to run about 12 filaments, and liquids and god knows what else. I'm fairly certain that never worked.
              What do you consider a 'low temp' or 'high temp' material? There has been at least 1 extruder on the market that (if fitted with a better sensor) could print in ULTEM or PEEK, was also very good with PLA, maybe the best with TPU. It couldn't print wax to save its life...
              I'm not convinced that the e3d design is the way to go (a magnet is all that stops the head from falling off? Really? So no high-speed printing then.) but its an early attempt and sold as an experiment.
              But the concept, tool changers, is absolutely the way to go. We are lucky that RRF and duet 3 makes that a practical option now.
              If you really want to go crazy, you can even add a Palette to such a machine. 4 colour head for PLA, plus more heads for other stuff.
              Why print something that already exists?
              https://www.mill-max.com/
              (Yes, I get the irony of saying that here, of all places)
              Isolate, substitute, verify.
              fcwiltundefined arhiundefined 2 Replies Last reply Reply Quote 0
                deckingman @arhi
                ..................Slowly going trough Danal's work .............................
                You did it again... 🙂
                I have an RPI - it's bolted to the printer but that's as far as I've got with it.
                To clean carbonised or blocked nozzles and stainless steel heat breaks, I wouldn't for one minute suggest that you should try putting them in an oven which has a pyrolytic cleaning cycle. Because that cycle typically reaches about 500 to 600 deg C which will burn away any plastic and leave nothing more than some loose ash which is easily removed with soft brush. It won't damage stainless steel, brass, or copper but it's too close to the melting point of aluminium so don't try it with a complete hot end. Of course you should never try this in any case because burning off plastic could release toxic fumes. That's why I wouldn't ever suggest you try it. But hypothetically speaking, if you take precautions about ventilation and so forth, it does work. 🙂
                arhiundefined jens55undefined 2 Replies Last reply Reply Quote 0
                • fcwiltundefined
                  fcwilt @theruttmeister
                  @theruttmeister said in What do you think about Dragon Hotend:
                  The heat sink is similar in size to the Mosquito and the M works fine.
                  Why do you think the Dragon would be different?
                  theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                  • arhiundefined
                    arhi @theruttmeister
                    Yup, all the work NopHead and Arcol did shows many of this things are going in the wrong direction. Most of Nop's stuff is still available, Arcol killed his blog and the few forums he was active as are dead and non existing now. For some reason he was never accepted on reprap.org as his idea was always to make the commercial and not open design and the community really disliked that. Nop's work was also not that popular due to him keeping lot of details about his machine for himself (he was running combo of python on stronger computer with stepper on mcu 10+ years ago) as noone could reproduce his awesome results and while his posts were always super informative and full of real engineering and real math ppl kinda like YT flashy stuff and not something with substance 😞
                    I remember that one and was actually trying to find the video and pics but could not. It was before Prusa Research while he was still just a Czech student. If you find some links share 😄
                    That's the think @deckingman is trying to do, he's trying to make a new hotend that will actually mix the filament as diamond is not mixing them (you can read his text about "toothpaste effect")
                    which one?
                    ATTM I tested mosquito and it prints both PEEK and PLA
                    E3DV6 I used to print wax filament made by Kai. Never tried anything hotter than nylon on E3DV6.
                    I did not make my toolchanger design in 10+ years I'm in 3D printing and I was thinking about it since day one. No clue if it was lack of time, knowledge, ideas... but I never did it. That's why I purchased this one to use for a while and learn from all the bad decisions they made (and acknowledge good ones), before I decide how to proceed.
                    I looked trough I think 500 different connectors and was not satisfied with what I found. I'll go trough this site too. I prefer to purchase a working solution than to invent hot water 😄 but so far nothing I found was fitting my vision
                    • arhiundefined
                      arhi @deckingman
                      I mostly use orangepi's as they were more powerful and cheaper/easier to get here but I have bunch of rpi's too. We (oracle-mysql) started supporting arm cpu recently so I have whole bunch of them for testing 😄 .. I have them in raid, solo.. some I use with 3d printers with octoprint... I took one rpi4 on the side to try this RRF integration .. that's where I run duetlapse
                      Interesting. I assumed that once carbonized exposing it to even more heat would not help but only worsen the situation so I always used mechanical way of cleaning. Normally I'd leave it in acetone for few days, then move the acetone container with nozzle to the ultrasonic cleaner than remove from acetone and put directly in to ultrasonic bath with some cleaning detergent heated to 70C and after that - mechanical cleaning.
