Heated bed 2500 Watt + Duet3 6hc
1.4k
    dutti @jens55
    @jens55
    ok I understand.... with S1 or S0.5 its heating much fast,but it comes to a fault. ``temperatur rising much slowly than expected. 1.3.C /sec. (with S0.5 its 0.7c/ sec.)
      jens55
      Default is S1 so just remove the portion that specifies 'S' or replace it with S1.0. You will want full power.
      You need to run heater tuning again in order to get rid of the warning message. You probably will see a message talking about being over - powered but that is expected. You need to understand what that means nad be aware of it but it's not a show stopper.
        jens55
        What is the command you give to start the tune ?
        undefined undefined 2 Replies Last reply 25 Jun 2020, 18:11 Reply Quote 0
          Stephen6309 @jens55
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning
          undefined 1 Reply Last reply 25 Jun 2020, 18:29 Reply Quote 0
            dutti @jens55
            @jens55
            With S.1 or nothing in the config.g the always comes to a warning:
            ``temperatur rising much slowly than expected. 1.3.C /sec"
            I mean I can skip the warning and start again. A few times and it's hot enough. So there are 2 options.
            S0.1 = heating slow BUT NO warning ``temperatur rising much slowly than expected. 1.3.C /sec"
            S1.0 or nothing: temperature rising fast but it comes to the warning:
            I use the button in the web control. I mean I used the configuration tool to setup heater etc.
              jens55
              It is of course up to you if you use S0.1 or S1.0, you need to decide while keeping in mind the speed of warmup (and maximum temperature).
              Forget about the warning message for now!
              undefined 1 Reply Last reply 25 Jun 2020, 18:20 Reply Quote 0
                jens55
                It's been a while since I have done tuning so maybe someone else can chime in to give you details about how to get rid of the warning message.
                Also, if the warning message results in the heater stopping to heat, then there is a problem. Again, I am not the right person to help out with that.
                undefined 1 Reply Last reply 25 Jun 2020, 18:21 Reply Quote 0
                  dutti @jens55
                  @jens55
                  Ok.. but why does it come to a warning when it is faster? The warning tells its rising to slow..
                  Why does it care about it? Haha
                  Can I skip this warning forever or change the value for " it's to slow"?
                  THANKS
                    dutti @jens55
                    @jens55
                    No worries. You already helped me. Thank you!!!!
                      jens55
                      The system tries to guess what it should see in the temperature rise. If it sees something that it thinks is out of the norm, it tells you about it. There are numerous parameters than can be tweaked from the 'standard' tuning and modifying them would alter the way that Duet thinks what is or isn't normal.
                      As long as the system doesn't throw a hard error, you can disregard the error and just keep it in the back of your mind.
                      A hard error is one where the system stops heating because it thinks there is something seriously wrong.
                        dutti @Stephen6309
                        @Stephen6309
                        M303: Run heater tuning
                        Parameters
                        Hnnn heater number
                        Pnnn PWM to use, 0 to 1 (you should normally use 1 i.e. full power), default 1
                        Snnn target temperature
                        Examples
                        M303 H1 P0.4 S240 ; tune heater 1 using 40% PWM, target temperature 240C
                        I made this with my date and it was fixed. Thank
                          jens55
                          What you just posted is tuning for a nozzle heater.
                          Again, just leave out the parameter that sets PWM (P) unless you know what you are doing.
                          You should be running M303 H0 S60 or something in that area.
                          undefined 1 Reply Last reply 25 Jun 2020, 18:34 Reply Quote 0
                            dutti @jens55
                            @jens55
                            I used the code with my specifications.
                            M303 H0 P0.7 S65
                            Sry
                              jens55
                              I don't understand why you insist on putting in PWM figures but if it makes you happy (and if it it doesn't give you a warning message) then so be it. Just be aware that it results in less power to your heat bed and causes a longer warmup time.
                              undefined 1 Reply Last reply 25 Jun 2020, 19:53 Reply Quote 0
                                dutti @jens55
                                @jens55
                                25C - 60C
                                S.1 = 78sec
                                S.0.7 = 110 sec
                                Both it's ok in my mind
                                No warning. Thanks to. The tune was successful @Stephen6309
                                  Sounds like you got it figured out.
                                  undefined 1 Reply Last reply 25 Jun 2020, 22:21 Reply Quote 0
                                    dutti @Phaedrux
                                    @Phaedrux
                                    Yes. There is nothing the forum can't help me!
                                    Thanks to all!!!!
                                    38 out of 45