                        theruttmeister @fcwilt
                        @fcwilt said in What do you think about Dragon Hotend:
                        I dunno, I've not done testing on either of them. But given the mass and surface area of the heatsink, plus the lack of any information on how the stainless tube is attached to the copper (if its not a press fit, that's a problem). I would expect it to be sub-optimal.
                        But then I disagree with the design choices made on the mosquito as well.
                        Simply saying a hotend 'works' isn't much of a measure. If I actually got off my behind and made the testing rig I designed ages ago I would measure force required for a given extrusion rate, which is the type of metric that would allow us to actually measure if a given hotend design is better or worse than any other. But I haven't, so I shouldn't complain too much.
                        But my hypothesis is that both of those hotends would require less force to extrude if they were fitted with larger heatsinks.
                        • jens55undefined
                          jens55 @deckingman
                          Rather than heating up a big oven, a plumbers propane torch does wonders for cleaning nozzles... and it's very quick!
                          More importantly, it doesn't get SWMBO wound up.
                          zaptaundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                            Static mixing or active? Because sealing an active mixer is a challenge.
                            which one?
                            Type A Machines G2. Not that you can do anything useful with ULTEM or PEEK without an oven to print inside... Plus you can't buy that extruder any more.
                            I know the feeling. But just used some of the mill-max SLC components on a project. If I try and build a tool changer with electrical connections, I'll use something from them.
                            • arhiundefined
                              static mixing using "weird paths" like those multi-component mixer attachments on the industry syringes ..
                              https://somei3deas.wordpress.com/2020/02/24/my-6-input-51-mixing-hot-end-version-2/
                              there are 9 parts of that, I find it super interesting 🙂
                              I just went trough the site, they have the pogo pin modules I was planing to use but they don't have a "connectors" with guides, locks etc etc.. I did not plan to use just blank pins and house them in my case (if I don't have to :D) but to pack bunch of stuff like this into a mating pair:
                              theruttmeisterundefined 2 Replies Last reply Reply Quote 1
                                @arhi
                                I think the closest are these
                                https://www.mill-max.com/products/new/rugged-spring-loaded-wire-termination-connectors
                                But no, not an actual connector. But if you are building a tool changer you don't need a connector, you need to design the electrical connections into the tool mount.
                                A simple PCB, that carries SLC's and breaks them out into maybe Molex KK connectors, and locates accurately on a machined aluminium mount that holds the printhead. With a matching PCB and mount on the printer...
                                That's how I did would do it. 😉
                                You could also just use the ones I linked to and bolt them in position.
                                Although if you are only going to use 2 tools, and don't need to be able to swap out the heads super fast, just regular connectors would work.
                                • fcwiltundefined
                                  Perhaps you should. I tried one M and was so impressed that I equipped my other printer with one.
                                  I like everything about the M. If it has a downside I have not found it yet.
                                  Time will tell.
                                  • zaptaundefined
                                    zapta @jens55
                                    @jens55 said in What do you think about Dragon Hotend:
                                    That's what I do, with a small cooking torch, but arhi's comment here about toxic fumes made me rethink it.
                                      deckingman @jens55
                                      In my house, 'er in doors doesn't object to getting her oven cleaned. Speaking hypothetically of course, but if one were to put a heat break in the oven, one doesn't necessarily have to tell anyone 🙂 If you go about it the right way, you can even earn brownie points. Be careful with that torch - it's not too difficult to anneal stainless steel if you get it too hot.
                                      • arhiundefined
                                        arhi @deckingman
                                        I managed to kill aluminium nozzle with a small proxxon torch so I don't go with torch near my nozzles any more.
                                        Don't put "non food" in the oven, dunno, small kids, wife, life's short either way without needed to explain what/where/why... Will be moving, hopefully this year, to a house where I'll have a proper work space (I will have a small 50m2 house just for me 😄 ) and there I plan for plastic-dedicated oven for my recycled plates (I recycle failed prints, support, iterations.. into plastic plates I later on machine and use for other builds) and for other stuff but now when space is scarce I have to restrain myself and worry about WAR (wife approval rate)
                                          Perhaps I should. The load cell is just gathering dust and I've not done a blog post in about 6 years...
                                          Might be interesting to do 1 hotend a month, proper quantitative benchmark.
                                            Interesting.
                                            The huge volume of the melt chamber is going to be an issue... he'll have epic purge requirements. And its funny that he thinks there is IP in static mixing device design (hint, if hundreds of pounds is a lot, you can't afford patent enforcement), static mixers have been around forever and are well understood.
                                            I just look at the endless number of sealing surfaces... I get the desire for CMYK mixing. I just think that 99.9% of people are happy with a low maintenance hotend and a wide range of available single colours. Just using the 4 colours of a Palette is a big jump in complexity for design.
                                            Good luck to him.
